Wez350
Post by Wez350 on Dec 2, 2012 19:52:10 GMT 1
Yep got to agree with John Twin for me as well just suits it better.
Post by scott on Dec 2, 2012 20:44:52 GMT 1
twins do it for me
Post by wizard on Dec 2, 2012 21:03:17 GMT 1
Mono for me
Post by mikee on Dec 2, 2012 21:06:02 GMT 1
Mono for me ,the swingers too big for twin shocks
Post by JonW on Dec 3, 2012 1:46:17 GMT 1
While I love the idea of twin shocks, Im loving the clean look the mono gives...
Post by bluetzrypvs on Dec 3, 2012 2:10:48 GMT 1
i would say i think the mono shock suits the overall look better, but like anything its a personal thing. if your past builds are anything to go by this is gonna be a killer triple!
Post by bryan on Dec 5, 2012 0:05:20 GMT 1
As you are going to the trouble of updating the running gear with better forks, 17 wheels, steering damper and 4 pot calipers, stick with the mono rising rate linkadge.
Post by Deleted on Dec 5, 2012 2:01:56 GMT 1
Mono for sure.
Post by lb on Dec 6, 2012 13:28:25 GMT 1
So cool to see the October twins still hanging lol. Another wicked build thread to watch!Is there a submit button here? Mono would suit it better...
Post by nikfubar on Dec 11, 2012 22:46:16 GMT 1
Well thanks for the input guys, on both forums the majority said mono so mono it is as I really couldn't decide So made a template & cut out a couple of 5mm MS mounting plates & tack welded them on ensuring the linkage is the same orientation as it is when fitted to the original frame, also inserted a washer which will allow for the thickness of the powder coat. Next was to weld it all up properly & add some frame reinforcement plates, don't want that bar snapping off Now to fit the lovely CBR600rr shock & fabricate the top mount & would you believe it bollocks the shock reservoir prevents the battery box from going in, no way no how. Solution fit one of the only half decent shocks available without a reservoir, this is off a 600 Bandit, may get a better quality after market one later but this will do for the build. Unless anyone else has an idea how I can get round this of coarse.
Post by dusty350 on Dec 12, 2012 8:17:35 GMT 1
Hi, Fantastic build, as usual and lovely welding too. Have you considered a smaller, gel type battery that can be mounted elsewhere or on it's side in a smaller box ? When I did my 400f years ago, I had to mount the battery in the tail of the race seat. Gel batteries didn't exist back then unfortunately, but there are loads available for special builds now. Dusty
Post by foxyjohn on Dec 12, 2012 18:32:44 GMT 1
Quality build
Post by nikfubar on Dec 17, 2012 0:20:50 GMT 1
Well, decided that one of the main reasons to fit the CBR shock was that it looked good & as you can't see much of it with the side panels on, what's the point a decent Bandit shock is more than up to the task, so I've welded in a second cross brace. Then fabricated a top shock mount plenty of room for the original battery box now. On a lighter note just bought a pair of angel eye headlights, so if anyone's interested I have the other one for sale.
Post by lb on Dec 30, 2012 9:34:53 GMT 1
Post by billy on Jan 11, 2013 22:10:01 GMT 1
You know you will regret not making it a twin shock! ;D
Post by nikfubar on Jan 11, 2013 22:30:09 GMT 1
You know you will regret not making it a twin shock! ;D There are lots of things I regret but we shall see, anyway not that big a deal to change to twin shocks in the future
Post by nikfubar on Jan 16, 2013 21:49:24 GMT 1
Been doing a bit more, got some nice Dynamic rear sets off ebay. Now I know where the mounting points are gonna be I can reinforce the swing arm mounts, so I cut out some plates. Then welded it all together, looks like a battle ship, think this needs some serious grinding to blend in all the welding. Got the inlet manifolds back today from the welders, not quite the way I thought he was going to do it but very neat never the less. This is how they look with the carbs mounted, not sure if there's gonna be any issues with the angle the carbs will be at :?
Post by raven13 on Jan 16, 2013 22:51:48 GMT 1
its this sort of build that makes me miss my workshop. first thing the wife did wen i left her was strip it out and sell everything. the affair i can forgive but not a hope in hell of forgiving that.
Post by billy on Jan 17, 2013 2:20:18 GMT 1
its this sort of build that makes me miss my workshop. first thing the wife did wen i left her was strip it out and sell everything. the affair i can forgive but not a hope in hell of forgiving that. F**k that sucks. Nice work btw Nick. I think it's fine if you just clean the surface of the welds up a little with a flap wheel, just take the worst bumps off and call it a day. No need to grind them flush with the sheet metal imo (if that's what you had in mind) as it'll look miles better when the paint comes on anyway. The biggest reason I'm against ground down welds is because, not only could it weaken the part (not that it matters on THAT particular part you've welded though), but it is also rather suspicious. It'll definitly lower the value of the bike as anyone with welding experiences in their background would hesitate on buying a bike with ground down welds, or welds that has in any way been covered/hidden, as they then have no idea of the quality of the welds. So.. Touch the welds up a little on the surface, but try leaving as much of them visible as possible.
Post by raven13 on Jan 17, 2013 3:06:50 GMT 1
+1 on the welds ;D
Post by Norbo on Jan 17, 2013 12:04:11 GMT 1
You have to much time on your hands.LOL its coming along niceley mate love the rear sets and the frame welding it a pro job.
Post by ste0070 on Jan 27, 2013 10:00:47 GMT 1
Looking a tidy build, nice work.
Post by raven13 on Jan 27, 2013 12:22:50 GMT 1
do you still have the spare angel eye headlight Nik? if so how much?
Post by nikfubar on Jan 28, 2013 0:43:37 GMT 1
do you still have the spare angel eye headlight Nik? if so how much? Sorry, sold it on evilbay
Post by nikfubar on Jan 29, 2013 23:04:12 GMT 1
Been doing a bit more, got the fork bottoms vapour blasted & anodised black, unfortunately Kawasaki didn't use very good quality ali & they came out matt so I clear coated them with petrol resistant laquer, should be ok when polished (see the difference ) Also my new seat arrived from Bobtheseat off ebay, nice seat but it sits a bit higher than the original so gonna take some fettling to make it fit properly
Post by flames on Jan 29, 2013 23:08:22 GMT 1
i wish i had half the talent you guys on here have got.
Post by foxyjohn on Jan 30, 2013 13:21:01 GMT 1
Lookin good very good
Post by nikfubar on Mar 11, 2013 23:03:51 GMT 1
Post by kennyroberts on Mar 12, 2013 0:00:02 GMT 1
Tidy work ! the gold on them calipers looks well nice.....mmmmmm sparkley!
Post by nikfubar on Apr 23, 2013 0:08:59 GMT 1
