Post by mak595 on Sept 29, 2020 15:56:48 GMT 1
Well, starting to look at the bodywork, the tank looks to have had some sort of jbweld smeared on the usual rust spots so filled the tank with Deox C to hopfully get rid of most of the rust inside, then I'll get a wire wheel on it and see what I need to weld. Probably get a liner afterwards....
Post by mak595 on Sept 30, 2020 14:58:00 GMT 1
Well the deox C seems to have done it's job inside, few pin holes that I've welded up, wire wheeled all the surface rust off the underside of the tank and painted with hammerite Krust rust treatment. Just a skim of filler needed and the underside should be ok then I can start DA sanding the top of the tank
Post by mak595 on Oct 9, 2020 19:27:10 GMT 1
Cracking on with the bodywork, tank lined with flowliner, various dints filled and ready for some high build primer. Picked up a single seat unit so wanted a smooth look on the rear panel so plastic welded up the seat catch and grab rail holes, also welded up the line on the panel to get it as clean as possible. Still need to decide on colour π€
Post by mak595 on Oct 11, 2020 19:06:02 GMT 1
Post by mak595 on Oct 11, 2020 20:38:52 GMT 1
Plan is to get it down to the mot station as is and get a mot on the vin number so I can start the long process with the dlva clowns to get a reg number.
Then I can get on with the painting etc over winter and hopefully get a V5 by spring !!
Post by mak595 on Oct 27, 2020 15:23:40 GMT 1
MOT done so I can get the paperwork away for a reg number now π
Post by mak595 on Nov 27, 2020 15:08:31 GMT 1
Got wheels back from powder coat, boring gold like all the others π Should have the bodywork back from my painter mate next week Got seat back from Bootleg seats in Preston, awesome job, I asked for the seat to look like it had a separate bum pad...nailed it π
Post by andy748 on Nov 27, 2020 21:21:50 GMT 1
Nice job the gold wheels look awesome mate, love the seat too cracking job on that. Andy.
2taol
Post by 2taol on Nov 27, 2020 21:45:39 GMT 1
agree, the gold wheels and forks look nice all right. Good bit of work done with the tank and panels tooπ
Post by mak595 on Nov 28, 2020 15:01:24 GMT 1
Bloody hell, my V5 arrived today, 3 weeks after I sent all the forms in, nova, dating cert etc etc. I didn't expect a number this side of Xmas π
Post by mak595 on Dec 3, 2020 17:59:54 GMT 1
Post by mak595 on Dec 8, 2020 13:06:29 GMT 1
Inside of the panels blacked and bolted up the brackets I made so the seat is spring loaded like the original
Post by JonW on Dec 8, 2020 13:16:11 GMT 1
Thats superb work. I was going to do the same with my Quality Works Solo tail but never fitted it to the LC2, i will use it tho and do this as well.
Post by mak595 on Dec 8, 2020 17:12:53 GMT 1
Thats superb work. I was going to do the same with my Quality Works Solo tail but never fitted it to the LC2, i will use it tho and do this as well. Cheers, it needs it or your trying to get your fingers underneath the panel to remove it.....pain in the arse and easy to damage the paintwork
Post by ypvsimon on Dec 10, 2020 18:19:19 GMT 1
Great project and read to see all the issues and challenges you have overcome. Will be a stunning bike when finished π
2taol
Post by 2taol on Dec 11, 2020 13:40:03 GMT 1
Those panels look the business. I like the big blocks and "Pure 2 Stroke Spirit"
rickymac
Hi all new to this forum and owner of a barn find 250lc
Post by rickymac on Dec 11, 2020 15:11:10 GMT 1
Looking good Mark do like the gold wheels, looking forward to seeing it built up π
Post by mak595 on Dec 11, 2020 16:10:04 GMT 1
Looking good Mark do like the gold wheels, looking forward to seeing it built up π I like them now, wasn't too sure with the front wheel being a different shade to the gold forks but mounted the red mudguard now and looks loads better...breaks it up a bit
Post by mak595 on Dec 11, 2020 16:33:00 GMT 1
Been playing around with the forks the last couple of days, with them meant for a YZF 125, their a bit soft. Not too many options, Hypro do a spring kit for Β£130 or Andreani Fork Cartridge Kit for Β£490 !!!! Anyway stripped the forks, they only have a cartridge in the R/H fork, and just a spring in the L/H, part of the course for a 125, i suppose. The springs are progressively wound, after doing a bit of reading up, i cut 30mm from the tight (softer) coils to increase the spring rate and make the spring more linear, i then machined up a 30mm spacer on my trusty mini lathe to make up the difference. Rebuilt the forks with 15wt oil (10wt standard) they defiantly feel better just bouncing them in the garage, still got around 30mm of static sag but don't dive as much.
I'll try them once the bike is on the road, worst case, i buy a set of hypro linear springs but i think (hope) this might just work, its not like i'm competing in GPs !!!
Post by mak595 on Dec 15, 2020 17:15:03 GMT 1
2taol
Post by 2taol on Dec 15, 2020 20:59:28 GMT 1
brilliant result! sounds like its running well, enjoy and well done.
Post by dusty350 on Dec 15, 2020 21:05:25 GMT 1
Wow, the paint scheme looks stunning The whole bike looks great - well done- massive transformation Dusty
Post by JonW on Dec 15, 2020 21:48:42 GMT 1
I will admit i wasnt too taken with the initial paintwork pics, but wow it looks good now its on the bike.
Really good looking machine!
Post by mak595 on Dec 16, 2020 11:59:29 GMT 1
Cheers guys, just need the weather to improve so I can get a few shake down runs under it's belt...
Post by oldbritguy on Dec 17, 2020 15:14:58 GMT 1
I havenβt commented on this one much but I have been following your progress quite intently. What a beautiful transformation you have achieved there and your efforts are there for all to see. You mustβve well pleased with how she turned out. π Agree that the weather is is abysmal just now but hopefully a few good days will allow you out and about. Enjoy.
Post by sidney81 on Dec 17, 2020 20:50:07 GMT 1
Brilliant ,been following the whole build! What a lovely result π
Post by andy748 on Dec 17, 2020 21:08:52 GMT 1
Lovely job you have done there mate, credit to you. Andy.
Post by arrow on Dec 17, 2020 21:28:25 GMT 1
That looks great, we'll done.
Post by perazzi350 on Dec 17, 2020 21:35:54 GMT 1
Cool looking bike mate well done
Post by Tobyjugs on Dec 20, 2020 22:58:42 GMT 1
Great looking bike. I like The swingarm
