Post by midlifecrisisrd on Sept 7, 2018 21:44:37 GMT 1
Nearly 10 years I've been knocking out RD's but all have been or at least started as a YPVS model
Then about a year ago a mate of a mate asked if I'd build him an LC hybrid
I said yes on the condition that there was no timescale. Was really looking forward to it in till the donor LC got stolen but that's another story
I bought another donor but it was a right sh1tter and the frame had been converted to a YPVS style set up. I'd already had the rgv swinger converted by no so decided to sell the matching frame/cases on and bought a UK frame
Tobyjugs very kindly sold me a set of ypvs cases at "mates rates" so fitted the swinger and a new yss shock along with an old ypvs front end and a mocked up engine
Sent it off to mutts for a set of stainless GP pipes to fit the no rearset
I'd best get some pics, back in a mo
Post by midlifecrisisrd on Sept 7, 2018 21:48:42 GMT 1
Pics of the pipes on mocked up chassis Steve
Post by midlifecrisisrd on Sept 7, 2018 21:53:34 GMT 1
Engine build My donor crank was toast, only the centre pin was usable so nearly all new - ouch Picked up a nice top end. Mildly ported on 0.25 bore a mere 500 miles ago and quality Vertex pistons Steve
Post by donkeychomp on Sept 7, 2018 21:53:40 GMT 1
Ooh nice! More pics please.
Post by midlifecrisisrd on Sept 7, 2018 22:02:52 GMT 1
Had to buy a stainless side stand from Dean at billet world to clear the rearsets. Black anodized billet yokes from a spondon440 and gsxr400 forks Forks had been stripped, machined on a lathe then re anodized gold. Rechromed stanchions, fully serviced. Front wheel came from an RF600 so same fitment as RGV but 3.5 inch rim Swinger is RGV banana converted by NK then powder coated "black chrome" before having a Tyga carbon cover kit fitted Rear wheel is GSXR 400 with a 400 bandit sprocket carrier and GS 500 39 tooth sprocket Steve
Post by midlifecrisisrd on Sept 7, 2018 22:10:01 GMT 1
I had clocks from the donor bike but cases were cracked New cases from Norbo seemed to be all they needed as apart from needing the inside of the glass cleaned, even the red line was good How wrong could I be, opened them and the white cases were smashed to bits I was very kindly gifted a Speedo and tacho that needed work from spondon440 so I stripped them and made a good pair out the 2 Bracket powder coated and an extra bulb holder fitted into the extra jap spec speed warning lens for a shift light Fitted along with a new ignition switch Steve
Post by oldbritguy on Sept 7, 2018 22:14:45 GMT 1
Looking brilliant so far. This will be a stonkin' bike when finished Keep the pics coming
Post by midlifecrisisrd on Sept 7, 2018 22:15:18 GMT 1
Billet headlight brackets fitted, just a bit worried about clearance. I'll have to fit the old tank to check All new panels away being painted Carbon headlight bowl looks good, cheers Dusty Steve
Post by midlifecrisisrd on Sept 7, 2018 22:21:11 GMT 1
My wife's been away since Thursday afternoon so spending a lot of time on the build Fitted the carbon swing arm covers properly, had to bond the front sections on and modify some of the mounting holes slightly I bought billet chain adjusters the other day so the standard ones will be going Strve
Post by midlifecrisisrd on Sept 7, 2018 22:25:47 GMT 1
This is where I got to tonight Engine was already in the frame but I'd been waiting on the clutch case coming back from the coaters so now fitted Billet manifold and v force 4 reeds Just waiting on jets then I can fit the new PWK 28's Fitted the exhaust stubs so hopefully get the pipes fitted tomorrow Steve
Post by andy748 on Sept 7, 2018 22:28:57 GMT 1
Cracking build Steve, another belter on the way. Andy.
Post by marsbar350 on Sept 7, 2018 22:30:14 GMT 1
liking it steve can t you put the clocks n bracket back above the top yoke ?
Post by midlifecrisisrd on Sept 7, 2018 22:32:46 GMT 1
liking it steve can t you put the clocks n bracket back above the top yoke ? I thought they went under as standard I did put them above at first but as they were mounted further forward too the bracket looked very obvious I may mess around with it some more Steve
Post by veg on Sept 7, 2018 22:37:38 GMT 1
Don’t be riding it because you will be converted and you won’t go back. 4l04eva 😀
Post by JonW on Sept 7, 2018 23:30:18 GMT 1
yes they go under. Really nice build Steve, as expected of course lol
Post by marrcel on Sept 8, 2018 7:13:26 GMT 1
Wow good job👍 Even small details like the steering stoppers. Were do you get them? Or did made it yourself?
Post by dusty350 on Sept 8, 2018 8:06:36 GMT 1
Hi Steve Looks fantastic mate The carbon headlight bowl looks much better on yours !! Have you the freedom to build it how you would want it or has your mate given you a plan to work to ? Think I would struggle to hand it over once it's finished !! Dusty
Post by stusco on Sept 8, 2018 8:17:01 GMT 1
Cracking bike Steve as usual as Veg says don’t ride it ,feels half the weight of a pv
Post by midlifecrisisrd on Sept 8, 2018 9:42:57 GMT 1
Wow good job👍 Even small details like the steering stoppers. Were do you get them? Or did made it yourself? Thanks The adjustable steering stops come with the yokes Steve
Post by midlifecrisisrd on Sept 8, 2018 9:51:03 GMT 1
Hi Steve Looks fantastic mate The carbon headlight bowl looks much better on yours !! Have you the freedom to build it how you would want it or has your mate given you a plan to work to ? Think I would struggle to hand it over once it's finished !! Dusty Cheers Dusty The build came about because his mate wouldn't sell him his so wanted one like it The brief was LC, USD forks, banana arm, GP pipes and candy blue paint The rest is my choice, he hasn't even seen it yet lol. Just leaves me to it and sends money when I need it Parting with it hopefully won't be a problem, I sold the last 3 builds without riding them I'll be tempted to ride this one out of curiosity. After the theft this one is registered in my name and insured so may ride it over for an mot when done. I usually have started gearing up for the next one so distracts me The spoked wheel lc2 hybrid is after this Steve
Post by JonW on Sept 8, 2018 9:56:56 GMT 1
... I sold the last 3 builds without riding them... Steve I think this is key to not falling in love...
Post by tipfinchy on Sept 8, 2018 12:29:59 GMT 1
that looks amazing already , the lucky fella you are building it for should be on cloud nine I have just ordered some rear sets after reading your thread the other night from a couple of months back , so thanks for that it saved me asking a load of questions mart
Post by midlifecrisisrd on Sept 8, 2018 15:17:01 GMT 1
Bit of a delay in fitting the pipes. Tried to fit my brake adaptor brackets and guess what... ...they don't bloody fit. As the front wheel needs to come off to sort I needed to prop it up which ain't easy with pipes on 2 hours later the fork lowers are modified with a Dremel, the brackets are fitted and front wheel and carbon muddy on Steve
Post by midlifecrisisrd on Sept 8, 2018 16:07:48 GMT 1
Brakes fitted Steve
Post by midlifecrisisrd on Sept 8, 2018 17:23:30 GMT 1
Pipes on No problem with side stand clearance on these The centre stand brackets were cut off to allow the pipes to sit higher😬 Steve
Post by midlifecrisisrd on Sept 8, 2018 17:26:14 GMT 1
Oh and a bit of rim tape to break up the black wheels Steve
Post by midlifecrisisrd on Sept 8, 2018 18:17:04 GMT 1
Stubby cans fitted. Think it may sound a bit fruity 🤤 Steve
Post by marsbar350 on Sept 8, 2018 19:16:38 GMT 1
liking it steve can t you put the clocks n bracket back above the top yoke ? I thought they went under as standard I did put them above at first but as they were mounted further forward too the bracket looked very obvious I may mess around with it some more Steve im on about the mounting brackets that come with andys top yoke they will fit above it aswell.gives a bit more space for ignition and headlight
Post by barney on Sept 8, 2018 20:28:19 GMT 1
Looks stunning mate 👍 Where did you get the tail tidy from?
Post by midlifecrisisrd on Sept 8, 2018 21:45:46 GMT 1
Looks stunning mate 👍 Where did you get the tail tidy from? It's one of Norbo's. It's adjustable so can recess the tail light if you like Took ages to work out how it went together lol I still have 2 small brackets and a reg plate holder left. Steve
