Post by lcmarky on Sept 9, 2023 11:18:37 GMT 1
Folks you were right and I was far too rich with the mains. I'm now on a 1.5mm dia hole or ~ #160 if you prefer.
The motor revs cleanly and quickly up to max. If I ride in a high gear and slowly open the throttle it'll stutter a bit around 5-5.5k, but WOT from take off and she's off.
Pilot is #48 and JJH needles. I'm now on the list to go see Mutts to get it fine tuned, but for now at least I'm away.
Post by sidney81 on Sept 10, 2023 9:12:21 GMT 1
Nice one ๐, mutts definitely the best way to go ๐
Post by lcmarky on Sept 13, 2023 15:06:44 GMT 1
Rear brake time
Post by lcmarky on Sept 14, 2023 15:08:35 GMT 1
Think Iโll give this a road test before any more fettling. Need a smaller diameter spring and maybe more stroke - hence the road test.
Post by lcmarky on Sept 14, 2023 15:10:18 GMT 1
Post by lcmarky on Sept 14, 2023 15:10:35 GMT 1
Post by lcmarky on Sept 14, 2023 16:44:31 GMT 1
Some form of bleeding the air out might be useful!!
Post by lcmarky on Sept 14, 2023 16:45:47 GMT 1
Longer Ti bolts required for the master cylinder to bracket, otherwise I think Iโm happy with the general lay out.
Post by headcoats on Sept 14, 2023 20:15:47 GMT 1
You can get a smaller (diameter) spring and as you have an hydraulic rear brake the the spring doesn't need to be very strong
Post by lcmarky on Sept 15, 2023 8:29:51 GMT 1
You can get a smaller (diameter) spring and as you have an hydraulic rear brake the the spring doesn't need to be very strong Yep & that's my plan - just need to source one.
Post by headcoats on Sept 15, 2023 8:32:08 GMT 1
Just re read it and you did already mention it ๐
Post by lcmarky on Sept 15, 2023 8:34:25 GMT 1
Once I'm happy with the brake action, I'll strip it all and clean up all the parts before painting a few bits and re-assembly.
Have now ordered a M10 x1.25 banjo bolt with bleed nipple which cleverly I'd missed!!
Post by midlifecrisisrd on Sept 15, 2023 8:35:19 GMT 1
I just used the standard spring, just moved it over a bit
Tab on the pedal then milled a bit off the hanger lug, drilled and tapped for a dome head allen bolt
Moving the hanger mount over may be enough
Post by lcmarky on Sept 15, 2023 8:56:56 GMT 1
I've achieved pretty good alignment Steve like this, so a skinny spring probably easiest with a central swivel hook. I may have to make another connecting piece if I want more plunger throw - dunno yet until I test it & for that I need hydraulic fluid without air so gotta wait for the bleed fitting now. Yes I know I'm a spanner!
Post by lcmarky on Sept 16, 2023 20:03:56 GMT 1
Post by lcmarky on Sept 16, 2023 20:04:13 GMT 1
Post by lcmarky on Sept 16, 2023 20:04:33 GMT 1
Post by lcmarky on Sept 16, 2023 20:04:51 GMT 1
Post by lcmarky on Sept 16, 2023 20:06:48 GMT 1
Iโm as impressed as I am amazed. The LC rides an absolute treat, great brakes, handling and road manners. Keeps a good temperature, finds every gear up and down and goes well. Looking forward to Mutts doing his thing but for now sheโs singing.
Post by lcmarky on Dec 27, 2023 18:24:53 GMT 1
Been doing some fettling of late having put a couple of hundred miles on the bike.
Had an issue with the RHS carb overflowing at random & occasionally, that I think is just crud related as I've checked everything else. in line fuel filter and a good clean now needs a test ride.
Suspension softened on the rear and tyre pressures dropped have given a bit more compliance and feel.
Lowered the bar clamps ~ 10mm or so by machining down to improve ergonomics for me. Adjusted lock stops, but you still need to be careful not to over turn if doing a Uey.
Replaced the perspex clutch window with a thicker item & made up some new bosses to mount the pipes as the original Nikkon ones were shocking..
Post by lcmarky on Dec 27, 2023 18:25:37 GMT 1
Post by lcmarky on Dec 28, 2023 12:18:25 GMT 1
Finished. I made the length of the stepped section that actually seats into the down pipe longer & machined clearance for the spring.
Post by tout on Dec 28, 2023 15:23:25 GMT 1
WOW that is some braking power, by the looks of it Top Class work Sir
Post by lcmarky on Dec 29, 2023 10:26:31 GMT 1
WOW that is some braking power, by the looks of it Top Class work Sir Thanks and yes, it stops well!
