cnkxu1
Post by cnkxu1 on Jan 10, 2021 5:44:49 GMT 1
cnkxu1
Post by cnkxu1 on Jan 11, 2021 7:15:23 GMT 1
Some progress over the last week with the frame Cleaned the frame with KBS Aquaklean and treated with Rustblast. Not a lot of rust to treat, mainly just where cables etc. rub.
Two coats of Rustseal and some gloss clear topcoat. Sets like a rock. Mixed up a new bath of nickel plating solution and seeing how the head bolts go.
cnkxu1
Post by cnkxu1 on Jan 11, 2021 7:19:07 GMT 1
Funny its not until I take a photo and then notice that I have completely missed cleaning a gasket surface. And always fun finding the sins made by previous owners. See if you can find it.
cnkxu1
Post by cnkxu1 on Jan 12, 2021 9:23:46 GMT 1
The build can begin (if I can find all the parts, I did label them in containers.)
Post by shaunthe2nd on Jan 13, 2021 1:16:35 GMT 1
Looks like you have a good starting point with that bike. I think I would have just washed it and riden it! You going stock or off piste with it?
cnkxu1
Post by cnkxu1 on Jan 13, 2021 13:55:00 GMT 1
Looks like you have a good starting point with that bike. I think I would have just washed it and riden it! You going stock or off piste with it? Stock with this one. It was the bike I wanted back in the 80's when I was riding an air cooled RD350.
cnkxu1
Post by cnkxu1 on Mar 18, 2021 9:58:38 GMT 1
You don't have to add much to make it start looking like a motorbike
cnkxu1
Post by cnkxu1 on Mar 18, 2021 10:02:17 GMT 1
Post by JonW on Mar 19, 2021 0:03:42 GMT 1
Cool. defo getting on!
Hot tip: Get hold of some Bowdens Mr Black and do the ends of the airbox, you'll love how they will come out.
cnkxu1
Post by cnkxu1 on Mar 19, 2021 22:28:50 GMT 1
Cool. defo getting on! Hot tip: Get hold of some Bowdens Mr Black and do the ends of the airbox, you'll love how they will come out. I was looking for my plastic restorer in the garage but could not find it. I might have chucked it out because it did not work so well. I will get some Mr Black. I did have a spray can of a UK product called Dash Dandy some years ago that was magic on exterior plastics. The Land Rover Discovery bumpers had started to turn a sparkly grey and it brought them back to black. I was never able to find the active ingredient or the product again. I see now it has appeared again but it looks like it may be silicon based although there is a non-greasy one.
cnkxu1
Post by cnkxu1 on Apr 6, 2021 11:26:50 GMT 1
One step forwards two steps back How much time do you spend fixing the PO problems? Someone decided that it would be a good idea to chop off the rear indicator stalks. I tapped what was left of the tubes, cut down some nuts to lock them and threaded the stalks in, a bit of a trim with the cutoff wheel and it will be sweet. A little narrower than stock but it will work.
cnkxu1
Post by cnkxu1 on Apr 6, 2021 11:42:11 GMT 1
Found something strange happening with my nickel plating - the copper wire I used to attach the nickel plate fell into the solution. After a while the copper wire dissolved dropping the nickel terminal and coating the target with a thin film of copper that did not really stick. After polishing, the result was a green colour on the plated parts similar to the original Yamaha plating.
Post by JonW on Apr 6, 2021 14:07:59 GMT 1
Love the threaded in indicator stalks on the back, superb!
cnkxu1
Post by cnkxu1 on Apr 7, 2021 7:14:24 GMT 1
Love the threaded in indicator stalks on the back, superb! Just checked to see that the tailpiece clears the stalks and it does.
Post by JonW on Apr 7, 2021 8:12:04 GMT 1
Love the threaded in indicator stalks on the back, superb! Just checked to see that the tailpiece clears the stalks and it does. I made up spacers in alloy with external threads on one end to bolt to the bike and internal to thread in some aftermarket inds for my 421 as the bodywork hit the inds, so pleased for you that you got the clearance. You probably know but there are two lengths of those stalks, the short ones are LC2, the longer ones are LC.
cnkxu1
Post by cnkxu1 on May 24, 2021 10:13:37 GMT 1
cnkxu1
Post by cnkxu1 on May 30, 2021 7:01:13 GMT 1
Back on its wheels. Bit of a sad centre stand but I should be able to weld something on the end to make it work.
cnkxu1
Post by cnkxu1 on May 31, 2021 23:16:44 GMT 1
Post by JonW on Jun 1, 2021 1:31:01 GMT 1
Sadly the YPVS chain guard isnt the same and I doubt it will fit, it would certainly need some mods. There must be some out there tho just gotta wait until someone sells one on ebay i guess.
Otherwise, great its coming on!
Post by stirling11 on Jun 1, 2021 8:38:48 GMT 1
You have a PM
Post by shaunthe2nd on Jun 1, 2021 9:06:05 GMT 1
Great progress.
cnkxu1
Post by cnkxu1 on Jun 4, 2021 8:58:44 GMT 1
Sadly the YPVS chain guard isnt the same and I doubt it will fit, it would certainly need some mods. There must be some out there tho just gotta wait until someone sells one on ebay i guess. Otherwise, great its coming on! Yes I don't know why I ended up with three of the YPVS ones and none of the LC.
Post by oldbritguy on Jun 4, 2021 10:17:42 GMT 1
This is great. Lots of home refurbing techniques which will inspire our members and guest visitors to have a go themselves. Brilliant thread and I love the Holden Keep the pics coming 😉 John
cnkxu1
Post by cnkxu1 on Jun 4, 2021 10:25:41 GMT 1
And the motor goes in. Had to be careful with how much I could lift so left the barrels off. One positive from another lockdown is it focusses me on the resto. Yes they are worn out socks taped to the frame for protection. And Jonw you will notice I did finish the air cleaner box with Bowdens Own Mr Black
Post by stirling11 on Jun 4, 2021 13:29:02 GMT 1
Hot water pipe foam lagging works well too for wrapping around the frame for engine removal or installation
Post by JonW on Jun 4, 2021 14:07:39 GMT 1
And the motor goes in. Had to be careful with how much I could lift so left the barrels off. One positive from another lockdown is it focusses me on the resto. Yes they are worn out socks taped to the frame for protection. And Jonw you will notice I did finish the air cleaner box with Bowdens Own Mr Black[/b] Nice work Chris! Glad the Mr Black worked well. Ive had good results with it, great on the faded ends of the airbox etc.
Post by JonW on Jun 4, 2021 14:08:31 GMT 1
Hot water pipe foam lagging works well too for wrapping around the frame for engine removal or installation I found it a bit thick and the engine was too high, i went back to old socks taped on just like shown here.
cnkxu1
Post by cnkxu1 on Jun 5, 2021 1:31:34 GMT 1
Hot water pipe foam lagging works well too for wrapping around the frame for engine removal or installation Guess what I threw out a few weeks ago in a cleanup.
Post by JonW on Jun 5, 2021 1:59:47 GMT 1
Hot water pipe foam lagging works well too for wrapping around the frame for engine removal or installation Guess what I threw out a few weeks ago in a cleanup. It wasnt the socks... theyre too damn useful! (you might need to press them back into action for their intended next week Chris, that polar ice cap melt is heading your way according to the news!)
cnkxu1
Post by cnkxu1 on Jun 6, 2021 3:05:47 GMT 1
Guess what I threw out a few weeks ago in a cleanup. It wasnt the socks... theyre too damn useful! (you might need to press them back into action for their intended next week Chris, that polar ice cap melt is heading your way according to the news!) Rain and southerlies means snowfalls on the ranges but I won't be going skiing this year unless it is in the backyard. We did have an unusual very light snowfall a few years ago but I don't think it will be cold enough in Melbourne.
