Post by flames on Aug 19, 2020 20:06:07 GMT 1
Hubba Hubba Hubba.π
Post by Tobyjugs on Aug 19, 2020 21:09:12 GMT 1
Finally got the rear wheel in centrally with rear caliper and bracket That really is old school
2taol
Post by 2taol on Aug 20, 2020 7:15:51 GMT 1
looks really good, nice beefy swingarm and the spoked wheel compliment well.
Post by midlifecrisisrd on Aug 20, 2020 9:00:40 GMT 1
That really is old schoolΒ Cheers That was the plan π Modern running gear that "looks" old Next job which I'm dreading and looking forward to the challenge is front brakes Need to work out adaptor brackets for the Lockhead CP copy calipers Thought I had found an easy alternative when I got offered some Harrison Billet 6 calipers that went straight on the forks but then found my discs were too thick for them Should be not too bad now that I've found you can buy a digital protractor Steve
Post by JonW on Aug 22, 2020 14:06:07 GMT 1
That really is old schoolΒ Cheers That was the plan π Modern running gear that "looks" old Next job which I'm dreading and looking forward to the challenge is front brakes Need to work out adaptor brackets for the Lockhead CP copy calipers Thought I had found an easy alternative when I got offered some Harrison Billet 6 calipers that went straight on the forks but then found my discs were too thick for them Should be not too bad now that I've found you can buy a digital protractor Steve By how much Steve? you might be able to doctor the caliper body and/or find lower pistons?
Post by midlifecrisisrd on Aug 22, 2020 16:33:05 GMT 1
Cheers That was the plan π Modern running gear that "looks" old Next job which I'm dreading and looking forward to the challenge is front brakes Need to work out adaptor brackets for the Lockhead CP copy calipers Thought I had found an easy alternative when I got offered some Harrison Billet 6 calipers that went straight on the forks but then found my discs were too thick for them Should be not too bad now that I've found you can buy a digital protractor Steve By how much Steve? you might be able to doctor the caliper body and/or find lower pistons? The Harrison calipers are super thin so pistons are shallow and not much meat on the 6 pads per caliper π±
Post by oldbritguy on Aug 22, 2020 22:22:15 GMT 1
I know the discs are new but could they be skimmed/machined down to fit the calipers and remain within their safe working tolerances? Or as you say sell the Harrisonβs and offset some of the cost of new Lockheeds. Joys of building a special bud π
Post by JonW on Aug 23, 2020 3:50:03 GMT 1
Ahh yes, slimline calipers.
Post by midlifecrisisrd on Aug 23, 2020 10:26:15 GMT 1
I know the discs are new but could they be skimmed/machined down to fit the calipers and remain within their safe working tolerances? Or as you say sell the Harrisonβs and offset some of the cost of new Lockheeds. Joys of building a special bud π I don't have a set of Harrison's, I got offered a set of big piston billet 6's made for the Yam fitment I already have the Lockhead copies as that was my first plan I could have got ABE to make discs to suit but then I'd have to move on all I'd spent a small fortune on βΉ Oh and it's Β£100 for pads for the Harrison calipers π― Steve
Post by veg on Aug 23, 2020 18:41:39 GMT 1
Ap calipers, master cylinder, wire wheels cool as 10 polar bears matey π
Post by markylc on Aug 23, 2020 19:04:33 GMT 1
Great project. Looking really cool.
Post by oldbritguy on Aug 23, 2020 21:15:39 GMT 1
Totally mis read that one Steve and got your brakes mixed up. I thought you had actually acquired theHarrisons. Lockheedβs all the way for that proper period look and awesome stopping power. Put a lightweight alloy one on my Norton and could not believe the difference. A brake which actually worked as the OEM one is total shite. Β£100 for brake pads!!!!!! Get some nice alloy adapter plates milled up for the Lockheedβs and never look back ( except when pulling out to overtake lol π)
Post by midlifecrisisrd on Sept 4, 2020 17:15:00 GMT 1
Spent 2 hours making a template for the front calipers Would have been quicker if I hadn't dropped a pad pin. Still haven't found the little fecker π‘
Post by dusty350 on Sept 4, 2020 19:03:58 GMT 1
That's looking good Steve Bit of CAD involved ?? Dusty
Post by midlifecrisisrd on Sept 4, 2020 22:09:23 GMT 1
That's looking good Steve Bit of CAD involved ?? Dusty No card involved π Here's the technical bit lol I stuck a 2mm packer on the edge of the disc then put a piece of card (oh sh1t I did use card π) behind each pad so when I sat the caliper on the disc it held in place with 2mm between the edge of the disc and the caliper groove with the pads on the very edge of the disc I then jammed the wheel with the other disc so the caliper was where I wanted it I knew the fork mount spacing was 100mm and the caliper mounts were 89mm and I could measure the distance between the 4 mount holes I then got my new toy out. A digital protractor π I then measured the angles between the bolt holes and transferred the data onto some steel plate, drilled out and cut around 1 hole is 1mm out but I can sort it with the engineer when I give him the template to mill out of the big chunk of alloy plate I just bought π Steve
2taol
Post by 2taol on Sept 5, 2020 7:29:49 GMT 1
hard not to use top spec engineering aids like cereal boxes, twine and masking tape. if they produce a result, well winner all right.
bracket looks good
Post by midlifecrisisrd on Sept 5, 2020 10:34:29 GMT 1
Got a 250x250x25 slab of alluminium in my eBay basket now
70 bloody quid π
Post by cb250g5 on Sept 5, 2020 11:15:00 GMT 1
Could you not split the 6 pots and make up a piece to go in the middle, to widen them? Few O rings to seal the fluid passage and bobs your aunties live in lover.
Post by midlifecrisisrd on Sept 5, 2020 11:30:34 GMT 1
Could you not split the 6 pots and make up a piece to go in the middle, to widen them? Few O rings to seal the fluid passage and bobs your aunties live in lover. Yes, that's a good call. I could but I don't like messing too much with brakes and the Girlings were the first plan anyway The yzf six pots and the tdm calipers off the leftovers build go straight on but I have literally no clearance I could get either to fit by getting new disc spacers made 1.5mm wider and take a flap wheel to the offending corner that just kisses the spokes and get 2-3mm clearance but if I'm honest that was only an option to save me the grief of making caliper brackets The template is done now so hopefully by the time the alloy has arrived the eng8neer will be back at work ish Steve
Post by veg on Sept 5, 2020 14:37:35 GMT 1
Girling/lockheed/grimeca all the way matey (I assume girling made them first then Ap took over girling and Grimeca just copied them? sorry reversed engineered them?) either way for a build like this they are the nutts. Should i ever get round to buy the frame etc i need for my other build ill be using them.
Post by oldelsieboy on Sept 5, 2020 16:43:43 GMT 1
Ap calipers, master cylinder, wire wheels cool as 10 polar bears matey π You're not wrong OEB
Post by flames on Sept 5, 2020 17:47:28 GMT 1
yummy yummy
Post by midlifecrisisrd on Sept 22, 2020 12:46:40 GMT 1
Engineer still working on the adaptors. Popped down to see him today as some other bits he was doing for me were ready He's having a problem programming the bottom curve into the machine from the template as it's not a straight forward radius He looked relieved when I told him that shape wasn't important. As long as the holes are in the right place with enough meat around them it will be fine π My clearance concern on the speedo drive to disc bolts ain't a problem any more Steve
Post by midlifecrisisrd on Sept 23, 2020 16:23:02 GMT 1
Caliper brackets home to test fit for alignment before the fork mount holes are drilled/tapped Steve
Post by oldbritguy on Sept 23, 2020 16:31:05 GMT 1
Lovely bit of milling there Steve. Should look the biz once you get them fitted. Polished or anodised ? John
Post by midlifecrisisrd on Sept 23, 2020 18:09:42 GMT 1
Lovely bit of milling there Steve. Should look the biz once you get them fitted. Polished or anodised ? John Cheers John Would have been a lot easier to just use 10mm plate then spacers to sort the offset but wanted something more "solid" so went for the one piece May get a bit milled out the back at the fork leg mounts, never be seen but quite meaty around that area. In saying that it gives 25mm of thread for the main mount bolts Finish will be anodised. I'll scotchbrite the unmachined face first I had the pegs/levers and swing arm end caps/chain pull plates clear anodised so I'll get these done the same along with the 2 disc spacers and the rear caliper bracket Steve
Post by midlifecrisisrd on Sept 24, 2020 17:11:01 GMT 1
Fork mount holes drilled and tapped now and trial fitted The joy of hand made parts π Left one is perfect, right one just skims the outer edge of the disc π I'll split the caliper and "relieve" the point it touches Was trying to get the calipers as far into the disc as possible as the 295mm disc is right on the max of the caliper With 1mm clearance the pads are right at the edge of the disc but that's what I get for fitting dust bin lids to 80's calipers π€£ Steve
Post by dusty350 on Sept 24, 2020 20:08:20 GMT 1
Looking really good Steve So much involved in getting it right, and working properly. Top notch Dusty
Post by midlifecrisisrd on Oct 1, 2020 18:49:58 GMT 1
May have found a donor chain guard, off an XJR Steve
2taol
Post by 2taol on Oct 1, 2020 19:53:21 GMT 1
that looks quite good! is it aluminium?
