Post by midlifecrisisrd on Apr 11, 2020 16:51:48 GMT 1
Countersink and countersunk bolt arrived so brake pedal now clears Steve
Post by midlifecrisisrd on Apr 11, 2020 18:58:27 GMT 1
Rolled it out the shed, connected a remote fuel tank with some premix and did the first start up Oil pump bled up and all seems fine other than rev counter looks slightly keen and temp gauge doesn't work so clocks off again and I'll have to try and find another rev counter from God knows where π€¬ I've earthen the sender wire and still nothing so unless I've made a schoolboy error with the wiring the gauge is knackered Steve
Post by midlifecrisisrd on Apr 12, 2020 18:09:01 GMT 1
Fitted newly plated brackets to the seat (after I finally found a pair that fit) Steve
Post by midlifecrisisrd on Apr 12, 2020 18:13:25 GMT 1
Post by Yogi on Apr 12, 2020 18:42:29 GMT 1
SWEEEEETπ
Post by copper99 on Apr 12, 2020 19:13:57 GMT 1
Very nice indeed Steve...
Post by philmill on Apr 12, 2020 20:13:34 GMT 1
Love it, the spoked wheels just finish out off perfectly for me. 10/10
Phil
Post by veg on Apr 12, 2020 20:29:09 GMT 1
ππ oh ya
Post by donkeychomp on Apr 12, 2020 22:07:57 GMT 1
Cracking! Excuse my ignorance (and I could be wrong) but I recall PV's didn't have LC clocks. Either way who cares she's a stunner!
Post by allspeeds on Apr 12, 2020 22:34:55 GMT 1
Cool as ,really, really nice I wish I had those skills and the ability to plan and build bikes like that.
Post by tacky1 on Apr 12, 2020 22:43:03 GMT 1
Damn Steve, that bike is just class, Its just mint!!!!!
Post by midlifecrisisrd on Apr 12, 2020 22:54:11 GMT 1
Cracking! Excuse my ignorance (and I could be wrong) but I recall PV's didn't have LC clocks. Either way who cares she's a stunner! Alex You are correct, ypvs never had those style clocks but luckily the early ypvs ran a mechanical tacho drive so quite easily done. Thanks Steve
Post by oldbritguy on Apr 13, 2020 9:25:21 GMT 1
That is just "smashin' " Steve
Just need a break in the lockdown and get out and enjoy the fruit of yer labour
Well done mate, another top build
John
Post by fatfreddy on Apr 13, 2020 10:45:30 GMT 1
Stunning! You may just have inspired me to go a similar way with my LC2 build. Or to buy this bike if you decide to sell it!π Let me know if you do.
Post by midlifecrisisrd on Apr 13, 2020 11:27:52 GMT 1
Stunning! You may just have inspired me to go a similar way with my LC2 build. Or to buy this bike if you decide to sell it!π Let me know if you do. It is for sale funny enough π I have another forum member interested so he has first refusal but nothing agreed as of yet Just be warned the price is not for the feint hearted By the time I'd built the rolling chassis and fitted the newly built engine I was at Β£5k Stopped counting at Β£7k π Steve
kopite30
http://www.motomovers.uk
Post by kopite30 on Apr 13, 2020 19:19:31 GMT 1
Thatβs is stunning steve love the wheels bud
Post by midlifecrisisrd on Apr 17, 2020 20:31:12 GMT 1
Got the temp gauge working, what a faffΒ
Before I stripped the clocks I thought I'd check the wiring.
Earthed the spade at the head and got nothing
Earthed the wire in the headlight and the gauge moved.
Bugger, I remembered the loom I used had the wire with the spade cut off where it entered the loom so immediately thought it must have been because it was brokenΒ
I had run a spare wire in case I used a electronic tacho so cut the sensor wire in the bowl and joined it to the new wire. Then soldered the spade section onto the new wire
It didn't feckin work!
Turns out after me cutting the wire out the loom it was only the spade connector crimp that was faulty π€¬
Post by midlifecrisisrd on Aug 16, 2020 17:18:51 GMT 1
Been out today and did 11 miles on my private estate π¬
No problems and now provisionally sold π
Post by flames on Aug 16, 2020 17:59:13 GMT 1
Been out today and did 11 miles on my private estate Steve That is a beauty. Someone is going to be a very happy bunny. Must be gutted to sell? Hope sale goes well bud.
Post by midlifecrisisrd on Aug 18, 2020 15:47:27 GMT 1
Sale fell through so it's still mine π Fitted some Jap spec mirrors and took it for an mot Passed of course π Slight issue with it not charging the battery without the headlight on so need to swap the regulator for another 25 miles in now Steve
Post by Yogi on Aug 18, 2020 15:51:22 GMT 1
I like them mirrors
Tooo many t**ts piss people around,,f**kING MORONS π‘
Post by drc on Aug 18, 2020 17:39:08 GMT 1
Really lovely. The black looks great. Cracking job.
Post by midlifecrisisrd on Sept 6, 2020 16:50:39 GMT 1
Had a play with the wiring and now charging the battery so looks like a dodgy connection π
Then no headlight now π. Just a furry fuse so doddle to sort π
Next it won't start (did this when I was going for its mot)
Well it starts till the float bowls are empty then stops and won't restart. Hefty tap on each float bowl and it starts. Fitted new valves but seems if it lies for a while with the valves shut they stick. Hopefully use will sort that
Fitted a newly covered seat then took it out and did 50 miles.
Behaved perfectly but RH pipe resonating loudly at 3-4k
Pipe is like a wizards sleeve on the stub so I obviously didn't shove enough sealer in. Soon sort that π
Post by flames on Sept 6, 2020 17:09:09 GMT 1
I like easy fixes
Post by Oliver31 on Sept 6, 2020 17:11:19 GMT 1
It does look nice though Steve.
Post by veg on Sept 6, 2020 17:50:41 GMT 1
No problems and now provisionally sold π Steve Provisionally fecked about you mean, i blame esther rantzen and her talking dogs.
Post by veg on Sept 6, 2020 17:51:43 GMT 1
Hey steve was speaking to Nigel earlier
Post by midlifecrisisrd on Sept 6, 2020 17:54:07 GMT 1
Hey steve was speaking to Nigel earlier Interesting π§ Steve
Post by veg on Sept 6, 2020 17:55:01 GMT 1
Enlightening id say
Post by Yogi on Sept 6, 2020 18:10:00 GMT 1
Hey steve was speaking to Nigel earlier Strange you was talking to Nigel earlier π§ ,,,,he doesnβt normally say a sausage π₯΄
