Post by stusco on Apr 11, 2015 22:24:36 GMT 1
F1 's are the bollocks
Post by stumpy on Apr 12, 2015 11:57:45 GMT 1
Looking good kostas, did you get the powervalve problem sorted, I have the same problem, servo motor spinning once waits a couple of seconds then spins completely again, I found your thread on it but no answer.Thanks
Post by kostas on Apr 12, 2015 15:09:58 GMT 1
Looking good kostas, did you get the powervalve problem sorted, I have the same problem, servo motor spinning once waits a couple of seconds then spins completely again, I found your thread on it but no answer.Thanks It was the controller that was shot. Cheers Kostas
Post by stumpy on Apr 12, 2015 17:28:43 GMT 1
Thanks Kostas, need to look on eBay then, thanks
Post by elliottles on Apr 21, 2015 17:35:19 GMT 1
hi Kostas,
me again, think I solved the clutch problem, been riding mine around and noticed that when I coast down a short local hill with the bike in gear and the clutch pulled all the way in, it still pushes the revs up a little. so now I know for sure that the clutch is dragging slightly!. because when I switch the engine off at standstill I also can pull the bike into neutral with my finger.
I think a brand new clutch will take a while to bed in before it can be adjusted properly.
cheers les
Post by kostas on Apr 21, 2015 20:24:18 GMT 1
hi Kostas,
cheers les I think the clutch will drag if you have wear (grooves) on the clutch basket also, causing the plates to catch on the grooves and not release as they should. In any case my approach is to ride and have the clutch bed in also. Cheers Kostas
Post by sp885 on Apr 21, 2015 21:09:02 GMT 1
Looking good
2taol
Post by 2taol on Apr 24, 2015 15:45:22 GMT 1
great build!
love the DIY painting and coating
Well done
Post by lcyoungboy on Apr 30, 2015 19:46:01 GMT 1
Read through the build..you have done an amazing job on it..I am picking up an f1 tomorrow..says it's mostly original With 33000 miles..hope it's not a basketcase..Will be using your thread as a guide..thanks
Post by kostas on May 1, 2015 18:47:03 GMT 1
Read through the build..you have done an amazing job on it..I am picking up an f1 tomorrow..says it's mostly original With 33000 miles..hope it's not a basketcase..Will be using your thread as a guide..thanks Thank you lcyoungboy. 33000 miles is not far from mine which has 57000 klm. Put a thread up with your build and good luck with it, I hope yours is better than mine.
Post by kostas on May 2, 2015 17:13:30 GMT 1
Post by toneless on May 6, 2015 12:42:32 GMT 1
Very nice work Kosta and plenty of room for more projects... I hope you'll enjoy it.
popeye
Post by popeye on May 13, 2015 7:39:56 GMT 1
Hi Kostas, considering there is an economic crisis it certainly hasn't got you down,excellent build quality.
Post by kostas on May 17, 2015 19:38:39 GMT 1
Post by skydemon on May 17, 2015 19:48:58 GMT 1
Hey Kostas. That bike is looking proper mint now. A testament to your hard work and attention to detail. Well done
Post by mercwagonman on May 17, 2015 20:47:40 GMT 1
looks great...Inspired to get on with mine!
Post by kostas on May 30, 2015 19:01:44 GMT 1
tezrhc
Post by tezrhc on May 30, 2015 21:10:22 GMT 1
A job well done Kostas,looks great. on to the next project?
Post by copper99 on May 31, 2015 11:06:40 GMT 1
Great work Kostas,she looks brilliant...well worth the wait eh?
Post by kostas on May 31, 2015 14:46:56 GMT 1
Well worth it mate. Time to ride it now for the rest of the summer..
Next up an RGV 250
Kostas
Post by stumpy on May 31, 2015 16:04:41 GMT 1
Looks good kostas
Post by arrow on May 31, 2015 17:57:37 GMT 1
Looks fantastic, well done. Enjoy.
Post by kostas on Oct 6, 2015 19:46:55 GMT 1
So finally after riding the bike for 700 klm the last 3 months I got around to fit the missing parts Fork decals IMG_0081 by k.apostolopoulos, on Flickr Vin plate! IMG_0082 by k.apostolopoulos, on Flickr Chain guard decal IMG_0083 by k.apostolopoulos, on Flickr Fitted a new R/H frame infill under the tank and I can now say that the bike is finished! During these 700 klm I realized that it takes some work to keep it clean and running as it should, so I have left the spanners out! Having finished my man lab I now have my pride in my dry and heated basement so when I'm to busy to ride I go sit and just look at it for half an hour. IMG_0086 by k.apostolopoulos, on Flickr Thank you all for your comments and for following my built, From this: IMG_0085 by k.apostolopoulos, on Flickr To this: IMG_0084 by k.apostolopoulos, on Flickr Kostas
Post by unrealedd on Oct 6, 2015 21:20:52 GMT 1
Top draw job and credit where its due that is a stunner. Good to hear she has a place in your house.
Post by copper99 on Oct 6, 2015 22:10:23 GMT 1
Shes a beauty Kostas, you should be very proud of all your hard work.
Post by kostas on Oct 30, 2017 20:39:28 GMT 1
Took the time to change all the picture links from photobucket to Flickr.
Hate to see all that work just disappear.
Kostas
Post by JonW on Nov 3, 2017 12:18:07 GMT 1
wonderful! beautiful bike Kostas!
Post by skydemon on Nov 3, 2017 13:30:48 GMT 1
Beautiful bike with beautiful vistas ❤️
Post by abar121 on Nov 8, 2017 23:28:49 GMT 1
Geia sou Kostas. Love the 31k. You have done a fantastic job.
I'm doing a blue and white one at the moment.
Cheers.
Post by plumma on Nov 9, 2017 22:25:52 GMT 1
Nice, well done!!
