Post by nikfubar on Oct 28, 2012 19:22:25 GMT 1
Well here we go on hybrid No 4 When I was 17 I had a lovely blue KH250 which was the fastest 250 around, found out why when I seized it up, it had a 350 top end ;D So this will be a 35 year old bike upgraded with parts of a 20 year old bike. KH250 frame, 350 engine with KR1s running gear. Started with this pile of shit sold all the bits I didn't need & ended up with a free bike ;D First thing to do was to get the KR1s swing arm in the frame, the arm was only 2mm too wide so ground down the frame mounts & beat it with a big hammer a bit . Now these look far to flimsy like LC ones, so opened up the spindle holes to 20mm & welded on spacers to suit the length of the spindle. Later I will weld on outer plates like the YPVS frames to beef it up Next job is to fit the yokes, I found the stem was 25mm too long so cut 25mm out the middle, fitted a 50mm long internal plug inside the stem to make sure it remained straight then welded it back together. Ground down the excess weld, new taper bearings to suit & jobs a good un also gonna fit this steering damper.
Post by marsbar350 on Oct 28, 2012 22:53:47 GMT 1
nice work and nice calendar ;D ;D ;D
Post by JonW on Oct 29, 2012 12:40:16 GMT 1
very excited to read this... keep it comin Nik!
Post by foxyjohn on Oct 29, 2012 13:33:12 GMT 1
This is going to be a crackin hybrid looking forward to seeing it finnished
Post by rivergypsy on Oct 29, 2012 14:16:36 GMT 1
Nice work, and ditto to the calendar
Post by mikee on Oct 29, 2012 21:57:32 GMT 1
Enjoying this , get on with it
Post by midlifecrisisrd on Oct 30, 2012 15:03:50 GMT 1
Nice work so far Nik Like the way you do things, don't just make things fit but make them right. Some would have just drilled out the frame without reinforcing it. Steve
Post by foxyjohn on Oct 30, 2012 18:10:38 GMT 1
Are you going to use twin shocks on the Kr1s swing arm
Post by nikfubar on Oct 30, 2012 18:51:06 GMT 1
Are you going to use twin shocks on the Kr1s swing arm I was thinking about it & it would look right on this bike but getting a pair of smart looking shocks your talking Ohlins, loads o money so afraid I going down the mono shock route, picked up this almost mint shock from a CBR600RR should do the job nicely
Post by raven13 on Oct 30, 2012 19:23:03 GMT 1
nooooooooooooooooooooooo stick it out for twins...................
Post by nikfubar on Oct 30, 2012 22:27:59 GMT 1
nooooooooooooooooooooooo stick it out for twins................... Mmm thought people would say that this could get expensive. Been playing with the top yoke, drilled it out for risers, cut off the old ignition switch lugs, drilled & tapped a couple of holes for the clock mounts. Got a cheap set of fatbars & risers off the bay, dry assembled the KR1s forks to see what she looked like. First problem, I have to have the pre-load adjusters wound all the way in
Post by midlifecrisisrd on Oct 31, 2012 8:35:11 GMT 1
Post by midlifecrisisrd on Oct 31, 2012 9:09:12 GMT 1
Post by nikfubar on Oct 31, 2012 17:33:14 GMT 1
Post by midlifecrisisrd on Oct 31, 2012 19:05:46 GMT 1
They do look good and if you consider there are 2 for that price with adjustable damping then good value Steve
Post by foxyjohn on Oct 31, 2012 20:06:36 GMT 1
Nik the build is yours the KR1s swinger is gagging for twin shocks and you will have a show stopper & winner
Post by nikfubar on Oct 31, 2012 20:31:47 GMT 1
Cheers fellas anyone wanna buy a monoshock
Post by bare on Nov 6, 2012 3:27:19 GMT 1
[quote author=nik board=hybridchat thread=17948 post=155706 so afraid I going down the mono shock route, picked up this almost mint shock from a CBR600RR should do the job nicely [/quote] Hopefully so. Certainly does the job in MY Cbr600RR :-)
Post by Norbo on Nov 7, 2012 9:15:14 GMT 1
I love the look of them black shocklers with the can on so cheep as well . not sure how good they would be as well but they do look nice.
Post by nikfubar on Nov 7, 2012 20:52:09 GMT 1
These arrived today from the good old US of A ;D 350 pistons, barrels & heads. Apparently they bolt straight onto 250 crank case. They were a bargain & rare as hens teeth over here so I was well happy to get them for £160.00 that was until Mr Turpin from the bloody inland revenue decided to charge me customs duty, import VAT & a clearance fee to the sum of £64.00 thievin b*****ds
Post by JonW on Nov 8, 2012 12:19:29 GMT 1
Still a bargain at 200 notes I reckon Nik.
Post by nikfubar on Nov 9, 2012 23:47:50 GMT 1
Well done a bit more didn't like the position of the risers so I've moved them to miss the pre-load adjusters & welded them on to the top yoke. Also fabricated a clock mount bracket to bolt onto the bottom of the yoke, both should look good when their powder coated ;D Got a nice pair of headlamp brackets off the bay. Now this is all in place I can fabricate the steering stop/damper bracket & the front end fab will be finished
Post by marsbar350 on Nov 10, 2012 0:11:09 GMT 1
the head light brackets look real period nick once rode a kh500 without a steering damper :ogood choice in fitting one
Post by scott on Nov 13, 2012 19:39:29 GMT 1
lookin nice nik,love the headlight brackets
Post by grunt33 on Nov 14, 2012 21:42:43 GMT 1
Looking good
Post by nikfubar on Dec 2, 2012 13:43:21 GMT 1
Post by raven13 on Dec 2, 2012 14:00:27 GMT 1
for me its got to be twin shock.
Post by Shane on Dec 2, 2012 14:03:54 GMT 1
Liking the Monoshock more Nick..Just looks a bit cleaner.
Post by flames on Dec 2, 2012 14:07:34 GMT 1
mono for me
Post by foxyjohn on Dec 2, 2012 19:20:10 GMT 1
Said it before & i will say it again twin shocks
