Post by mouse on Apr 7, 2024 17:13:48 GMT 1
Those brakes have come up a treat, Ovi has surpassed himself!
All looking great Dusty, the only thing, with those 'powerhouse' kits, everytime i've used them the bleed nipples they supply are useless. They never seem to seal properly and i end up using the original, hope you have better luck though!
Mouse
Plan B !
Apr 7, 2024 18:38:06 GMT 1
via mobile
Post by huggy76 on Apr 7, 2024 18:38:06 GMT 1
Dusty, could you measure the length of those brake hoses for me please? I think mine might be a bit too long as they have rubbed on the rad guard. Thanks
Post by dusty350 on Apr 7, 2024 19:37:35 GMT 1
I will have to take them off again. Just spent a couple of hours fitting it all !!
Post by dusty350 on Apr 7, 2024 19:56:41 GMT 1
Hi Mouse Noted regards the bleed nipples mate. I've cleaned up the originals and fitted them instead Built the calipers back up today. One last job before reassembly was to run a wire brush on the dremmel down the slider housings, to clean some corrosion at the very bottom of the holes; 20240406_120757 by dusty miller, on Flickr Once that was done and the holes cleaned out, it was time to fit the slider pin boots and the seals; 20240407_095812 by dusty miller, on Flickr The rest all went together easily enough; 20240407_175016 by dusty miller, on Flickr 20240407_174948 by dusty miller, on Flickr
Plan B !
Apr 7, 2024 22:11:57 GMT 1
via mobile
Post by huggy76 on Apr 7, 2024 22:11:57 GMT 1
I will have to take them off again. Just spent a couple of hours fitting it all !! No worries, obviously wouldn’t expect you to do that. Thanks anyway. 👍
Post by dusty350 on Apr 8, 2024 6:47:19 GMT 1
No problem Huggy, I will do it for you. Will be later today when I get home
Post by dusty350 on Apr 8, 2024 18:19:36 GMT 1
51cm from centre of banjo at top to centre at bottom. Both lines are the same. Do you need to know the length from master to splitter ?
Plan B !
Apr 8, 2024 19:22:46 GMT 1
via mobile
Post by huggy76 on Apr 8, 2024 19:22:46 GMT 1
51cm from centre of banjo at top to centre at bottom. Both lines are the same. Do you need to know the length from master to splitter ? That’s brilliant thanks, no need to measure the one from m/cyl to the splitter though cheers, I can now measure mine to see what mine are. 👍
Post by dusty350 on Apr 8, 2024 19:26:44 GMT 1
No probs
