Post by lcmarky on Apr 19, 2023 9:50:09 GMT 1
Clock mount slowly taking shape.
Post by lcmarky on Apr 19, 2023 17:23:47 GMT 1
Came out something like I had intended. Should be nice a rigid.
Post by lcmarky on Apr 19, 2023 17:24:09 GMT 1
Post by lcmarky on Apr 19, 2023 17:30:56 GMT 1
Looks like this on the bike. GPS will stick down. Ti bolts needed now
Post by sidney81 on Apr 19, 2023 20:57:44 GMT 1
Looks lovely π
Post by JonW on Apr 20, 2023 3:40:29 GMT 1
Fancy!
Post by lcmarky on Apr 20, 2023 16:41:54 GMT 1
Sprocket offset time.
Post by lcmarky on Apr 20, 2023 16:43:31 GMT 1
Turned up a dummy sprocket to double check my measurements.
Post by lcmarky on Apr 21, 2023 13:44:27 GMT 1
There will be a bit of an interlude as I fathom out how to make an offset sprocket to suit, Machine some lock stops and source handlebar controls, rear brake master cylinder, front brake discs and hydraulic lines all round.
Post by lcmarky on Apr 21, 2023 13:48:50 GMT 1
Looking at the above pic on a big screen I think actually I may need to try and pull in the rear sprocket first.
The laser is the centreline of the rear sprocket as positioned with some toolmakers clamps, a parallel & a slip gauge. The rear wheel is centralised and I set the chain adjustment blocks by Vernier to be sure it was all as square as is possible.
Chain line looks a bit close to the frame for my liking..
Post by jackjabba on Apr 21, 2023 17:20:24 GMT 1
Looking great, wish I had the time, skill and tools to do this.
Post by 4l04ever on Apr 21, 2023 18:41:23 GMT 1
Better to have the chain as inboard as possible, as the further out the front sprocket is, the more the load on the front sprocket bearing.
Post by lcmarky on Apr 22, 2023 9:13:56 GMT 1
Better to have the chain as inboard as possible, as the further out the front sprocket is, the more the load on the front sprocket bearing. Absolutely. Trouble is I am somewhat limited by the rear wheel & sprocket hub. I'm starting to think I may need a different rear wheel...
Post by JonW on Apr 23, 2023 3:08:25 GMT 1
If you get stuck with frame/chain issues you can try a DID VT2 or whatever the new name is for that chain, its a thinner version of an X ring 520 that KTM use for off road bikes so its lighter as well, it can save a good few mm.
Post by lcmarky on Apr 24, 2023 9:04:24 GMT 1
If you get stuck with frame/chain issues you can try a DID VT2 or whatever the new name is for that chain, its a thinner version of an X ring 520 that KTM use for off road bikes so its lighter as well, it can save a good few mm. Funnily enough I did compare the chain on my RS250 that sits next to the LC for exactly that reason, so this is a good shout thank you. I've ordered a couple of 17T JT Sprockets that have tapped holes in and a parallel hole for some reason, so I'll look to stack those and can then machine, weld etc to suit. If I don't like the end result I'll think again. Maybe a longer output shaft? LC needs to vacate the workbench for a while, so I'll reassemble it all for now and leave it to have a think...
Post by midlifecrisisrd on Apr 25, 2023 9:25:18 GMT 1
You make me feel pathetic with what stuff I do on machines π€£
I thought with an RGV wheel it should just be a 9mm offset sprocket, the LC spacer and a 3mm clutch basket thrust washer π€
Post by lcmarky on Apr 25, 2023 18:05:22 GMT 1
Have to vacate the bench so took the opportunity for a quick pic.
Post by arrdy350 on Apr 25, 2023 20:44:53 GMT 1
That is very cool πππ
Post by lcmarky on Apr 26, 2023 9:36:46 GMT 1
That is very cool πππ Thank you - still plenty to do however!!
Post by JonW on Apr 26, 2023 14:03:23 GMT 1
Have to vacate the bench so took the opportunity for a quick pic. Im going to call this bike 'Jake the Peg'...
Post by lcmarky on Apr 26, 2023 15:16:35 GMT 1
The peg that needs shortening too..
Post by Tobyjugs on Apr 26, 2023 16:04:00 GMT 1
I think the side stand looks good.
Post by lcmarky on Apr 26, 2023 17:39:35 GMT 1
I think the side stand looks good. Thanks, but it needs a slight shave.. I may just make another.
Post by JonW on Apr 27, 2023 14:14:50 GMT 1
I like it, it looks like a mini rgv fork leg.
Post by lcmarky on May 4, 2023 14:51:01 GMT 1
Lock stop in itβs early stages.
Post by lcmarky on May 4, 2023 15:58:01 GMT 1
Post by Tobyjugs on May 13, 2023 16:41:48 GMT 1
I will second the opinion of Rob, i'm pretty sure i ordered M10 temperature sensors from Koso No that's wrong it's definately not metric as ive just had a few in my hands as i was looking for an M10 x1.00 temperature sensor.
Post by crogthomas on May 14, 2023 9:44:21 GMT 1
Post by lcmarky on Jun 1, 2023 17:16:07 GMT 1
Zero actual build progress due to other 2 w heel distractions, but I have received my number plate following the V5C arriving. What do you reckon folks? ππβπ¨π¨
Post by lcmarky on Jun 8, 2023 14:38:27 GMT 1
In anticipation of continued grief with fuel height I ordered these a while back and had forgotten all about it until now. Should be able so see whatβs going on in there. Hopefully it wonβt catch fire!!π
