Post by stusco on Oct 5, 2018 21:22:17 GMT 1
Rg400
Oct 5, 2018 21:24:19 GMT 1
Post by marsbar350 on Oct 5, 2018 21:24:19 GMT 1
that's bad news stu have you contacted the seller? suppose it was running great when he had it
Rg400
Oct 5, 2018 21:30:34 GMT 1
via mobile
mikee likes this
Post by midlifecrisisrd on Oct 5, 2018 21:30:34 GMT 1
It does sound initially like bad news but if that's the worst thing you find you are doing ok
Post by stusco on Oct 5, 2018 21:32:54 GMT 1
I’ve not contacted him no point really he’ll just deny any knowledge,so I’ll just get on with it ,it’s getting a big bore kit anyway
Post by stusco on Oct 5, 2018 21:34:06 GMT 1
Strange seeing pistons without windows and small ends with thrust washers
Rg400
Oct 5, 2018 22:23:52 GMT 1
Post by marsbar350 on Oct 5, 2018 22:23:52 GMT 1
well I hope it aint too expensive good luck with it
Post by mikee on Oct 5, 2018 22:56:51 GMT 1
Get on with it , it’s only money
Mike
Rg400
Nov 3, 2018 18:29:57 GMT 1
Post by stusco on Nov 3, 2018 18:29:57 GMT 1
Anyone ever rebuilt a water pump on a RG 400/500 ?I’ve just changed the oil seal put it back together and it’s not a smooth as I would have liked both bearings are silky smooth the bevel gears look perfect but all together it feels notchy it’s all doweled so it can’t be out of line maybe it’s like that normally, any ideas?
Rg400
Nov 3, 2018 19:15:03 GMT 1
Post by mikee on Nov 3, 2018 19:15:03 GMT 1
Dod spence at IPF (Glenrothes) built one a couple of years ago might be worthwhile giving him a call
Mike
Rg400
Nov 3, 2018 19:28:49 GMT 1
Post by stusco on Nov 3, 2018 19:28:49 GMT 1
Dod spence at IPF (Glenrothes) built one a couple of years ago might be worthwhile giving him a call Mike I don’t know ipf where are they?
Rg400
Nov 3, 2018 19:30:39 GMT 1
Post by stusco on Nov 3, 2018 19:30:39 GMT 1
Dod spence at IPF (Glenrothes) built one a couple of years ago might be worthwhile giving him a call Mike I don’t know ipf where are they? Scratch that I know the guy he does my powder coating and welding
Rg400
Nov 3, 2018 21:52:22 GMT 1
Post by mikee on Nov 3, 2018 21:52:22 GMT 1
You in fife then ?
Mike
Rg400
Nov 3, 2018 22:21:38 GMT 1
Post by stusco on Nov 3, 2018 22:21:38 GMT 1
No I’m in south Queensferry I work in fife I in Glenrothes most days
Post by stusco on Nov 3, 2018 22:35:27 GMT 1
Had a message from Mark Dent ha says the water pump is like that
Post by stusco on Nov 8, 2018 17:26:32 GMT 1
Post by midlifecrisisrd on Nov 8, 2018 18:26:23 GMT 1
That's what happens when you buy a Suzuki 🤣🤣🤣
Rg400
Nov 8, 2018 19:00:14 GMT 1
Post by stusco on Nov 8, 2018 19:00:14 GMT 1
Got the answer from mark dent
Post by stusco on Nov 10, 2018 16:53:46 GMT 1
Anyone know of a safe way of cleaning this oil pump up
Rg400
Nov 25, 2018 14:46:48 GMT 1
Post by stusco on Nov 25, 2018 14:46:48 GMT 1
I had the same probs with my rg250 frame corrosion that affected the anodised finish I don’t think there is a great deal you can do about it. I’m sure someone will no doubt correct me 😀 I just got a quote for stripping the anodised finish then I prepare the frame then they will reanodise it in what ever colour I want £60 a bargain I think. i might go for black or gun metal
Rg400
Nov 25, 2018 15:07:52 GMT 1
via mobile
Post by veg on Nov 25, 2018 15:07:52 GMT 1
Bloody hell that is cheap have they done them before?
Rg400
Nov 25, 2018 15:22:55 GMT 1
veg likes this
Post by stusco on Nov 25, 2018 15:22:55 GMT 1
When I visited on Friday they said they had just done a motorcycle frame but I never saw it ,they are good platers Able platers in Livingston Midlifecrisisrd uses them regularly,I’ve never had anything anodised before Maybe I’ll ask Steve’s opinion first I’m sure he’s had stuff done
Rg400
Nov 25, 2018 16:07:44 GMT 1
via mobile
Post by veg on Nov 25, 2018 16:07:44 GMT 1
Cheap and recommended don’t get much better than that 👍
Rg400
Nov 25, 2018 16:10:00 GMT 1
Post by mikee on Nov 25, 2018 16:10:00 GMT 1
My mate Pete got some stuff done there for his tz and Mito , seemed okay Used to use serenco in Glenrothes years ago , always did a good job Used a place in Dalkeith through work too top quality work , Lothian engineering or summat like that
Mike
Rg400
Nov 25, 2018 16:13:55 GMT 1
Post by mikee on Nov 25, 2018 16:13:55 GMT 1
Stu If you get any colour other than clear you might get dis-colouration on the welds relative to the frame Just a thought
Mike
Rg400
Nov 25, 2018 17:01:19 GMT 1
Post by stusco on Nov 25, 2018 17:01:19 GMT 1
Cheers for that I might just polish the frame after the anodising is removed
Rg400
Nov 25, 2018 17:18:08 GMT 1
via mobile
Post by midlifecrisisrd on Nov 25, 2018 17:18:08 GMT 1
When I visited on Friday they said they had just done a motorcycle frame but I never saw it ,they are good platers Able platers in Livingston Midlifecrisisrd uses them regularly,I’ve never had anything anodised before Maybe I’ll ask Steve’s opinion first I’m sure he’s had stuff done There main business is anodising so he knows his stuff. I've had some smaller bits done and they were good. He has warned that some materials take the colour different so if you have a part with billet, cast and weld sections it can shade differently. Clear or silver for me. You can only try as they can easily remove it again. He has said he can change my blue spots to red Steve
Rg400
Nov 25, 2018 18:03:45 GMT 1
Post by stusco on Nov 25, 2018 18:03:45 GMT 1
Cheers Steve I’ll get the old stuff stripped then decide what I’ll do next
Rg400
Nov 25, 2018 19:32:17 GMT 1
via mobile
Post by veg on Nov 25, 2018 19:32:17 GMT 1
I was warned that where the anodising had tarnished previously that it would always tarnish even when renewed, if you aren’t doing a concourse Reston I would not worry too much about it .
Rg400
Nov 25, 2018 19:43:17 GMT 1
Post by stusco on Nov 25, 2018 19:43:17 GMT 1
It’s more a resto mod so anything goes I can’t leave the frame like that it spoils the bike for me anyway so illl take it to the plater and see what he can do
Rg400
Nov 25, 2018 20:11:07 GMT 1
via mobile
Post by midlifecrisisrd on Nov 25, 2018 20:11:07 GMT 1
Yes if there is any corrosion spots they will need rubbed back till the surface is perfect
I got a set of caliper brackets done that had spots and black had grey defects
