Rg400
Mar 2, 2020 21:57:16 GMT 1
Post by mak595 on Mar 2, 2020 21:57:16 GMT 1
Awesome
Rg400
Mar 7, 2020 23:08:02 GMT 1
Post by stusco on Mar 7, 2020 23:08:02 GMT 1
Had a run round the block it likes it better on the choke what does that mean?
Rg400
Mar 7, 2020 23:16:58 GMT 1
via mobile
stusco likes this
Post by Deleted on Mar 7, 2020 23:16:58 GMT 1
You’ve got the wrong pilot jets and the needle is in the wrong clip. The higher up ie lower clip the richer it is drop the needle to the 2nd from top Also you need to adjust the air screws as that controls the slow speed
Jetting an RG can take a long time to get correct. The 400 needs different setting up to the 500
I think mine took about a year to get right !!
Rg400
Mar 7, 2020 23:26:06 GMT 1
Post by stusco on Mar 7, 2020 23:26:06 GMT 1
Cheers I thought it would be a pain ,I was hoping for a quick fix😣
Rg400
Mar 8, 2020 10:03:05 GMT 1
Post by Deleted on Mar 8, 2020 10:03:05 GMT 1
It's long winded Take the side fairings off and put them somewhere safe. New air filter Remove the snorkel in the top of the air box Remove the mesh filters between the trumpets and the air box Set float heights New B9ES plugs go up 2 sizes on the pilot jets If it starts without choke you are probably somewhere near on the pilot jet. Wind the air screw all the way in then back out 1/2 a turn Rev the engine gently from pick up/ride round the block at tick over. You need to get it to pick up from tickover to about when the rev counter shows about 3-4k Wind the air screw out 1/4 turn until it's picking up. If you get to 3 full turns then you need to alter the pilot jet Repeat until it picks ups from zilch On a 400 the MJ std is 135. Drop it to 120 Start the needle on the middle clip Get the engine to pickup between 4-8k by adjusting the needle up/down. There is a 1/2 shim under the clip. If need be remove this if you get close to being spot on to give the final adjustment Put some new plugs in and go for a proper ride. If it's pulling to the red line you are nearly there. As the PV closes at about 8k everything changes on the jetting. The motor now starts to use the pipe. If its a bit rich then 115's if it's a bit squeaky bum 125 If all seems OK put the old plugs in and do a final plug chop, If U R very appy with D byke you're done. Put some new B9ES plugs in and give it one last test Put the fairings on
Next buy a zeeltronic CDI and PV controller and start again :-)
Rg400
Mar 8, 2020 10:37:13 GMT 1
Post by stusco on Mar 8, 2020 10:37:13 GMT 1
Cheers for the info I’ve already got the Zeel and dents air filters
Rg400
Mar 8, 2020 11:18:10 GMT 1
Post by Deleted on Mar 8, 2020 11:18:10 GMT 1
Sorry Stu you are on your own on that one.
I tried and tried with ITG filters. Road RG's need an air box. Others have also reverted to the air box to get some sort of decent mid range. Race RG's and the 570 need to breath. Road bikes don't need to as much. Unless you are constantly revving the nuts off it it (keeping it about 8k with the PV shut), it will be pants. That usage also makes the low down carburation completely redundant and early crank replacement a must. The air box restores some of that bottom end that the high flow filters take away
The 400 will make about 59ish bhp if you are lucky. They aren't the most potent motor
With Dent filters you need to start at about 250-270 main jets. The 400 just doesn't have the crank case pumping volume to suck on the smaller jets. Pilots will be what ever it is. Ditto the air screws. I don't think the needles will make any difference (400 or 500)
There are quite a few ignition maps I posted up for the RG, over on the RGV250 forum
Good luck
Rg400
Mar 8, 2020 11:24:15 GMT 1
Post by stusco on Mar 8, 2020 11:24:15 GMT 1
Cheers ,I guess I will be spending lot of time with the fairings off
Rg400
Mar 8, 2020 12:33:30 GMT 1
Post by Deleted on Mar 8, 2020 12:33:30 GMT 1
I guess you will. TBH that's why I sort the engine and suspension out first, then (if I can be bothered) the paint work last. The last thing you want is all show and no go :-)
Rg400
Mar 8, 2020 12:36:20 GMT 1
Post by stusco on Mar 8, 2020 12:36:20 GMT 1
I agree but my painter kept my bike for 5 1/2 months so I couldn’t sort out all the niggles over the winter
Rg400
Mar 18, 2020 17:53:24 GMT 1
Post by stusco on Mar 18, 2020 17:53:24 GMT 1
I’ve got the jetting sorted 230 main and 30 pilot ,so I’ve drove it up and down the road and the brakes feel wooden they work ok but have no feel ,it’s like you have no idea when it going to lock up,I believe it has a rgv 250 master cylinder with standard calipers ,I refurbish all of them and now I wish i hadn’t. Anyone a decent upgrade for standard wheels and forks?
Rg400
Mar 18, 2020 17:57:45 GMT 1
via mobile
Post by midlifecrisisrd on Mar 18, 2020 17:57:45 GMT 1
I take it you fitted new pads to used discs
May take a while to bed in
On the rz250 I fitted new pads to vapoured discs. They were shocking at first. Even after 30 miles They were improving but still not perfect
Post by stusco on Mar 18, 2020 18:25:18 GMT 1
Aye new pads to an old disc ,I’m now having deja vu I had to buy new discs for my lc for this very reason
Post by Deleted on Mar 18, 2020 18:58:18 GMT 1
The std. calipers are a bit pants. IIRC the RGV master cylinder is a 5/8" or 16mm. Cheapest upgrade I chose was to use a master cylinder from the original fireblade as it comes with the reservoir and bracket. The best FVM radial is a Frando by Venhil. Sometimes you just have to try different capacity master cylinders until you get the right feel
Post by stusco on Jul 2, 2021 15:53:18 GMT 1
Some Mark Dent magic
Post by midlifecrisisrd on Jul 2, 2021 17:04:16 GMT 1
Yummy, yummy 😋
Now stop wasting time and get them fitted 🤣
Post by stusco on Jul 2, 2021 17:04:59 GMT 1
Im on it😅
Post by stusco on Jul 4, 2021 14:06:47 GMT 1
Fitted the altered disc valves and barrels ! Ive fitted a few barrels in my time but the ones on the rg are a pain in the arse ,the skirt on the liner doesn’t do very good job off compressing the rings
Rg400
Jul 18, 2021 10:35:17 GMT 1
Post by 17again on Jul 18, 2021 10:35:17 GMT 1
Some Mark Dent magic machined to 500? 570cc? + tuned? will have to take mine of soon ish
Post by stusco on Jul 18, 2021 10:37:50 GMT 1
Just 460 and tuned hopefully test drive today
Rg400
Jul 22, 2021 17:23:56 GMT 1
Post by 17again on Jul 22, 2021 17:23:56 GMT 1
Just 460 and tuned hopefully test drive today oh i see you had the exhaust ports opened to work better with the pipes. how did it go?
Post by stusco on Jul 22, 2021 17:31:41 GMT 1
It definitely pulls hard now but as you know the jetting is a pain its just about right but needs a smaller pilot i think
Rg400
Jul 22, 2021 19:06:33 GMT 1
via mobile
Post by Tobyjugs on Jul 22, 2021 19:06:33 GMT 1
It definitely pulls hard now but as you know the jetting is a pain its just about right but needs a smaller pilot i think Are you now satisfied? It's a great looking bike.
Post by stusco on Jul 22, 2021 19:41:55 GMT 1
Once its jetted and mapped (zeel) ill be satisfied its too expensive to nip up😬
Rg400
Jul 23, 2021 17:19:36 GMT 1
Post by 17again on Jul 23, 2021 17:19:36 GMT 1
It definitely pulls hard now but as you know the jetting is a pain its just about right but needs a smaller pilot i think sound like you are on the right road now stu
Rg400
Jul 24, 2021 10:05:31 GMT 1
Post by muttsnuts on Jul 24, 2021 10:05:31 GMT 1
Hi Stu, any luck with the zeel, had another one a few weeks back, same issue as yours, swapped it for another one, seems ok at the moment, but I've lost all confidence in them recently, I even bought a new laptop and downloaded the latest software just in case it was something funny with my laptop, but nope, still seeing the same issue as your's had - something very odd going on
But, I've also had a few others in with no issues, oddly enough, those zeels where all about 5 years old or older speaking to the customers, so not sure if that's anything to go by
Rg400
Jul 24, 2021 11:09:30 GMT 1
Post by stusco on Jul 24, 2021 11:09:30 GMT 1
Hi Dave it seems to be behaving itself at the moment but I don’t really trust it anymore,was it a rg with a zeel?
Rg400
Jul 24, 2021 11:43:22 GMT 1
Post by muttsnuts on Jul 24, 2021 11:43:22 GMT 1
yeah, an RG500 with the 2 units like yours, it had done the same thing, double counting the RPM/sparks, so would only rev to around 6/6.5k before hitting the rev limiter, only good thing was I pretty much knew within 5 mins what the fault was, I tried to reset the sparks setting, but it wouldn't let me, de-ja-vue sprung to mind !
Rg400
Jul 24, 2021 13:11:47 GMT 1
Post by stusco on Jul 24, 2021 13:11:47 GMT 1
And Borat has never had any problems 🤥
Post by stusco on Jan 21, 2022 18:45:25 GMT 1
Got some new brakes for the gamma should make a difference
