Post by spacejunkie on Oct 28, 2014 8:33:15 GMT 1
Looking good...
Post by kostas on Oct 28, 2014 16:17:17 GMT 1
Again thanks for the commends... Super happy today!! Fired up the engine Gave it 10 kicks and it would not start then I thought to pull the choke out, and it started first kick Here is a video of it running, Cannot figure how to get a decent quality video up, this one looks crap but the sound is there One thing I notice is that it does not smoke from the exhausts?? Running 30:1 premix. Gastrol TTS. Barely run it for 2 or 3 minutes... Pump not bled yet. What do you think??
Post by kostas on Oct 28, 2014 17:21:08 GMT 1
Post by copper99 on Oct 29, 2014 21:03:14 GMT 1
Sounds and looks very sweet mate, I believe 30:1 is what many people run them at, it wouldnt have lasted 2 or 2 minutes if it wasnt getitng enough, im not expert at premix thou, ive always run the pump, bleed it up and away you go(assuming Arrow did refurb your pump?!..)
Post by kostas on Oct 30, 2014 20:25:44 GMT 1
Sounds and looks very sweet mate, I believe 30:1 is what many people run them at, it wouldnt have lasted 2 or 2 minutes if it wasnt getitng enough, im not expert at premix thou, ive always run the pump, bleed it up and away you go(assuming Arrow did refurb your pump?!..) Thanks copper, I just did not get the "smokes like a train" coming out of the exhausts. But figured out what I did wrong, bled the pump from the bleed screw and as soon as I got oil coming out steadily I stopped. I should have let it some more time to get the pipes to the cylinders full with oil. It is an Arrow rebuild pump so there should be no issues. Kostas
Post by greasemeup on Oct 31, 2014 10:14:30 GMT 1
The garage floor looks clean enough to eat off. Good job on the bike too.
Post by kostas on Jan 3, 2015 22:57:34 GMT 1
It has been a while since my last update but I have moved forward a bit, So had an issue withe the voltage output which proved to be the bloody multimeter, i have prepared the fairings/plastics for paint From this IMG_1906 by k.apostolopoulos, on Flickr To this IMG_2833 by k.apostolopoulos, on Flickr I had to remove the brake master cylinder to replace the sight glass as it was leaking IMG_2922 by k.apostolopoulos, on Flickr Not finished with this yet.. I also replaced the main jets to 240 as the carbs were fitted with 200s, the bike runs really sweet so I'm very happy with it. Here is who it looks now IMG_2835 by k.apostolopoulos, on Flickr IMG_2822 by k.apostolopoulos, on Flickr IMG_0064 by k.apostolopoulos, on Flickr Kostas
Post by 1966baz on Jan 4, 2015 11:25:50 GMT 1
Looking good Kostas, good to see the project again.
Post by copper99 on Jan 4, 2015 17:46:00 GMT 1
That it is Baz..quality work as always Kostas, not that far off now then.
Say hello to Kostas2 for us!
Post by fatfreddy on Jan 4, 2015 18:01:39 GMT 1
Looks nice!
Post by kostas on Jan 4, 2015 20:48:55 GMT 1
That it is Baz..quality work as always Kostas, not that far off now then. Say hello to Kostas2 for us! Will do Bryan, Not far off now.. Brakes, fairings, drivers license and I'm ready to go!! Kostas
Post by thepetros67 on Jan 4, 2015 20:59:40 GMT 1
Looks TOP condition Kostas.
I appreciate your efforts for this project.
Petros
Post by kennyroberts on Jan 12, 2015 14:51:34 GMT 1
Looking great Kostas, can't wait to see the bodywork on it.. You are so close now. You are beating me to the finish line.
Post by kostas on Jan 17, 2015 17:01:03 GMT 1
Thanks for the comments.. The seat bottom was damaged from the wheel eating thru it and the mudguard and it was dirty as s**t IMG_0052 by k.apostolopoulos, on Flickr Can't afford a good used one at the moment and as the cover is good enought I had this cleaned and I glued a plastic patch on. IMG_0053 by k.apostolopoulos, on Flickr Not good as new but will do for now. I also fitted the fairings on with a couple of screws to check that all align before they get to paint. IMG_0056 by k.apostolopoulos, on Flickr IMG_0055 by k.apostolopoulos, on Flickr IMG_0054 by k.apostolopoulos, on Flickr Looks good. Kostas
Post by jessy03 on Jan 17, 2015 17:19:44 GMT 1
Looking good, soon be finished. Jess
Post by kostas on Jan 24, 2015 21:34:23 GMT 1
A small step forward, Fitted the new master cylinder sight glass, IMG_0057 by k.apostolopoulos, on Flickr Got he glass from eBay, nice kit only issue is that the glass is thin and sits on the bottom of the bore, so it doesn't look like the real deal. Dropped the bodywork to the painter today. Cheers Kostas
Post by copper99 on Apr 4, 2015 16:05:30 GMT 1
A small step forward, Fitted the new master cylinder sight glass, Got he glass from eBay, nice kit only issue is that the glass is thin and sits on the bottom of the bore, so it doesn't look like the real deal. Dropped the bodywork to the painter today. Cheers Kostas Hi Kostas, anymore done in the last couple of months mate?
Post by kostas on Apr 4, 2015 17:52:03 GMT 1
Hello Bryan,
Having problems making the brakes work.. There is no air in the system and I get pressure build up but both are soft. I can pull the fwd almost all the way back. I think I have to order a set of new high press brake lines.
I'm still waiting for the painter to finish the bodywork (2 months now) but I went on a ride with it today!!
So here is what I found out 1. Impossible to find neutral with engine running at a standstill 2. Leaks from R/H exhaust gasket 3. Leaks from the neutral switch cover 4. Brakes are crap But 1. Goes thru all the gears easily while running 2. Starts first kick every time 3. Looks to have lots if power, no hesitation and the revs pick up nicely 4. Sounds and smells sweet
I think I will be 99% ready by the end of April. Summer is already here so I can't wait to hit the road!
Cheers
Post by bazzer5115 on Apr 4, 2015 22:16:57 GMT 1
In the past when I had poor spongy brakes after lots of bleeding,I have put pressure on lever with a cable tie over night and in the morning perfect brakes! May work for you! Thanks for offer of gearbox parts,I will give you details of what I need to make my gearbox good. Baz
Post by sp885 on Apr 4, 2015 22:51:02 GMT 1
When I bought my 82 350LC 6 months ago the front brake was terrible, you could pull the lever in almost to the handlebars, bleeding it didn't do anything, biggest problem was the 33 year old original rubber brake lines, you could see them flexing when you pulled the lever, I tossed up getting a new pattern set of rubber lines, as gen Yam ones are NLA I believe, but decided to get a set of stainless Goodridge lines for it, this was a big improvement, the pads that are in it are only about a 1/4 worn and I have just got a set of the sintered race pads from Norbo that everyone seems to recommend, I will put these on in the next few weeks and see if it's any better Steve
Post by kostas on Apr 5, 2015 17:52:05 GMT 1
In the past when I had poor spongy brakes after lots of bleeding,I have put pressure on lever with a cable tie over night and in the morning perfect brakes! May work for you! Thanks for offer of gearbox parts,I will give you details of what I need to make my gearbox good. Baz Hi Baz, Already tried the cable tie trick and did not help much.. I can see and feel the brake lines flex under pressure so I think new ones is the way to go.. Let me know what you need from the gearbox.. Kostas
Post by elliottles on Apr 5, 2015 22:13:23 GMT 1
hi
now I get why its an "economic crisis rd"!! you blew the cash on a helicopter and a go cart!!
cheers les
Post by kostas on Apr 6, 2015 19:59:42 GMT 1
hi
cheers les LOL I never seem to have too many toys!!! I need to find someone to fund all this... offers / donations accepted! Kostas
Post by elliottles on Apr 6, 2015 21:19:28 GMT 1
hi Kostas,
glad you can see the funny side. on a serious note, I just finished a build and I am also not able to select neutral at standstill with the engine running, although all gears are fine when moving.
please let me know if you find a solution! I have been through everything and the nearest I have got is that it is clutch related, maybe the centre bush with too much play and wont disengage the clutch cleanly.
cheers again les ireland
Post by kostas on Apr 7, 2015 6:20:24 GMT 1
I think it is all about getting the offset bolt adjusted correctly, not having wear at the clutch basket grooves, or even fitting back the clutch rubber washers as originally were fitted.
My clutch bush is like new.. No play at all, the basket has light grooves. Weird thing is that the shift lever if completely stuck when the engine is running. As soon as I switch off the engine I can find neutral just pulling the lever with one finger.
I can't take the engine e apart again, I just want to ride the bike for the summer and enjoy, that's a very common problem we have, I will just find neutral as I coast down and sort this out next year.
Life is too short to worry about little things like that!!
Post by elliottles on Apr 7, 2015 8:34:00 GMT 1
could not agree more, enjoy your summer!! les
Post by copper99 on Apr 8, 2015 9:08:37 GMT 1
Well, wee niggles aside, not that far off mate.
Post by kostas on Apr 8, 2015 19:44:06 GMT 1
Well got most of the bodywork back. Here I'd the tank IMG_0058 by k.apostolopoulos, on Flickr Top quality job as far as paint finish. As for decal positioning I expect the decal police to be all over me any time soon!! Kostas
Post by copper99 on Apr 8, 2015 22:20:13 GMT 1
Wow...looks a quality job to me mate.
Post by kostas on Apr 11, 2015 21:14:23 GMT 1
