Post by Tobyjugs on Feb 21, 2020 0:21:17 GMT 1
Do you know which way he went with the +4 crank. Was it a special crank shaft or did the tuner machine the crankcases for a YPVS crankshaft?
Post by morgy on Feb 21, 2020 9:06:27 GMT 1
Do you know which way he went with the +4 crank. Was it a special crank shaft or did the tuner machine the crankcases for a YPVS crankshaft? Machined cases...
Post by morgy on Mar 16, 2020 15:03:35 GMT 1
Not much to report!! Going is very slow due to funds at an all time low right at the time all the expensive stuff needs to be ordered and made.. Tank, Paint, Exhausts, Carbs etc...
I have managed to finally get the hydraulic clutch system fitted although it's being a pig to bleed up properly! The Front Toki 6 pots have also been a pig to bleed, but they have finally come good and i now have a good feel on the fronts.. I still need to get the rear lines made up something i have been putting off for a while as i wanted to make sure i have everything correct..
Post by dusty350 on Mar 17, 2020 8:19:04 GMT 1
Hi Mark I know how you feel ! Could be a couple of £k in that little list It's amazing how these builds just drain the money from the pot. Still, it will be an awesome special when it's done. Trouble I have is when one is done, I want to start the whole process all over again !! I'll never be "money rich" !! Dusty
Post by morgy on Apr 17, 2020 17:47:52 GMT 1
Post by philmill on Apr 17, 2020 18:29:15 GMT 1
Lovely, that looks awesome. I love the polished forks.
Phil
Post by dusty350 on Apr 17, 2020 19:29:27 GMT 1
Looking minty mint Mark, stunning Dusty
Post by morgy on Apr 18, 2020 10:33:01 GMT 1
Post by morgy on Apr 18, 2020 10:35:41 GMT 1
Post by zig on Apr 18, 2020 10:58:23 GMT 1
Great attention to detail right through your build...love it
Post by morgy on May 19, 2020 6:20:34 GMT 1
Post by rattler on May 19, 2020 11:15:06 GMT 1
Wow !! an amazing build and such superb attention to detail. Some real skills and lots of patience to create this work of art !! I like the "6 months project" bit
Post by dusty350 on May 19, 2020 14:18:39 GMT 1
Great pics Mark 🙂 Really show the lovely detail. It's up there with the best builds, for sure. Well done
Dusty😉
Post by morgy on May 24, 2020 8:55:15 GMT 1
Wow !! an amazing build and such superb attention to detail. Some real skills and lots of patience to create this work of art !! I like the "6 months project" bit Just slightly over my predicted 6 months now..
Post by morgy on May 24, 2020 8:57:33 GMT 1
Great pics Mark 🙂 Really show the lovely detail. It's up there with the best builds, for sure. Well done Dusty😉 Thanks Dusty. That means a lot... I'M STILL STUCK ON THE COLOUR SCHEME!!!!!!
Post by dusty350 on May 24, 2020 9:14:51 GMT 1
Don't go standard !
Post by dusty350 on May 24, 2020 9:21:19 GMT 1
My 400 hybrid colour scheme will be standard decals over non standard paint. I'm thinking Ford "Tangerine Scream" this time with black wheels, engine cases, frame etc, so somewhere between a Kenny Roberts yellow and the Orange I had on my last Lc hybrid $_86[1] by dusty miller, on Flickr Dusty
lcfc
Post by lcfc on May 24, 2020 12:05:18 GMT 1
Top notch build the detail is excellent, well done. Dusty I did mine in tangerine scream with kenny decals, the pic doesnt show the colour very well it looks much better in the flesh.
Post by morgy on May 24, 2020 14:36:41 GMT 1
I've been over and over different colour options even got to a spray out from Mark cordwell but now gone off that colour a bit back to the start for colours!! I still need to order a new tank first anyway..
New seat foam is on order with norbo, I need a colour choice so i can chose the material for the New custom seat cover.
Post by 1966baz on May 24, 2020 16:59:14 GMT 1
I are really doing a fantastic job on everything. Keep up the good work morgy.
Post by morgy on May 27, 2020 7:27:10 GMT 1
Well it seems the old girl is suffering a little with incontinence, First off water pump plate was slightly bent/warped now i am on the second Gearbox Gasket i bought from norbo and she still has a minor drip of Gearbox oil.. All the bolts have been torqued up to equally to 8NM , All nipped up by hand first. There was me thinking i was going to have issues with the clear window!!
I have put a straight edge and also cleaned up both gearbox and cover faces to make sure there was no stove enamel or gime causing the leak but now i am stumpt!!
Post by Tobyjugs on May 27, 2020 20:29:18 GMT 1
I normally stick the gasket to the cover side with Loctite 5910 sealant. Its more like a glue. Then on the other side i tend to put a smidge of non hardening sealant on the engine where the 2 halves are butted together.
I do the above to cut down on the chance of leakage and i don't find it a problem if the gasket stays on the cover when i remove it.
Post by stamfordcowboy on May 28, 2020 3:45:39 GMT 1
Great build. A real inspiration for me
Post by morgy on May 28, 2020 6:31:51 GMT 1
I normally stick the gasket to the cover side with Loctite 5910 sealant. Its more like a glue. Then on the other side i tend to put a smidge of non hardening sealant on the engine where the 2 halves are butted together. I do the above to cut down on the chance of leakage and i don't find it a problem if the gasket stays on the cover when i remove it. Thanks Tobyjugs I was going to use some 3bond but i never like using sealant with gaskets, I will order some more gaskets and try a gen Yam one, if that fails i will get out the glue
Post by morgy on May 28, 2020 6:38:18 GMT 1
Great build. A real inspiration for me Thanks Mate... I started of by looking at peoples build threads, Originally i wanted to do a resto until i saw some of the 4L0 hybrid builds and that was it, just been plodding along slowly getting there!!! This Forum is Great for newbies like myself for info and where to source parts or what fits with what etc..
Post by dusty350 on May 28, 2020 7:05:20 GMT 1
I tend to use sealant with gaskets - even new Yamaha ones ! The trick is to not put too much on - a very thin smear is enough on a new gasket against a clean mating surface. I know it probably isn't required but I see it as more protection against leaks, especially base and inlet gaskets where a leak could be very expensive !! Each to their own !! Dusty
Post by tipfinchy on May 31, 2020 14:23:23 GMT 1
hi mark , can I ask if you used the Brembo brake light switch with the RCS19 master , as I am after a radial master and a little put off by the length of the banjo bolt type switch that would have to be used on other brands of master cylinder.
as for your colour dilemma , with it being such a quality build I think it could look really classy with a mars or bounty standard paint scheme mart
Post by steelerd on May 31, 2020 14:26:14 GMT 1
Damn that's look truly epic mate
Post by morgy on May 31, 2020 15:05:53 GMT 1
hi mark , can I ask if you used the Brembo brake light switch with the RCS19 master , as I am after a radial master and a little put off by the length of the banjo bolt type switch that would have to be used on other brands of master cylinder. as for your colour dilemma , with it being such a quality build I think it could look really classy with a mars or bounty standard paint scheme mart Brembo front used a small micro switch not Banjo pressure switch mate..
Post by morgy on Jun 5, 2020 17:12:52 GMT 1
