Post by kostas on Feb 2, 2013 18:45:00 GMT 1
Hi all, Been away in Turkey for a few days so did not have much done, Got my nuts and bolts cleaned and plated, will it qualify for a full nut and bolt rebuild now? IMG_1279 by k.apostolopoulos, on Flickr Came out very bright gold, so I maybe blast some and have those done again, not sure yet Got the swingarm seals, bushings fitted, first parts that come together again IMG_0037 by k.apostolopoulos, on Flickr and started cleaning my wiring, which will take some time and I hope when complete all swiches do what they suppose to do.. IMG_0038 by k.apostolopoulos, on Flickr Have not touched my engine yet.. I'm afraid of what I find inside, I just noticed that there is some play at the flywheel side of the crankshaft. Bearings must be shoot Cheers Kostas
Post by marsbar350 on Feb 2, 2013 18:50:39 GMT 1
phil
Post by phil on Feb 2, 2013 20:10:18 GMT 1
looking good keep up the good work!
Post by kostas on Feb 10, 2013 19:00:48 GMT 1
Post by kostas on Mar 3, 2013 18:42:57 GMT 1
Post by marsbar350 on Mar 3, 2013 18:46:55 GMT 1
you will get it ready for summer kostas ;D remember it lasts 10 months in greece
Post by copper99 on Mar 9, 2013 20:53:10 GMT 1
Looking good mate, you've done a fair bit in a short time.
Post by billy on Mar 9, 2013 23:22:34 GMT 1
Whaaaat? Damn bro, you're almost at the finish line now. You'll make it if you just keep putting some work into it! Piece by piece, don't give up! Don't think about time pressure, JUST DO IT. Do something every day (or as often as you can) without stressing it. You'll be surprised at how much you can do in, let's say 1 month, if you JUST DO IT.
Post by kostas on Mar 10, 2013 19:00:18 GMT 1
Thanks for the support guys, I have two demons in my head, one says to finish it and ride it and the other one to be patient and take it slow to do it propertly. I assembled the chasis with the wheels to see some results, Im very happy with the result so far IMG_1396 by k.apostolopoulos, on Flickr IMG_1398 by k.apostolopoulos, on Flickr fitted the rear wheel.. IMG_1401 by k.apostolopoulos, on Flickr steering bearings with re-cromed cover IMG_1402 by k.apostolopoulos, on Flickr Top and lower steering yokes with re-cromed top yoke bolt IMG_1404 by k.apostolopoulos, on Flickr and finaly forks, wheel and clip-ons IMG_1404 by k.apostolopoulos, on Flickr IMG_1428 by k.apostolopoulos, on Flickr Then I just sat there and look at the thing for an hour Hope you like it!!
saftie
Post by saftie on Mar 10, 2013 21:24:11 GMT 1
Kostas that is really starting to look special now, loving all photo's as well keep up the good work it is worth it. regards from a bitterly cold England.
Post by kostas on Mar 25, 2013 12:49:58 GMT 1
Hi from sunny Greece, Latest report, I have been striping and clening my brake calipers, thank god the pistons are looking good so will only need the seals also shotblasted and primed some more bits and started fitting parts on the frame. Calipers IMG_0043 by k.apostolopoulos, on Flickr Tail-light mount IMG_0042 by k.apostolopoulos, on Flickr Powervalve controller cleaned and installed IMG_0045 by k.apostolopoulos, on Flickr Coming back together,, the fun starts now Kostas
Post by kostas on Apr 8, 2013 21:27:21 GMT 1
Update, Summer is here for good, short sleeve T-shirts, but no bike to ride Got the primed parts painted satin black, also got some parts from Norbo and competed the brake calipers rebuild IMG_1461 by k.apostolopoulos, on Flickr IMG_1462 by k.apostolopoulos, on Flickr Got the frond brake master cylinder cleaned painted and fitted, IMG_1463 by k.apostolopoulos, on Flickr And I finished polishing the footrest hangers, installed re-cromed footpegs and cleaned the rubbers IMG_1470 by k.apostolopoulos, on Flickr More to follow! Strugling to keep up with work so progress is slow. Cheers Kostas
Post by fatfastroger on Apr 8, 2013 21:46:47 GMT 1
Looking great, giving me inspiration and motivation to get on with my 31K. The satin black stuff looks good, is it rattle can ?
Post by flames on Apr 8, 2013 22:21:08 GMT 1
you are doing a fantastic job mate.......and you must be the only person ive heard of,who's bike has a helicopter parked next to it in the garage.excellant.
Post by kostas on Apr 9, 2013 19:47:41 GMT 1
Hi fatfastroger, All paint job done with Sikkens premium quality car paints. There is a black coat and then satin clear laquer on top. Done with spray gun, I just hate how rattle can paint fades over time. I'm planning to paint the bodywork by myself also. Only thing I outsourced so far was the frame powder coating and welding I find my bike much more exciting than the helicopter parked next to it ;D
Post by tigermac on Apr 27, 2013 10:39:07 GMT 1
Awesome work!
Post by deanord on Apr 27, 2013 19:36:20 GMT 1
Hey Kostas, great build so far! I'm a little behind you with my F2 Hybrid build.. work and women seem to be more demanding!
a few posts earlier you show your seat lock - how did you get the lock barrel out of the body? i cant see how to do it?
I'm in the same boat - screwdrivered lock...
thanks in advance
Post by butchers on Apr 27, 2013 20:10:45 GMT 1
Hey Kostas, great build so far! I'm a little behind you with my F2 Hybrid build.. work and women seem to be more demanding! a few posts earlier you show your seat lock - how did you get the lock barrel out of the body? i cant see how to do it? I'm in the same boat - screwdrivered lock... thanks in advance here ya go mate first remove the cover plate and remove the round disc type plate then you will see this you will see 2 lick "eres"at 11 and 1 oclock you can just see them in the pic. using a small tool depress them inwards. Then using your thumb push the lock set from the opposite end outwards like so good luck
Post by deanord on Apr 28, 2013 11:43:26 GMT 1
cheers butchers - still got those locks you sent me and finally got around to having a play!!
Post by kostas on Apr 29, 2013 19:33:24 GMT 1
That's the way to get that hub out, wish there was a similar to get it off the plastic petrol cap, The release clip is out of reach in there.
Have done some more work on the bike but been to busy to post some pictures. Also I fell in love with a mint KR1-S last sunday.. Been a couple of decades since I've seen one up close, and this was a piece of art.
So I have to finish my beauty and hit the streets fast!
Kistas
Post by kostas on May 11, 2013 21:17:14 GMT 1
Hi Guys, Made some progress over the last days, Finsihed with repairing the wiring which had a lot of taped connections with the wires just twisted together, no solder, no heatshrink.. Soldered everything replaced some connectors and is now ready to fit. Finished with painting and sorting the wiring on the clocks IMG_1479 by k.apostolopoulos, on Flickr Also finished with the switchgear, with a decal kit from Norbo, IMG_1530 by k.apostolopoulos, on Flickr here is a before picture IMG_1476 by k.apostolopoulos, on Flickr one of those had a crack on it, IMG_1483 by k.apostolopoulos, on Flickr Had to grind it a bit and repair it with JB Weld. Came out nice IMG_1525 by k.apostolopoulos, on Flickr So much work for just a couple of small bits. Kostas
Post by billy on May 12, 2013 21:07:02 GMT 1
Very nice.
Post by arrow on May 12, 2013 21:11:16 GMT 1
Nice work.
Post by subaru180 on May 13, 2013 0:48:12 GMT 1
Cracking job your doing there especially on the wheels and swing arm....Gives me an idea what a mess my place will be in this winter....keep it going.
Post by kennyroberts on May 14, 2013 18:08:52 GMT 1
Loving the work kostas..... Its a real neat and quality job you are doing. I wish my progress was as fast. I read the whole thread through. Keep the progress coming!!
Post by kostas on May 14, 2013 19:43:45 GMT 1
Thank you all for your comments,
You may have a slow progress there Kennyroberts with your F2 rebuild but I think yours will be one of a kind bike. Yours is one of the re-builds that made me go for a resto in the first place.
Doing it yourself is an amazing experience, you can get a good bike to ride even a mint one with less than the rebuild cost, but I don't think its worth it at all.
Keep it up!!
Kostas
Post by kennyroberts on May 14, 2013 21:27:38 GMT 1
Thank you all for your comments, You may have a slow progress there Kennyroberts with your F2 rebuild but I think yours will be one of a kind bike. Yours is one of the re-builds that made me go for a resto in the first place. Doing it yourself is an amazing experience, you can get a good bike to ride even a mint one with less than the rebuild cost, but I don't think its worth it at all. Keep it up!! Kostas Thanks a lot kostas. Im as keen as ever to keep going. Im enjoying it as much as ever. But spending some horrible english wintery nights and weekends on my sons car at the moment. And when i get done on bike and car.i cant wait to start another.......seeing yours i fancy a nice red framed one !!!
Post by kostas on Oct 2, 2013 17:13:58 GMT 1
Well is has been over 3 months since the last time I worked on the bike. Summer weather is hard to handle, it gets more than 40 degrees C in the hangar, so a trip to the nearest beach is always the first option. Anyway I sourced a nice straight headlight/fairing bracket from e-bay and last week I fitted this on with the clocks installed on it. IMG_1825 by k.apostolopoulos, on Flickr IMG_1827 by k.apostolopoulos, on Flickr It was after that when I realised that it all needs to came off again so I can repair the fairing lugs and fit it on the bracket first I'm so happy that winter is finally back, I have to speed up to get the bike ready for next summer.. Kostas
Post by kennyroberts on Oct 2, 2013 18:53:13 GMT 1
Good to see you back on it kostas....the weather may be hot but the bike is looking cool!.
Post by copper99 on Oct 2, 2013 20:17:34 GMT 1
Its a funny old world, ill be stopping work in my garage over Winter soon enough...!
Your bike is going to be a beautiful example Kostas, look forward to more updates.
