cnkxu1
Post by cnkxu1 on Jun 6, 2021 9:13:05 GMT 1
Talk about torque. Must have gone around 4 or 5 times torqueing the head. The new head gasket I guess just kept compressing. Anyway another step closer, next is refurbishing the exhaust pipes. They are pretty rough with a big scrape on the right hand side, so a bit of scrubbing, filling and paint.
cnkxu1
Post by cnkxu1 on Jun 6, 2021 9:26:07 GMT 1
Post by JonW on Jun 8, 2021 1:28:57 GMT 1
If youre after a better muddy, Webike sell a decent quality modern plastic front mudguard. its cheap enough as well at about $80ish (depends on x rate) +post (i buy things ahead of when i need them and use their surface post, saves a fortune). It comes with a bracket, but your old one will fit, just needs the holes drilling for the extra bolts if you want 'aussie spec'. I drill the rivets and pull the brackets off before paint and use new rivets to refit to get a better quality job and as my plater is better than theirs i get them replated, but you dont have to its ok as is - its just the industrial 'by the thousand' vs the hand done work. japan.webike.net/products/23087733.html(To be fair Norbo sells a front muddy too, but its OEM and so obviously is a lot more money)
cnkxu1
Post by cnkxu1 on Jun 8, 2021 3:26:00 GMT 1
If youre after a better muddy, Webike sell a decent quality modern plastic front mudguard. its cheap enough as well at about $80ish (depends on x rate) +post (i buy things ahead of when i need them and use their surface post, saves a fortune). It comes with a bracket, but your old one will fit, just needs the holes drilling for the extra bolts if you want 'aussie spec'. I drill the rivets and pull the brackets off before paint and use new rivets to refit to get a better quality job and as my plater is better than theirs i get them replated, but you dont have to its ok as is - its just the industrial 'by the thousand' vs the hand done work. japan.webike.net/products/23087733.html(To be fair Norbo sells a front muddy too, but its OEM and so obviously is a lot more money) Looks to be about 125AUD (69USD plus 28USD sea freight) landed if there is no duty or gst compared to 135 pound 250AUD plus freight. We are living in the wrong country Jon. I am happy with the Roonsport one for now.
Post by JonW on Jun 8, 2021 5:36:38 GMT 1
not sure where you found 125, it says '89.25AUD (7,567 JPY)' when i look.
there is no duty on this to import, its under 1k and webike do not charge gst.
cnkxu1
Post by cnkxu1 on Jun 8, 2021 11:01:30 GMT 1
not sure where you found 125, it says '89.25AUD (7,567 JPY)' when i look. there is no duty on this to import, its under 1k and webike do not charge gst. It defaults to USD and I converted. I clicked on AUD and it comes up as 89.25AUD and add 36.48AUD shipping is 125 total.
cnkxu1
Post by cnkxu1 on Jun 25, 2021 6:29:47 GMT 1
A bit more progress - fitted the chain and used a rivet joiner.
cnkxu1
Post by cnkxu1 on Jun 25, 2021 6:30:40 GMT 1
I think I compressed the rivets enough.
cnkxu1
Post by cnkxu1 on Jun 25, 2021 6:31:32 GMT 1
Safety wired the rotor bolts.
cnkxu1
Post by cnkxu1 on Jun 27, 2021 7:34:49 GMT 1
Fitted the clocks
cnkxu1
Post by cnkxu1 on Jun 27, 2021 7:35:37 GMT 1
Nice shiny new bits Pipes came up ok too.
cnkxu1
Post by cnkxu1 on Jun 27, 2021 7:40:50 GMT 1
Horns did not work out of the box but I took them apart and adjusted the nuts and bolts until they made noise. Low note just needed a little turn on the nut. High note was a bit more stubborn. I think everything was tightened up too much when they were manufactured.
Post by JonW on Jun 28, 2021 6:43:38 GMT 1
Ahh, where were they from? Ive had a few sets from yambits and they worked out the box, but know guys have had issues with the Legend ones. We usually say these all come from the say factory so maybe the Legends are seconds, but good to know that a fiddle makes them work Oh and your C/stand is missing its foot in case you werent aware?
cnkxu1
Post by cnkxu1 on Jun 28, 2021 10:06:04 GMT 1
Ahh, where were they from? Ive had a few sets from yambits and they worked out the box, but know guys have had issues with the Legend ones. We usually say these all come from the say factory so maybe the Legends are seconds, but good to know that a fiddle makes them work Oh and your C/stand is missing its foot in case you werent aware? Horns were from Yambits November last year and I did not test them until now. Centre stand is a bit of a problem. The foot is indeed missing and I have not been able to find another one. It is why it has not been repainted until I weld on something suitable. I fitted it up with the pipes to work out some measurements and shapes. You would think stands would be available with all the bikes that have had aftermarket pipes fitted but I guess they were all thrown away.
cnkxu1
Post by cnkxu1 on Jun 28, 2021 10:11:58 GMT 1
BTW the horn has a 10mm nut as a spacer behind the plate that vibrates. Not quite right. I will have to see if I have any other old horns and what they use as a spacer.
cnkxu1
Post by cnkxu1 on Jul 1, 2021 6:52:05 GMT 1
A new friend from the west sent me a chain guard. Another step forward and another positive outcome from this forum.
Post by oldbritguy on Jul 1, 2021 7:15:36 GMT 1
Fantastic work. Really enjoying this build. Giving me some good tips too 😉 John
cnkxu1
Post by cnkxu1 on Jul 3, 2021 7:26:54 GMT 1
Installed a new clutch basket today. Torqued to 65 ft lbs achieved by placing in first gear and standing on the foot brake.
cnkxu1
Post by cnkxu1 on Jul 3, 2021 7:27:52 GMT 1
And new clutch plates, soaked overnight in engine oil.
cnkxu1
Post by cnkxu1 on Jul 4, 2021 8:07:26 GMT 1
Primed the pump and the oil is starting to come through. This was done by opening the screw until the oil flowed, closing the screw, kicking the motor over until the pump stroke was the greatest and manually pushing tje pump shaft in and out until the oil flowed. I collected the oil from the bleeder and squirted that into the intake. That should lubricate the bottom end when it starts until the pump fills the lines.
cnkxu1
Post by cnkxu1 on Jul 4, 2021 8:09:13 GMT 1
Nice new radiator cover
Post by stirling11 on Jul 5, 2021 13:59:34 GMT 1
Chris
You may wish to change out the clear oil lines for the solid black Yamaha ones
I was advised by Arrow a few years back that the majority of the clear ones do not like the Aussie sun
Just a thought for you
cnkxu1
Post by cnkxu1 on Jul 6, 2021 0:13:54 GMT 1
Chris You may wish to change out the clear oil lines for the solid black Yamaha ones I was advised by Arrow a few years back that the majority of the clear ones do not like the Aussie sun Just a thought for you I may do that once I have seen the oil coming through. The lines are fuel and oil rated though. Not that this bike will see the sun all that often. It is on a 45 day club permit and I usually only go out less than 5 times a year on my other club permit vehicles. Besides it is in Melbourne and there are only two good bike riding days - one in Autumn and one in Spring - the rest of the year is too damn hot or too damn cold. LOL
cnkxu1
Post by cnkxu1 on Jul 6, 2021 0:14:52 GMT 1
Those blue radiator hoses have to go too. I have some black ones on order.
cnkxu1
Post by cnkxu1 on Jul 6, 2021 0:21:11 GMT 1
1M1 oil pump so using the rectangular mark for full throttle
cnkxu1
Post by cnkxu1 on Jul 6, 2021 5:49:22 GMT 1
Tried the copper wire but resorted to the coat hanger wire to pack out the exhaust flange.
Post by JonW on Jul 6, 2021 6:24:06 GMT 1
That copper twist is nice and neat But, yeah Ive always had to resort to the old coathanger in mine. I'm not a fan of the wire lock wire on the oil hose, your call of course but the OEM clip (on the OEM pipe as has been said) is the way with these really.
cnkxu1
Post by cnkxu1 on Jul 6, 2021 9:20:31 GMT 1
Love using my twist lock pliers
cnkxu1
Post by cnkxu1 on Jul 6, 2021 9:21:50 GMT 1
Wrestle mania. A bit of silicon and a lot of wriggling and they are in.
cnkxu1
Post by cnkxu1 on Jul 6, 2021 9:24:22 GMT 1
Just have to put on the choke interconnect tube between the carbies, add the balance tube and some drain tubes - another step closer.
