Post by raven13 on Apr 23, 2013 0:46:17 GMT 1
loving the build nik. keep the pictures coming
Post by foxyjohn on Apr 23, 2013 18:57:42 GMT 1
Lookin even better
Post by JonW on Apr 24, 2013 0:41:40 GMT 1
Looks great! (as ever!)
Post by nikfubar on Apr 25, 2013 17:26:38 GMT 1
Looking good Will those carbs need to be reangled because of the lean angle ? Mmm not sure, the manifolds have been modified to make the carbs fit so this is their final position so not sure how well they will work. Other KH hybrids run them like this , we will see. The only other alternative is to go the reed valve route & the carbs could then be leveled out
Post by nikfubar on Aug 11, 2013 11:47:44 GMT 1
Quick update, picked up me pipes from Kenny fantastic job as usual, only wish I had taken my camera with me as I had to diss-assemble the bike to get it in the car Crank shaft & barrels are at PJ engineering being rebuilt & rebored, when I get them back I can crack on
Post by Ragger rd on Aug 11, 2013 11:55:10 GMT 1
Those pipes are well sexy mate. Nice project as well
Post by midlifecrisisrd on Aug 11, 2013 14:30:44 GMT 1
pipes look really good nik as does the mocked up bike
wish i could get my ts down to him for a pipe
steve
Post by turbopresh on Aug 11, 2013 17:23:22 GMT 1
Some serious work going into this lad.. welding/fab work looks sweet!
Post by nikfubar on Aug 31, 2013 20:04:55 GMT 1
Got my refurbished crank & honed barrels back today so I could do a bit more. Got the pipes dry fitted so I could reposition the side stand so it clears the left hand pipe, think I need to adjust the brackets slightly to get them sitting properly.
Post by raven13 on Aug 31, 2013 20:10:36 GMT 1
she is looking sweet nik.
Post by lcyoungboy on Sept 1, 2013 18:53:40 GMT 1
Looking great..them pipes look the business :-D
Post by jollyjoiner on Sept 1, 2013 20:10:15 GMT 1
Porn
Post by midlifecrisisrd on Sept 1, 2013 20:28:25 GMT 1
Too used to Rd's,
That crank looks wrong lol
Post by 1966baz on Sept 2, 2013 20:29:36 GMT 1
Looks great, keep up the good work mate.
Post by nikfubar on Dec 21, 2013 15:15:13 GMT 1
Well it's been a while, finally got my powdercoat back after 6 weeks so I can start assembly, still got to get spindles, bolts, spacers etc zinc plated before I can get a rolling chassis but there are a few bits I can get on with, putting the wheels together, love assembling new parts not quite the gold colour I wanted but still bling bling.
Post by Roofmonster on Dec 21, 2013 15:25:25 GMT 1
Looking good so far Nick. For what it's worth, I think you are correct with the front discs - the top one is the RHS.
oldman
Post by oldman on Dec 23, 2013 20:54:28 GMT 1
LOOKING GOOD
Post by jon on Dec 23, 2013 21:46:47 GMT 1
Nick, I quite like the gold shade of the wheels; but I don't think it it go with kwak green.
What colour are you painting the tank etc?
Will it be blue like you old one?
Post by nikfubar on Dec 24, 2013 0:43:27 GMT 1
Not sure on colour scheme, will have gold wheels & calipers, stainlessn exhausts & most of the rest of it will be black including the side panels & front mudguard so the only things left will be the tank & tail unit so I recon it needs to be white but I'm always open to suggestions
Done a bit more, assembled the newly powder coated swing arm with nice new bearings
Put together the rear light unit
Also test fitted my modified chrome powder coat grab rail well happy with how that came out, just needs a set of black plugs for the ends of the tubes.
Also took in all the spindles, bolts etc to be re-zinc plated, gonna be a 2 week wait cos of Christmas
Post by bazzer5115 on Dec 24, 2013 10:21:40 GMT 1
You should have put a zinc plating kit on your Christmas list then you could do it yourself over the Christmas break!!!! I bought one from eBay new for about £100,looks a bit Heath Robinson but gives fantastic results.
Post by Roofmonster on Dec 24, 2013 10:32:21 GMT 1
The green/gold/white scheme works well on that Headcoats.
Post by nikfubar on Dec 24, 2013 10:57:03 GMT 1
Seen that bike before it was build by Cabbie who also built the Kwickasfuki unfortunately that colour scheme doesn't float my boat Bazzer, I've got a nickel plating kit but they only want £15.00 to zinc that lot as I've done most of the prep work for them.
Post by Roofmonster on Dec 24, 2013 11:16:15 GMT 1
I'm not sure it would work so well with a black frame.
Post by nikfubar on Jan 17, 2014 23:04:37 GMT 1
Well got me bits back from the platers £15.00 bargain & had my bars re-anodised black for a fiver. Now I can start assembly, all the fixings that aren't plated I've replaced with stainless. Decided to splash out on a second hand Nitron shock, barely been used, pity you can't really see it when the panels are all on. Swinger & wheels dry fitted so I can check the alignment marks before the tyres are fitted. Tyres fitted today, bloody BT92s were so hard to fit he put a chip in the powder coat on the rear wheel with a tyre lever still he knocked £40.00 off the bill for damaging it. Notice how much weight he had to fit as well because he didn't get the dot on the tyre lined up with the valve. Also got this back today as I couldn't be arsed to prep it well paint stripper doesn't work anymore plus it was a bit rusty in places, so they stripped & zinc plated it for £20.00 won't go rusty now.
Post by nikfubar on Feb 2, 2014 12:44:44 GMT 1
Post by lolly on Feb 2, 2014 15:11:51 GMT 1
work of art ; I wish I was that talented
Post by midlifecrisisrd on Feb 2, 2014 15:57:32 GMT 1
Lookin good nik
Post by nikfubar on Feb 2, 2014 16:15:25 GMT 1
Thanks guys Used the 150 rear tyre, apparently the BT92s are a touring more than sports tyre, that's why their tough as old boos & the fitter had trouble getting them on & chipped my powdercoat still hopefully they should last a lot longer that the BT090s I got fitted to the RD, spanked after 1200 miles
Post by lcyoungboy on Feb 2, 2014 17:50:08 GMT 1
Where did ya get them indicators..going great keep it up
Post by nikfubar on Feb 2, 2014 17:57:05 GMT 1
