Post by stusco on Sept 22, 2018 16:29:42 GMT 1
Here is my latest purchase some of you might know this bike ,if you do any info on its past would be great i hope I can put this in this section it will be getting a resto mod ,new pipes ,460 big bore and anything else I can afford,I might get a Barry Sheene paint job,any advice on upgrading the suspension?its got a nitron shock at the moment www.dropbox.com/s/lqbcckir1dh3viw/image1.jpeg?dl=0
Rg400
Sept 22, 2018 16:34:11 GMT 1
Post by dusty350 on Sept 22, 2018 16:34:11 GMT 1
Very nice A mate of mine had one from new, in Skoal Bandit colours. Mark Dent is one of the "goto" guys for these bikes. Does some pretty trick work with them. I look forward to your progress Dusty
Rg400
Sept 22, 2018 16:40:02 GMT 1
via mobile
Post by midlifecrisisrd on Sept 22, 2018 16:40:02 GMT 1
Very nice
You need to bring it round 😁
Rg400
Sept 22, 2018 16:40:20 GMT 1
Post by stusco on Sept 22, 2018 16:40:20 GMT 1
Cheers Dusty I’ve looked,at his site once I got my head round it’s four of everything the prices are no different to our lc bling the fairing is one of those Chinese jobbies and it’s a cover on the tank but it will be getting the tank painted properly at least
Post by jessy03 on Sept 22, 2018 17:20:33 GMT 1
Looks like nice rider, you will need some deep pockets for the engine, 2 cranks 4 pistons etc... Mark Dent is your man for these, as Dusty says. got the bigger brother, sadly hardly use it, keep trying to make my self use it but end up on the LC2 Good luck with the resto
Post by veg on Sept 22, 2018 17:36:14 GMT 1
Nice bike If it were mine I would do a Sheene rep like these I don’t think the early texaco colours work
Post by stusco on Sept 22, 2018 18:07:48 GMT 1
$250
Rg400
Sept 22, 2018 18:12:39 GMT 1
via mobile
Post by veg on Sept 22, 2018 18:12:39 GMT 1
Fan feckin tastic mate
Post by stusco on Sept 22, 2018 18:24:57 GMT 1
I need a manual took me 40 minutes to work out how to get the tank off ! Plugs are black that will be why it’s really sluggish below 4000 then it rips your arms off The frame has slight corrosion marks you can’t feel them with your finger nail but autosol doesn’t take them off anyone got a good answer,I don’t want it polished I like the standard finish
Rg400
Sept 22, 2018 18:55:02 GMT 1
Post by jessy03 on Sept 22, 2018 18:55:02 GMT 1
They like some revs to get them going
Rg400
Sept 22, 2018 19:00:41 GMT 1
via mobile
Post by veg on Sept 22, 2018 19:00:41 GMT 1
I had the same probs with my rg250 frame corrosion that affected the anodised finish I don’t think there is a great deal you can do about it. I’m sure someone will no doubt correct me 😀
Rg400
Sept 22, 2018 19:02:05 GMT 1
Post by stusco on Sept 22, 2018 19:02:05 GMT 1
I first drove it on Friday it pulled away fine when it hit the band it took off I was really impressed did about five miles then it started pissing down,got home was Erving it in the garage noticed the wet road outside my garage going all oily like it’s really rich anyway running like crap today and the plugs are black
Rg400
Sept 22, 2018 19:04:26 GMT 1
veg likes this
Post by stusco on Sept 22, 2018 19:04:26 GMT 1
I had the same probs with my rg250 frame corrosion that affected the anodised finish I don’t think there is a great deal you can do about it. I’m sure someone will no doubt correct me 😀 Is it anodised?i doesn’t look like it I’d better have another look when I’ve not been drinking (I am on holiday )
Post by Deleted on Sept 22, 2018 21:39:26 GMT 1
Bin the air snorkel Bin the trumpet gauze filters Go to 120 MJ Drop the needle a notch Air screws 1.5 turns out balance all 4 slides properly and adjust the oil pump drain the 2T tank and use fully synthetic tickover screws are different front and rear carbs Don't use iridium plugs good old B9ES Fuel tap leaks. use in line taps Float valves leak. Replace them and it will still leak. Put Grose float valves in, it will still leak 2T oil valves stick open, put a tray under the bike to catch the oil Centre crank bearing runs in gearbox oil. Change gearbox oil every 1000 miles 2nd and 6th gears explode. Change them Clutch slips and drags. You need the revised clutch shim Clutch slips when you use synthetic gear oil. Put old style 10w40 in (see above)
std front forks are sh!te replace with VJ22 or GSXR or better. You will need 25-50mm riser clip ons otherwise you will trap your thumbs std wheel sizes are sh!te GSXR400 front and rear are the simple upgrade std ride height is sh!te Ride height adjuster required and get the static sag correct. Chain will be hanging off at static sag and tight as a tight thing on full compression. The engine is in the wrong place compared to the swing arm pivot std gear change is sh!te get a shift shaft support and rear sets
That should get you going.....
Rg400
Sept 22, 2018 21:42:49 GMT 1
Post by stusco on Sept 22, 2018 21:42:49 GMT 1
Yep that will keep me going cheers
Post by Deleted on Sept 22, 2018 21:48:25 GMT 1
Don't rev it over 10,500 or it will destroy the cranks. Grampian are where MD sends his cranks (but gets a trade discount)
Before you know it it will sound like this
Rg400
Sept 22, 2018 21:52:09 GMT 1
Post by stusco on Sept 22, 2018 21:52:09 GMT 1
More good advice thanks
Rg400
Sept 23, 2018 1:53:48 GMT 1
Post by donkeychomp on Sept 23, 2018 1:53:48 GMT 1
Never ridden one but oddly I have just finished reading a bike mag from Dusty about your 400. Seems is was a better bike than the 500, lighter, more nimble and almost as fast. The factory tuning kits gave it bonkers power with top speeds way past the 150mph mark. Gotta go for Skoal Bandit colours as that just is the pups dongle dangles!
Rg400
Sept 23, 2018 7:09:36 GMT 1
via mobile
Post by Deleted on Sept 23, 2018 7:09:36 GMT 1
Never ridden one but oddly I have just finished reading a bike mag from Dusty about your 400. Seems is was a better bike than the 500, lighter, more nimble and almost as fast. The factory tuning kits gave it bonkers power with top speeds way past the 150mph mark. Gotta go for Skoal Bandit colours as that just is the pups dongle dangles! Alex The 400 produced much less power than the 500. Other than that they are almost identical. Fuel gauge, slightly different pipes and jetting and needles. Everything else is the same My 400 kicks out about 65bhp about the same as a well setup VJ22. My std 500 Is about 85bhp where as the lightly tuned one is about 95 and the proper one about 110.
Rg400
Sept 23, 2018 9:05:29 GMT 1
Post by stusco on Sept 23, 2018 9:05:29 GMT 1
I was really surprised how light it is it’s easier to push around than my lc it feels half the weight of a lc2
Rg400
Sept 23, 2018 17:24:20 GMT 1
Post by mouse on Sept 23, 2018 17:24:20 GMT 1
Stusco, that is a beauty, really like these, good luck with whatever you do to it
Mouse
Rg400
Sept 23, 2018 17:25:12 GMT 1
veg likes this
Post by mouse on Sept 23, 2018 17:25:12 GMT 1
Looks like nice rider, you will need some deep pockets for the engine, 2 cranks 4 pistons etc... Mark Dent is your man for these, as Dusty says. got the bigger brother, sadly hardly use it, keep trying to make my self use it but end up on the LC2 Good luck with the resto Love it! Don't want to sell it do you Jessy? Mouse
Rg400
Sept 25, 2018 20:36:30 GMT 1
via mobile
Post by brucie on Sept 25, 2018 20:36:30 GMT 1
Rg400
Sept 25, 2018 23:16:11 GMT 1
via mobile
Post by brucie on Sept 25, 2018 23:16:11 GMT 1
Fantastic bike your a lucky chap wish I had one
begbie
Rg400
Sept 25, 2018 23:35:52 GMT 1
Post by begbie on Sept 25, 2018 23:35:52 GMT 1
Never ridden one but oddly I have just finished reading a bike mag from Dusty about your 400. Seems is was a better bike than the 500, lighter, more nimble and almost as fast. The factory tuning kits gave it bonkers power with top speeds way past the 150mph mark. Gotta go for Skoal Bandit colours as that just is the pups dongle dangles! Alex The 400 produced much less power than the 500. Other than that they are almost identical. Fuel gauge, slightly different pipes and jetting and needles. Everything else is the same My 400 kicks out about 65bhp about the same as a well setup VJ22. My std 500 Is about 85bhp where as the lightly tuned one is about 95 and the proper one about 110. A stock 400 = 55 ish hp a stock 500 mid 70s hp
Post by stusco on Sept 28, 2018 15:18:31 GMT 1
Started stripping it today ,it’s a lot different to a lc !
Rg400
Sept 29, 2018 9:04:28 GMT 1
Post by mikee on Sept 29, 2018 9:04:28 GMT 1
Hammer impact wrench , not like an lc at all
Like your style 😀
Mike
Rg400
Sept 29, 2018 10:18:33 GMT 1
veg likes this
Post by stusco on Sept 29, 2018 10:18:33 GMT 1
Basic tools for a fitter ,the toffee hammer is not my usual choice but I thought I’d be delicate at first
Rg400
Oct 2, 2018 20:52:39 GMT 1
Post by philmill on Oct 2, 2018 20:52:39 GMT 1
$250 Is that one of those Chinese body kits? I've seen them for the RD500 and wondered if they were any good. Let me know what its like please. Phil
Rg400
Oct 2, 2018 20:55:39 GMT 1
Post by stusco on Oct 2, 2018 20:55:39 GMT 1
The one on mine is ok I’m not to fond of the tank as it’s a cover ,I was thinking about pulling it off and getting the tank painted ,or buy yellow set above
