Post by cobby on Feb 17, 2022 19:53:55 GMT 1
Great thread.
Loving the RG.
Post by stusco on Feb 25, 2022 16:53:27 GMT 1
Fitted my new brakes ,more bleeding required a bit spongy for me
Rg400
Feb 26, 2022 7:43:04 GMT 1
Post by mouse on Feb 26, 2022 7:43:04 GMT 1
That looks great, did you get the calipers and adapters from 'Bike Torque'?
Mouse
Post by stusco on Feb 26, 2022 7:58:48 GMT 1
I got the adapters from 17again and got them anodised i got the brakes from caprimoto in italy .Don’t get a rcs master cylinder they dont fit they hit the fairing and the clocks ive had to make new mirror brackets that spread the fairing enough too get full lock hopefully it passes an mot
Rg400
Feb 26, 2022 16:49:10 GMT 1
Post by mouse on Feb 26, 2022 16:49:10 GMT 1
I got the adapters from 17again and got them anodised i got the brakes from caprimoto in italy .Don’t get a rcs master cylinder they dont fit they hit the fairing and the clocks ive had to make new mirror brackets that spread the fairing enough too get full lock hopefully it passes an mot Thank you, shame about the m/c, hope you get it sorted. Mouse
Rg400
Mar 19, 2022 19:31:56 GMT 1
Post by stusco on Mar 19, 2022 19:31:56 GMT 1
Out for a run on my gamma today so it still doesn’t run right at low revs infact it has a flat spot from 2000 to 2800 and its dead you have to slip the clutch ,everywhere else its spot on and goes like a scalded cat ,unfortunately 2 to 2.8 is town /traffic driving it was a nightmare today stuck behind a bus on a steep hill ,the temperature gauge went to 3/4 just below the red,what do you think ? my mate thinks it needs smaller pilots,he says its not the airscrew as its ok upto 2000.
Rg400
Mar 19, 2022 20:05:11 GMT 1
via mobile
Post by midlifecrisisrd on Mar 19, 2022 20:05:11 GMT 1
What is it doing between 2000 and 2800?
Usually if pilot is too small it bogs with the carbs droning. Won't take anything other than small throttle openings
Rich and it will be a wall like when you leave the choke on or machine gunning
Take the air filters out and see if it gets better or worse
Post by stusco on Mar 19, 2022 20:09:37 GMT 1
No throttle movement makes any difference you just have to wait or slip the clutch ill pop the filter off tomorrow
Post by 500RG on Mar 20, 2022 6:44:27 GMT 1
Rg400
Mar 20, 2022 11:07:14 GMT 1
Post by stusco on Mar 20, 2022 11:07:14 GMT 1
I new i had read that somewhere,cheers Saying that it idles fine its only pulling away or crawling in traffic
Rg400
Mar 20, 2022 11:38:43 GMT 1
via mobile
Post by 500RG on Mar 20, 2022 11:38:43 GMT 1
I’m sure there is another article by Lance on setting carbs up - but I just can’t seem to find it at the moment.
Rg400
Mar 20, 2022 11:43:16 GMT 1
via mobile
Post by 500RG on Mar 20, 2022 11:43:16 GMT 1
Rg400
Mar 20, 2022 11:44:50 GMT 1
via mobile
Post by 500RG on Mar 20, 2022 11:44:50 GMT 1
These bikes are never great at the bottom end and even worse with any tuning, carb bore or disc mods.
Rg400
Mar 20, 2022 11:48:33 GMT 1
Post by stusco on Mar 20, 2022 11:48:33 GMT 1
Well im f**ked as ive got all of that😬
Rg400
Mar 20, 2022 11:55:41 GMT 1
via mobile
Post by 500RG on Mar 20, 2022 11:55:41 GMT 1
Me too !
Rg400
Apr 2, 2022 16:18:08 GMT 1
Post by 17again on Apr 2, 2022 16:18:08 GMT 1
you know my rg250 is kinda like that pulling, you have to rev it.
i put it down to 28mm carbs for 125cc was to big a air movement.
Rg400
Apr 9, 2022 19:28:33 GMT 1
Post by stusco on Apr 9, 2022 19:28:33 GMT 1
Okay out today I’ve tried the airscrews no difference 😡its not as bad when its cold but when its warmed up if you get caught in the flat spot it just drones and cuts out,if im quick enough and pull the choke it pulls away,could this be floats causing fuel starvation as the pilot is the highest jet and the choke is at the bottom of the bowl?
Rg400
Apr 9, 2022 20:35:16 GMT 1
via mobile
Post by midlifecrisisrd on Apr 9, 2022 20:35:16 GMT 1
Sounds like it's lean at the bottom end
Go up one or 2 on pilot size
Post by stusco on Apr 9, 2022 20:39:57 GMT 1
Dave had bigger pilots in it but Dent has kept them it has 25’s fitted i think i have 30’s ill try them tomorrow,not ideal when its just back from getting a dyno set up
Rg400
Apr 10, 2022 12:35:28 GMT 1
Post by stusco on Apr 10, 2022 12:35:28 GMT 1
Just checked the float height and its 23mm so that means it will have less fuel in the bowl? But it has high flow ceramic ball fuel valves do these have a different float height? I set them to 17mm when I fitted them but they would leak on the side stand (the bike does lean over quit a lot)
Post by stusco on Apr 16, 2022 17:31:01 GMT 1
Reset all the carbs kept the 25 pilots as I found one choked (strange one choked pilot can stop a four cylinder) it still has the flat spot but can be driven through and avoided so alls good ,gave it some stick in a couple of gears today 😁👍now that’s what ive been looking for,starts to pull hard at 6 then really pulls at 8 when the pv closes ,i just need to put the fairing back on and roll on summer
Post by stusco on Jul 27, 2023 17:50:45 GMT 1
Update: Ive purchased a performance fabrications adjustable pickup after checking the timing it was 10 degree at tickover and 23 at half throttle its now 14 and 26 its running much better now and has really reduced the low down flat spot ,im running an ignitech now junked the zeel, its all been adjusted mechanically and not by the igi when i plug in the igi it says i have reverse polarity on the pickup or something like that I will take a screenshot next time i check
