Post by midlifecrisisrd on Jun 3, 2020 11:23:03 GMT 1
Say no more. Nudge, nudge 😁
Post by midlifecrisisrd on Jun 3, 2020 12:15:31 GMT 1
Checked fitment of SS top hat reducers and the cut to size spindle to check all fitted before putting it in the plating bucket Steve
Post by midlifecrisisrd on Jun 9, 2020 18:38:34 GMT 1
Nice box arrived today Steve
Post by dusty350 on Jun 9, 2020 20:16:37 GMT 1
Looking good so far Steve What fitment is that rear master cylinder with the built in reservoir ? Not seen one like that before. Dusty
Post by midlifecrisisrd on Jun 9, 2020 20:50:31 GMT 1
Looking good so far Steve What fitment is that rear master cylinder with the built in reservoir ? Not seen one like that before. Dusty It is a Nissin master from NK with 49mm mount spacing The frame bracket is 40mm and he does Brembo cylinders to fit that either GP style or with a built in res but there is no stop on them so you need a pedal stop on the lever to stop the plunger coming out the cylinder meaning you lose the ability to adjust the lever height The Nissin has a stop and as I'm using levers pivoting off the foot pegs and not the separate pivot points behind the pegs on the frame I reckoned I'd have to mod the bracket or use an adaptor plate anyway Steve
Post by dusty350 on Jun 10, 2020 7:02:47 GMT 1
Cheers Steve Certainly looks good Dusty
Post by LC_BOTT on Jun 10, 2020 7:28:11 GMT 1
''It is a Nissin master from NK with 49mm mount spacing''
That's good to know too, Didn't realise Nissin did them as well, been thinking about one too, and seen Norbo lists the Brembo type on his site. I'd started looking at KTM/CRF ones as well, as they look similar.
Post by midlifecrisisrd on Jun 10, 2020 8:38:57 GMT 1
''It is a Nissin master from NK with 49mm mount spacing'' That's good to know too, Didn't realise Nissin did them as well, been thinking about one too, and seen Norbo lists the Brembo type on his site. I'd started looking at KTM/CRF ones as well, as they look similar. It was £69 + vat from NK Steve
Post by mak595 on Jun 10, 2020 11:07:44 GMT 1
Post by midlifecrisisrd on Jun 10, 2020 11:51:19 GMT 1
No, hadn't noticed that, thanks Decent price too 👍 Steve
Post by veg on Jun 10, 2020 17:05:52 GMT 1
Its a banger though, and a money pit, better of doing it the way you have steve.
Post by midlifecrisisrd on Aug 3, 2020 16:41:24 GMT 1
Couple of bits of progress Yoke stem shortened so now fits the frame 😁 Disc spacers made and fitted. Ignore the bolts, just to hold it temp so I can look at Speedo drive and wheel spacers Steve
Post by veg on Aug 3, 2020 18:53:48 GMT 1
Oh nicey nice. I may be returning home with another frame shortly as 1 project is never enough. I love your wheels and funnily enough i copied you
Post by jon on Aug 3, 2020 19:02:38 GMT 1
Either you’ve got very small feet, or those disks are seriously chunky!
Post by veg on Aug 3, 2020 19:14:59 GMT 1
Thats not him Jon its his lithuanian slave he keeps to polish everything. Cant you tell by the crappy trainers.
Post by midlifecrisisrd on Aug 3, 2020 19:27:37 GMT 1
Either you’ve got very small feet, or those disks are seriously chunky! Jon Bit of both in that pic Camera perspective making feet look small (size 10 trainers) and the discs look massive They ain't lightweight either as the discs are 6mm thick 😳 Steve
Post by veg on Aug 3, 2020 19:29:12 GMT 1
You can actually tell the discs are thick as buggery, this is gonna look damm fine when its done.
Post by midlifecrisisrd on Aug 3, 2020 19:32:58 GMT 1
Thats not him Jon its his lithuanian slave he keeps to polish everything. Cant you tell by the crappy trainers. Shhh! He's an illegal 😅 That's my hand me down trainers 😀 Not from anybody, just after a new pair start to go grubby they get downgraded to garden trainers After that they go to DIY/garage trainers to meet their death by grinder and paint 😄 Good pair of Adidas they were Steve
Post by midlifecrisisrd on Aug 3, 2020 19:36:40 GMT 1
You can actually tell the discs are thick as buggery, this is gonna look damm fine when its done. Could have used modern sports discs but wanted to keep the "old school" look I may have got sidetracked by a pair of Billet 6 calipers 😖 Waiting to hear if they will actually fit between the discs and spokes They are spaced as far as possible while still clearing the forks Steve
Post by Yogi on Aug 3, 2020 19:39:19 GMT 1
Looking good mate 👍
I’m glad I’m not the only one who works his trainers out to the shed in stages 🤣
Post by abar121 on Aug 3, 2020 20:02:03 GMT 1
Looking Brilliant !
Post by reggieperrin on Aug 3, 2020 21:50:50 GMT 1
Hmmm.. Nickel plate, it's lovely and looks gorgeous. Somehow more lustrous than chrome but it's a pain in the arse and will corrode easily. The Nickel on my Rickman has suffered and will need replating..
Post by dusty350 on Aug 4, 2020 7:12:43 GMT 1
Looks great so far Steve This is gonna be such a nice build, and pretty unique too. We need more pics !! Dusty
Post by midlifecrisisrd on Aug 12, 2020 20:06:07 GMT 1
Left hand rear wheel spacer made to line the wheel centrally now The Bandit brake caliper bracket was way too chunky so had one made out of 10mm plate then 2mm machined off opposite faces to centre the caliper on the disc Now got the measurement for the RH spacer so once that's made the wheel is ready and I can get a tyre fitted Also managed to get a bearing cup to fit the headstock so another little thing sorted Front wheel spacers next Steve
Post by dusty350 on Aug 12, 2020 20:15:33 GMT 1
Looking good Steve The caliper bracket looks more trick than a standard Bandit item anyway, so worth the effort Dusty
Post by midlifecrisisrd on Aug 12, 2020 20:19:54 GMT 1
Cheers Dusty. I'll get it brushed then anodised when I'm getting the swingarm done
Need to work out a small chain guard and get a mounting tab welded on
Post by oldbritguy on Aug 13, 2020 14:22:56 GMT 1
Nice work so far Steve, looking really good.
Are you going to use Able for your anodising? My brother got some stuff done by them a while back and it didn't turn out that great. That was, to be fair, getting well worn parts re done as opposed to new bare metal. Looking forward to seeing how they turn out.
John
Post by midlifecrisisrd on Aug 13, 2020 17:29:24 GMT 1
Popped the top yoke on and stuck the forks in to measure the front wheel spacers Fazer forks sleeved down to 15mm spindle and a cut down Yam 350 ypvs rear spindle Steve
Post by midlifecrisisrd on Aug 14, 2020 13:11:58 GMT 1
Front wheel spacers done and wheel in all fine and dandy Pity the rear isn't as straight forward Cush drive has squeezed in more meaning I have 1mm too much space now and rear caliper needs moving 2mm towards the arm 🙄
Post by midlifecrisisrd on Aug 19, 2020 19:51:13 GMT 1
Finally got the rear wheel in centrally with rear caliper and bracket
