Post by midlifecrisisrd on Jan 29, 2019 14:32:11 GMT 1
Couple of jobs done. Bled the brakes surprisingly easy. Rear was the easiest I've experienced. Cracked the bleed nipple and the fluid ran straight through without touching anything. Also drilled the bottom yoke 😰 for the horn bracket. And a very quick service from Bob the Seat as this just turned up Steve
Post by Tobyjugs on Jan 29, 2019 16:02:31 GMT 1
Is the seat original or one of the repro makes
Post by midlifecrisisrd on Jan 29, 2019 16:23:50 GMT 1
Is the seat original or one of the repro makes It's a standard lc base with a conversion foam and cover so should not have fitment issues Steve
Post by Tobyjugs on Jan 29, 2019 16:25:40 GMT 1
It looks very nice. i just read the other thread ha ha
Post by Mr Kipling on Jan 29, 2019 18:15:09 GMT 1
Seat looks great....
Post by philmill on Jan 29, 2019 19:09:28 GMT 1
Love the seat, I'd like one on my 31k.
Phil
Post by mouse on Jan 30, 2019 21:11:21 GMT 1
This bike is looking amazing, love the seat too
Mouse
Post by midlifecrisisrd on Jan 30, 2019 21:17:27 GMT 1
Love the seat, I'd like one on my 31k. Phil Be careful what you wish for The ypvs Giully seat has a hump on it that's a bit Marmite I cut mine down Steve
Post by philmill on Jan 30, 2019 21:33:50 GMT 1
Oh , I don't like that, not like any other Gully seat I've ever seen. Phil
Post by philmill on Jan 30, 2019 21:34:54 GMT 1
Nice bike though!
Phil
Post by Tobyjugs on Jan 30, 2019 21:36:30 GMT 1
Beautiful looking bike. The two things that stick out which i like are the handle bar riser's and the silencers on the exhausts.
Post by midlifecrisisrd on Jan 30, 2019 21:48:15 GMT 1
Beautiful looking bike. The two things that stick out which i like are the handle bar riser's and the silencers on the exhausts. I have a stubby set of carbon silencers I was going to fit (if I ever get round to recomissioning it) but the ones on it are very sturdy with the banding About the only set that didn't go wobbly Steve
Post by Tobyjugs on Jan 30, 2019 21:51:32 GMT 1
Yes that is a problem with carbon silencers
Post by dusty350 on Jan 30, 2019 21:51:45 GMT 1
I love that 385 of yours Steve. Certainly one of the nicest Pv builds ever Dusty
Post by wallcraft on Jan 30, 2019 23:37:14 GMT 1
Hi Steve trying to find the right length clutch cable for my 421, the one you have used looks like the one I need. Any chance of the yam part number please.
Thanks Mark.
Post by midlifecrisisrd on Jan 31, 2019 10:27:51 GMT 1
Hi Steve trying to find the right length clutch cable for my 421, the one you have used looks like the one I need. Any chance of the yam part number please. Thanks Mark. I'll double check today. Think it's either 57v or 1ar model cable. You may be lucky and I have a spare lol Steve
Post by midlifecrisisrd on Jan 31, 2019 14:37:36 GMT 1
Horn bracket, new horns and carbon cover fitted Also wired up the extra bulb holder in the clock cover for the Jap speed warning light for the shift light on the Ignitech Steve
Post by Mr Kipling on Jan 31, 2019 14:44:53 GMT 1
Love the seat, I'd like one on my 31k. Phil Steve Now that's what I call a nice bike , wouldn't mind that sitting in the garage....
Post by Yogi on Jan 31, 2019 14:52:55 GMT 1
You might be on the lc dark side but you soon snaffled up that ypvs top end and that was after I left the seat locks off berti because I knew you’d want them The lc coming along nicely now though,,,,I’m not bitter
Post by midlifecrisisrd on Jan 31, 2019 15:00:16 GMT 1
You might be on the lc dark side but you soon snaffled up that ypvs top end and that was after I left the seat locks off berti because I knew you’d want them The lc coming along nicely now though,,,,I’m not bitter Lol 😆 The seat catches were for a good cause. Its your fault anyway, you sold me the rear frame section If I didn't have anything to bolt them to I wouldn't have needed them 🤣🤣🤣 Steve
Post by Yogi on Jan 31, 2019 15:10:07 GMT 1
You might be on the lc dark side but you soon snaffled up that ypvs top end and that was after I left the seat locks off berti because I knew you’d want them The lc coming along nicely now though,,,,I’m not bitter Lol 😆 The seat catches were for a good cause. Its your fault anyway, you sold me the rear frame section If I didn't have anything to bolt them to I wouldn't have needed them 🤣🤣🤣 Steve Fair point it’s not the first time I’ve shot myself in the foot
Post by Tobyjugs on Jan 31, 2019 19:41:24 GMT 1
Horn bracket, new horns and carbon cover fitted Also wired up the extra bulb holder in the clock cover for the Jap speed warning light for the shift light on the Ignitech Steve That's a great idea about the shift light. I will be using that idea, I hope you don't mind too much.
Post by midlifecrisisrd on Jan 31, 2019 20:22:06 GMT 1
Horn bracket, new horns and carbon cover fitted Also wired up the extra bulb holder in the clock cover for the Jap speed warning light for the shift light on the Ignitech Steve That's a great idea about the shift light. I will be using that idea, I hope you don't mind too much. Not at all I did the same on my 385 with an import rev counter Steve
Post by midlifecrisisrd on Jan 31, 2019 20:24:59 GMT 1
Hi Steve trying to find the right length clutch cable for my 421, the one you have used looks like the one I need. Any chance of the yam part number please. Thanks Mark. Part number here Its an n1 ypvs cable If you search on eBay Franco's Yamaha has a few at a very reasonable price, I bought a spare just in case as the pattern cable have no Teflon liner on the inner so are heavy Steve
Post by midlifecrisisrd on Jan 31, 2019 20:33:00 GMT 1
Made up a little loom to extend the indicator wiring as the mini indicator wiring is short Bit of heat shrink on the Indy wires and bolted them on Steve
Post by wallcraft on Jan 31, 2019 20:42:40 GMT 1
Hi Steve trying to find the right length clutch cable for my 421, the one you have used looks like the one I need. Any chance of the yam part number please. Thanks Mark. Part number here Its an n1 ypvs cable If you search on eBay Franco's Yamaha has a few at a very reasonable price, I bought a spare just in case as the pattern cable have no Teflon liner on the inner so are heavy Steve That's great thanks for that Steve much appreciated. Mark.
Post by midlifecrisisrd on Jan 31, 2019 23:55:21 GMT 1
Temporarily fitted the tail panel to check the tail light alignment and fit the reg plate Steve
Post by midlifecrisisrd on Feb 5, 2019 13:35:26 GMT 1
BBBAAAAAASSSSSSTTTTTAAAAARRRRRDDD
Went to wire in the Ignitech feed, oh the tail fuse is a bit loose, I'll need to close the clips a bit.
Both bloody broke
I'll be rummaging in my "old loom" box of sh1te then 🤬🤬🤬
Post by Tobyjugs on Feb 5, 2019 15:04:46 GMT 1
What does the part look like?
Post by Shytalk on Feb 5, 2019 15:42:41 GMT 1
What does the part look like? It'll be a fuse holder.
