Post by midlifecrisisrd on Feb 23, 2021 19:33:10 GMT 1
£1500 rebuild but rusty head bolts? ?? I was biting my tongue If I'd paid 1500 for a rebuild I'd have expected a lick of paint Steve
Post by liffy16 on Feb 23, 2021 19:44:02 GMT 1
Hell fire gunner who did the rebuild Steptoe and son?? Definitely engine out to start with !
Post by headcoats on Feb 23, 2021 19:48:21 GMT 1
See it has reed spacers, were they sealed both sides with gaskets ?
Don't run it anymore and you will have to strip top end at least
Get a Haynes manual if you haven't got one and ask loads of questions on here as this forum will talk you through it
Post by stusco on Feb 23, 2021 19:56:57 GMT 1
Make it stop!! I couldn’t turn it off quick enough sounds a bit big endy😫😩
Post by jessy03 on Feb 23, 2021 20:01:12 GMT 1
Looks like a complete strip and rebuild, no offence but it doesn’t look like a £1500 rebuild.
Jess
Post by tony2stroke on Feb 23, 2021 20:06:15 GMT 1
I would certainly try re-torque the head 1st and start it again, if still sounds the same then head off to look inside, don't rev it though unless it sounds OK, its a straw worth clutching to.
Post by midlifecrisisrd on Feb 23, 2021 20:06:38 GMT 1
For it to seize but then to start straight away makes me worry it's debris that have jammed it
Previously being dyno'd, running a bit noisey then failing so early into being opened up sound like a componant failure to me
Post by steve h on Feb 23, 2021 20:13:02 GMT 1
£1500 rebuild but rusty head bolts? ?? Thought the same as you veg. Looks like its not been apart
Post by giggsey999 on Feb 23, 2021 20:36:22 GMT 1
I did think the same about the head bolts, the corners of the bolts are shiny though so may have seen a socket not that long ago.
Post by steeley on Feb 23, 2021 20:49:40 GMT 1
Get the head off and get some pictures up .
Post by giggsey999 on Feb 23, 2021 20:59:15 GMT 1
Will do, as soon as I get time.
Post by veg on Feb 23, 2021 21:02:34 GMT 1
Whereabouts are you? Members may be able to assist even remotely. 👍 If you need a manual I’ve a spare Haynes you can foc if that helps?
Post by giggsey999 on Feb 23, 2021 21:36:01 GMT 1
That's a very generous offer, thanks but I have a Manuel, I am in Sandy Bedfordshire, the LC family seems to be more of a northan thing, not heard of any other southerners like me with LC s, they must exist I suppose. Have just been searching around on line to see where I might get my barrels re bored, will be asking for recommendations, don't mind coming north to get them done right if I have to.
Post by 29davyt on Feb 23, 2021 21:42:00 GMT 1
You’ll need to get your passport stamped matey !
Post by veg on Feb 23, 2021 21:43:28 GMT 1
Down larndan way and oop norf is where most members are, major population areas although Yorkshire seems to have a disproportionate amount.
Post by chippy348 on Feb 23, 2021 22:01:47 GMT 1
Lots of help and advise on here, please do post some photos of the piston OR pistons that have seized so i can offer some advice on what may have happened.
Post by jessy03 on Feb 23, 2021 22:03:31 GMT 1
I’m not far from you if you need a hand, TL engineering in Elstow can do you a rebore and vapour blasting.
Jess
Post by giggsey999 on Feb 23, 2021 22:15:22 GMT 1
I'm very great full for everyone's support, I will get some pics up as soon as I can, with the help of my new friend Dusty.
Post by dusty350 on Feb 23, 2021 22:26:56 GMT 1
Yep, send them to me and I will post them up if you cant. Pjme in Wolverhampton are excellent for rebores, crank rebuilds etc. As the lads say, start with the top end strip and you might get clues as to what's gone wrong, and as importantly, why. A well built engine with the "right" parts should take more abuse than what you've given it, and if it's been on Dave's dyno and had his input, you'll know it's fuelling correctly. I'd take a punt on poor quality parts used or badly fitted, but only one way to find out Dusty
Post by giggsey999 on Feb 23, 2021 22:53:51 GMT 1
Thank you, will prob be 3 or 4 days before I get chance to strip it.
Post by Shytalk on Feb 23, 2021 23:01:51 GMT 1
Also those clear oil lines are known to have poorer clamping at the spigots, could be another one to look at.
Post by 4l04ever on Feb 23, 2021 23:17:53 GMT 1
Will need to get the top end off and get some pics of the pistons. The scuffs will give you a clue as to what went on.
Did you have receipts for the work? Be worth seeing what was actually done beforehand?
Post by giggsey999 on Feb 23, 2021 23:44:11 GMT 1
Afraid not.
Post by arrow on Feb 23, 2021 23:53:25 GMT 1
Smoking heavily on start up is not necessary a sign the oil pump is working properly. What was the smoke like when up to running temperature?
Post by reedpete on Feb 24, 2021 0:15:01 GMT 1
Top off Toby time, something very defo wrong. I think it will be obvious what’s going on as soon as it’s apart. Sounds very little endy to me, maybe stretched rod eye.
If it’s any consolation, you are lucky that it’s still basically running. An aggressive lock up can lunch an engine big time.
Post by midlifecrisisrd on Feb 24, 2021 10:41:14 GMT 1
I'm with you Pete, thought it sounded like a little end hence the debris concern
Did billbot not gave similar on a fresh engine and a cheap little end
Or a nice Taiwan piston losing a skirt
Time will tell
Post by wassy06 on Feb 24, 2021 10:51:52 GMT 1
Think I’d be contacting the person I’d bought it off if it’s shat itself the first time it’s been ridden............
Post by tsa on Feb 24, 2021 11:41:43 GMT 1
Sounds like major piston slap to me, maybe skirt cracked too.
neil
my 125
Post by neil on Feb 24, 2021 18:41:06 GMT 1
I would have said piston slap aswell
Post by veg on Feb 24, 2021 18:48:36 GMT 1
Think I’d be contacting the person I’d bought it off if it’s shat itself the first time it’s been ridden............ Their response will be buyer beware, plus you’ve had it for X amount of times and it was running ok when it was dyno’ed. Got zero chance of come back this is why you need evidence of who built it? With what eg genuine yam seals? Then your visual and auditory senses used bolts etc oh and receipts Very few I’d trust to build my motor the half a dozen I would are on here 2, are professional builders one who set my bike up and 4 are amateurs but seeing their builds I’d trust them implicitly oh and they are long term members/owners.
