Post by stusco on Feb 12, 2019 15:44:32 GMT 1
Got my wheels done Anyone got any recommendations for tyres
Rg400
Feb 12, 2019 15:53:42 GMT 1
Post by Mr Kipling on Feb 12, 2019 15:53:42 GMT 1
oh yeah , they look superb !!!
Rg400
Feb 12, 2019 15:55:16 GMT 1
Post by tacky1 on Feb 12, 2019 15:55:16 GMT 1
Very very nice job on the wheels...
Rg400
Feb 12, 2019 17:09:06 GMT 1
Post by Tobyjugs on Feb 12, 2019 17:09:06 GMT 1
That is very smart, seems a pity to put tyres on them.
Rg400
Feb 12, 2019 17:15:03 GMT 1
Post by philmill on Feb 12, 2019 17:15:03 GMT 1
Lovely, I like that gold, better than what got put on my wheels, is it powder or paint?
Phil
Rg400
Feb 12, 2019 18:21:37 GMT 1
Post by mouse on Feb 12, 2019 18:21:37 GMT 1
Beautttttttttttiful job on the wheels
Mouse
Rg400
Feb 12, 2019 18:22:11 GMT 1
Post by stusco on Feb 12, 2019 18:22:11 GMT 1
It’s powder coat the colour is ment to match Suzuki racing gold they are done in satin
Rg400
Feb 12, 2019 19:35:54 GMT 1
Post by Deleted on Feb 12, 2019 19:35:54 GMT 1
Rg400
Feb 12, 2019 19:40:52 GMT 1
Post by stusco on Feb 12, 2019 19:40:52 GMT 1
Thanks for that I took bt45’s off they looked horrendous
Rg400
Feb 12, 2019 20:42:46 GMT 1
Post by Deleted on Feb 12, 2019 20:42:46 GMT 1
The trick is to use GK71F wheels; exactly the same spoke pattern but a 110/70/17 front and 140/60/17 rear. They are rare but cheap. Sometime confused with the GK71H which had 3 spoke wheels. The earlier GK71B had 16" front and 18" rear but the same pattern as the RG. Caveat Emptor
Post by stusco on Feb 19, 2019 15:32:13 GMT 1
Got my plating back now thats£50 worth
Post by stusco on Feb 19, 2019 17:25:33 GMT 1
Why Ignore the bolt that was in the wrong box ,screwed them in by hand put the torque wrench on them they all go in except this one guess what it won’t go in or out😭
Rg400
Feb 19, 2019 17:39:56 GMT 1
via mobile
500RG likes this
Post by midlifecrisisrd on Feb 19, 2019 17:39:56 GMT 1
Oh Bugger
Must be something binding the thread
Get an Allen socket in it then heat the Allen socket with a blow lamp
The disc should shield the wheel from the heat but the Allen socket should transfer heat into the bolt and the thread
Hopefully will let it loosen off
Rg400
Feb 19, 2019 17:47:01 GMT 1
Post by 4l04ever on Feb 19, 2019 17:47:01 GMT 1
Put a hex bit socket in the bolt and give it a tap with a hammer. Might free it up.
Post by stusco on Feb 19, 2019 17:59:27 GMT 1
Phew
Post by stusco on Mar 3, 2019 14:59:42 GMT 1
Got my tyres fitted yesterday just need my swingarm back from Mark Dent and my fork internals from Maxton then the build can begin
Post by donkeychomp on Mar 3, 2019 23:50:18 GMT 1
Those wheels are astounding.
Post by stusco on Apr 4, 2019 16:12:02 GMT 1
Got these today after a lot of hassle,basically they advertise you can buy their cartridges and install them your self but they try every trick in the book to get you to send your forks to them so they can charge nearly £200 to install them ,they even asked if I had tools and if I knew how to rebuild a set of forks
Rg400
Apr 11, 2019 19:13:06 GMT 1
Post by stusco on Apr 11, 2019 19:13:06 GMT 1
The maxton saga continues,so looking for help ! it turns out that the rebound or tension damping is in the right fork leg and the compression or bump damping is in the left fork leg,but the only difference in the cartridges is one has an oil hole at the top and the other is in the bottom ,I’ve contacted maxton but had no reply, anyone have any knowledge on this so I can get them built and back on the bike
Rg400
Apr 11, 2019 19:21:45 GMT 1
via mobile
Post by veg on Apr 11, 2019 19:21:45 GMT 1
I don’t have the answer sorry but some companies seem to succeed despite themselves. In today’s social media world when piss poor customer service is reported on so quickly you would think they would think twice. Good luck with getting it sorted.
Post by Deleted on Apr 11, 2019 21:25:14 GMT 1
Thing is you chose to build them yourself. If you refused the offer, all be it at a price, for Maxton to do the work, then I'd say you are on your own. I have had people buy taps then phone me up for advice on fitting them. My reply is always do you want me to come and fit it, as I know they have had a go, failed, probably bolloxed something up and now when it doesn't work or leaks is suddenly my problem. I charge accordingly. Back to the fitting issue, I presume these are for std RG forks, with the antidive blanked off. If not then you need to remove the internals and adjust the amount of oil (upwards) to account for the increase in volume Check the manual (it's on my server) to see how the legs come apart, then simple reverse the process. I don't now what weight oil. what volume or air gap you would use. The fork legs are identical (apart from being left/right lowers) so it's irrelevant which one goes in which leg
Post by stusco on Apr 12, 2019 7:21:23 GMT 1
I chose to assemble them ,they have been altered they have supplied the oil and fitting and service instructions but there’s no markings to say which leg they go in where the instructions are leg specific. They offered a saving off £200 if I fit them myself it’s only a seal and a top bush plus the bottom cap screw only problem is which one is which it was still over £700 with the £200 off the least they could do is write L and R on the bag
Post by oldbritguy on Apr 12, 2019 9:43:59 GMT 1
Got my plating back now thats£50 worth Hi Stu Just noticed this and what a fantastic plating job. Did you get this done local as I am just at the other end of the M8 from you? I have used a firm in Livingston before and they were very good but I am not sure if they are still on the go. Cheers John
Post by stusco on Apr 12, 2019 12:51:10 GMT 1
Yes it was able plating in Livingston
Post by stusco on Apr 12, 2019 14:15:11 GMT 1
Problem solved maxton sent me a photo so alls well and jobs done i better take some photies
Post by stusco on Apr 15, 2019 16:47:27 GMT 1
Fitted my maxton upgraded forks and my braced swingarm today
Rg400
Apr 15, 2019 16:52:21 GMT 1
via mobile
Post by midlifecrisisrd on Apr 15, 2019 16:52:21 GMT 1
Fnarr🍆
Post by Mr Kipling on Apr 15, 2019 16:57:27 GMT 1
braced swinger looks Ace...
Rg400
Apr 15, 2019 17:02:05 GMT 1
Post by muttsnuts on Apr 15, 2019 17:02:05 GMT 1
braced swinger looks Ace... agree, does look well that
Rg400
Apr 16, 2019 17:00:38 GMT 1
Post by stusco on Apr 16, 2019 17:00:38 GMT 1
As my luck continues the swingarm has to to go back as the paddock stand bosses have been welded on in the wrong place I can’t fit the back wheel as the chain adjusters hit the bosses😩
