Post by paul8899 on Nov 28, 2015 20:28:15 GMT 1
any updates on this savage project? Yes there is
Post by paul8899 on Nov 28, 2015 20:59:10 GMT 1
After getting Mito envy while reading through Yazza54's thread I remembered that I had a pile of bits that used to be a mito. Being as the swingarm I made didn't fit I decided that I'd get a standard arm as it should be a straight swap I quickly remembered that I needed a rear wheel so I ordered one from an er6 so it would match the zx10 front It seems that the sprocket carrier I made for the 10 wheel fits but I won't know if the chain run is right until it's all together. It looks pretty though. When I tried the wheel in the arm I quickly realised that they won't fit together properly without machining the hub down a lot. It was then that I remembered that I moved the shock mount on the frame which gave me a couple of options. 1 is to move the mounts back to their orginal positions, this would mean that I'd have to junk the rear subframe and use a different seat unit though 2 try something else Being as I quite like the way it looks I'm going to try someting else.
Post by paul8899 on Dec 24, 2015 18:48:20 GMT 1
Being as I'm basically starting over again I thought I'd have a go at re-making some of the bits. One of the first things I found in the shed was the rear engine mount. So I found this 7.4kg lump of ally hiding in the bin Which ended up as a 1.3kg lump and fitted in a loose arm I then decided that the yokes I had already made didn't look as I wanted them to so ........ and a fitted picture ( I really need to clear my shed out ) The weight of these are 1.54kg and for comparison a set of oe R1 yokes weigh 1.5kg. I made a set of domes up for a friend of mine as well which have a toriodal chamber. The plan is that I'll use this shape when I ( finally ) build the engine which will save some time messing around developing the chamber shape Next job is to work out fitting the engine tie bars then I can start worrying about getting the wheel to fit in the arm
Post by yazza54 on Dec 24, 2015 19:21:55 GMT 1
Skillz
Post by rigga on Dec 25, 2015 14:42:58 GMT 1
You have some epic machining talent, but I'd question who leaves big billets of aluminium in the bin lol
Post by unrealedd on Dec 25, 2015 18:11:11 GMT 1
Wow some serious alloy porn going on there!!!!! Luvin it.
gringo
Post by gringo on Dec 25, 2015 20:43:49 GMT 1
Absolutely ace machining , can't wait to see he end result
2taol
Post by 2taol on Feb 16, 2016 17:22:27 GMT 1
[been keeping a low profile] nice updates!
pity about the beefy swinger
Post by Eyrey1 on Feb 17, 2016 0:47:31 GMT 1
Its taken me 3 months to get this far and I'm hoping to get it finished around christmas (ish) but you know how these things go
that was in 2010 paul ,lol how time flys eh . keep moving forward mate it will be a right thing when done ! cant wait to see it come together . you know i like all the ally parts but the stuff you do is like on the next level
Post by rgvsam81 on Feb 17, 2016 14:52:15 GMT 1
This is going to be awesome when finished
Post by Topman350 on Feb 21, 2016 21:36:31 GMT 1
Where can I get a milling machine like that very clever work top job :-)
Post by yazza54 on Aug 8, 2016 10:09:49 GMT 1
Any more progress? Seemed like you had the bit between your teeth
Post by markhoopy on Aug 8, 2016 11:06:14 GMT 1
+1 this has been a rebuild thread I've watched for a long time and it would be great to see it finished
Post by paul8899 on Aug 13, 2016 22:02:24 GMT 1
I'm still in the planning stage at the moment so it will take a while longer yet Plus I'm trying to get shot of my 3ma for a bit of space and everything has come to a standstill until that's sorted There is something I want to try out on the intake but I'm still working out the fine details so it will be a while until I'm ready to give any details out on exactly what it is
Post by svogliato88 on Oct 27, 2021 3:12:45 GMT 1
Wow!! can you sell one of this?? Being as I'm basically starting over again I thought I'd have a go at re-making some of the bits. One of the first things I found in the shed was the rear engine mount. So I found this 7.4kg lump of ally hiding in the bin Which ended up as a 1.3kg lump and fitted in a loose arm I then decided that the yokes I had already made didn't look as I wanted them to so ........ and a fitted picture ( I really need to clear my shed out ) The weight of these are 1.54kg and for comparison a set of oe R1 yokes weigh 1.5kg. I made a set of domes up for a friend of mine as well which have a toriodal chamber. The plan is that I'll use this shape when I ( finally ) build the engine which will save some time messing around developing the chamber shape Next job is to work out fitting the engine tie bars then I can start worrying about getting the wheel to fit in the arm
