Post by mak595 on Apr 26, 2020 16:49:46 GMT 1
Looking a bit better now
Post by mak595 on Apr 30, 2020 17:29:13 GMT 1
Crank's been sent away to PJME today to a rebuild so it looks like I'm building the bike now !!!
sausages
Member is Online
Post by sausages on Apr 30, 2020 17:41:20 GMT 1
You must be getting bored Mark
Post by jonw on May 1, 2020 1:56:45 GMT 1
Glad that you are keeping the 51Ls and giving them a go. Always nice to see those top ends saved.
Post by mak595 on May 1, 2020 8:38:35 GMT 1
Glad that you are keeping the 51Ls and giving them a go. Always nice to see those top ends saved.  Yep, not sure what cdi etc to run.....
Post by mak595 on May 1, 2020 8:39:41 GMT 1
You must be getting bored Mark I am but back to work later next week
Post by Yogi on May 1, 2020 8:48:32 GMT 1
Post by mak595 on May 1, 2020 9:23:44 GMT 1
Cheers, just sent an offer....
Post by jonw on May 1, 2020 9:44:56 GMT 1
yep thats the right one. Do you have 1GA carbs... if not I have some Im selling for a mate on my site.
Post by mak595 on May 1, 2020 9:48:50 GMT 1
yep thats the right one. Do you have 1GA carbs... if not I have some Im selling for a mate on my site. I've got the original carbs but not really checked em out yet tbh Jonw, what stator would i need? i've got a spare 31k stator and flywheel....
Post by mak595 on May 1, 2020 10:04:48 GMT 1
These are the carbs ive got, its a Jap spec bike Enginerzrr1
Post by mak595 on May 1, 2020 10:07:29 GMT 1
Post by midlifecrisisrd on May 1, 2020 11:30:31 GMT 1
Same style as the 3hm1 carbs
An absolute bitch to get on and off till you work out the knack
Post by jonw on May 1, 2020 13:41:28 GMT 1
Same as USA carbs i think.
We didnt get those, we had 1GA versions. They are PJs.
RE stator and flywheel, our 51Ls were the 85 model units. im using them on an 83/4 at the mo so I assume you can use the parts the other way round. you need to check the various versions of Martin K's what-fits-what that are doing the rounds online tho, and you will need to make up loom/plus to suit. There will be fun n games with the kill switch wiring and im not sure about the triggers etc. I put an 85 in my LC on my 51L engine swap, i drew a wiring diagram by looking at the bike specific wiring and went from there. 30mins of quiet time with pen paper and a haynes for the diagrams would have you sorted i'd think.
Post by mak595 on May 1, 2020 18:40:07 GMT 1
Thanks, a guy of fb has a rz250 1xH-50 cdi, I think that's the slightly later model, any idea if that would work, if I don't get the 51L of ebay. It's half the price !
Post by jonw on May 2, 2020 4:48:40 GMT 1
it will work, but its not a 51L, I think the 1XH is the same as the 29L re the curve etc. It will also not just plug in, the 1XH has the later plugs.
Post by mak595 on May 2, 2020 18:38:31 GMT 1
Cheers, just sent an offer.... Excepted an offer of £70 for the 51L cdi do that's another piece of the puzzle...
Post by mak595 on May 3, 2020 10:22:11 GMT 1
Chucked the engine together just so it's not kicking about all over the place....
Post by 17again on May 3, 2020 15:13:17 GMT 1
Same style as the 3hm1 carbs An absolute bitch to get on and off till you work out the knack Steve changing needle heights has to be the worst job on them.
Post by 17again on May 3, 2020 15:13:52 GMT 1
bike is really coming on.
shame you cant show the old owner.
Post by mak595 on May 3, 2020 23:19:06 GMT 1
bike is really coming on. shame you cant show the old owner. Think he's in south america somewhere
Post by mak595 on Jun 14, 2020 20:29:38 GMT 1
I wasn't happy with the rear suspension set up, no static sag and with using the standard totally non adjustable yzf rear shock I couldn't do a lot about it. Sure it was how the rear bottom knuckle was mounted, anyway I've fettled the mounting plates I made so now the knuckle is parallel to the ground rather than at an angle. It feels much better now with linear suspension movement so happy with the rear end now. I can always get a yzf YSS shock if needed once on the road but that's a good while off yet !!! I've ordered a rear sprocket from B&C got to be cut from a blank so it fits the yzf rear wheel but in a 520 pitch rather than the standard 428 for a yzf. Don't fancy a skinny 428 chain in the bike. On to the front and when I put a tank on the bike, the yzf clip on's touched the tank, didn't want to bugger about with the lock stops as I've allready got a MT125 top yoke, I've gone that route with a renthal fatbars I had kicking about. Also the MT top yoke has some lugs which a assume are for mounts clocks etc so I can use them when I make a mount for the Koso clocks I've got. The renthal's needed a good inch chopping off them so they didn't look like cowhorns 😁😁 Nicked the seat off my other bike and it feels pretty good with the R1 rearsets. On to the engine, PJME are on with rebuilding the crank, got all new seals off Norbo, my oil pump is going off to Arrow tomorrow as I've got to the top of the list AND I've found a great set of 350 barrels on .50 with good PV's and a set of 31k carbs to go with them. Pick them up tomorrow...happy days 😀😀😀 Still need to source a set of pipes, no idea what yet and I need a cdi and PV controller so think I'm going to get a ignitech unit off DaveW once my wallet as recovered 🤑
Post by mak595 on Jun 14, 2020 21:31:24 GMT 1
I like the fact that the MT bar clamp has I little tuning fork logo on it, ties in nicely 😂
rickymac
Hi all new to this forum and owner of a barn find 250lc
Post by rickymac on Jun 15, 2020 14:58:46 GMT 1
Looking good Mark, I’ll have to check the suspension on mine when I get the frame back I used the adjustable plates designed for the rgv arm Ricky
Post by mak595 on Jun 15, 2020 15:01:17 GMT 1
Looking good Mark, I’ll have to check the suspension on mine when I get the frame back I used the adjustable plates designed for the rgv arm Ricky Think the plates will probably be fine, just get the knuckle parallel and you won't be far off....
Post by mak595 on Jun 16, 2020 19:27:07 GMT 1
Been shopping, pair of 350 31k barrels, pistons and 31k carbs 😁😁
Post by mak595 on Jun 21, 2020 13:55:48 GMT 1
Box arrived from PJME today 😁😁
Post by mak595 on Jul 1, 2020 17:00:51 GMT 1
Been a good productive couple of days on my yzf-rd project. Got the dummy engine in and the custom rear sprocket arrived from B&C so I could check out chain run. As I thought, the swing arm was angled too far down so I've remade the linkage mounting plates so the arm is now flat and it feels and looks alot better now. The chain run looks spot on, I'll just need a offset front sprocket, probably about 5mm but going to leave that measurement for now until it gets it's real motor in. I dropped the forks 10mm working on the principle that if I get the lower frame rails parallel to the ground, it's a good starting point. As a bonus, with the bike lower, the side stand is now the right length 😁😁
Post by dave1w on Jul 2, 2020 18:48:10 GMT 1
That does look better on the rear.
For the sprocket, are you having to space the front outwards?
Post by mak595 on Jul 2, 2020 19:12:27 GMT 1
That does look better on the rear. For the sprocket, are you having to space the front outwards? Yep, probably need about a 5mm offset front sprocket but waiting until I get the real motor in so I can measure it properly
