Post by 17again on Oct 27, 2019 17:57:53 GMT 1
liking the build : )
Post by veg on Oct 27, 2019 18:25:49 GMT 1
Erm hello you on strike? Or had a heart attack after pricing wheels For the tr? Looks fabulous.
Post by midlifecrisisrd on Oct 27, 2019 19:47:43 GMT 1
Erm hello you on strike? Or had a heart attack after pricing wheels For the tr? Looks fabulous. Between the wheel price and dvla knocking back the 3hm1 I've had it lol I picked up the rear shock Jack up plates and spacers I've had made and the engine cases are back from vapouring tomorrow so some slow progress Steve
Post by midlifecrisisrd on Oct 29, 2019 11:48:16 GMT 1
Jack up plates and spacers fitted
Used an old shock spacer between the plates on the original mount point and got a pair of top hat spacers made to go in the holes to the rear of the mount and a pair of high tensile bolts to stop the plates rotating.
Finally a couple of spacers to go between the plate lower mount and the shock eye
Shock is now on its shortest setting and when on the stand the rear wheel is an inch off the ground (Not 3 inch on the longest setting as before)
I'd add pics but now it's tapatalk's turn to be cnuts
Apparrently I've uploaded 10 pics already this month so unless I pay 77p a month and register a card or my PayPal against Google play I can't do more
I don't have a problem paying tapatalk but what if I don't want a payment method against Google play
Post by midlifecrisisrd on Oct 30, 2019 9:24:28 GMT 1
Pics
Post by veg on Oct 30, 2019 11:09:47 GMT 1
I have had problems being logged out of Tapatalk I get notifications I can see the quotes etc then when I try to reply it says Iโm not registered? Bizarre.
Post by midlifecrisisrd on Oct 30, 2019 11:20:37 GMT 1
I have had problems being logged out of Tapatalk I get notifications I can see the quotes etc then when I try to reply it says Iโm not registered? Bizarre. I emailed them and they said I should be able to post 50 pics a month but the message I keep getting says 10 I've now found out that as my Google account is managed by my work it won't allow payment methods to be set up Now tapatalk sent me a link to upgrade without Google which I have now done I can post pics now but if I try and upload more than one at a time or upload hi res pics it says I need to be a VIP member to do it I've just paid for VIP+ ๐ Steve
Post by midlifecrisisrd on Oct 30, 2019 11:22:12 GMT 1
Cases back now too
Post by midlifecrisisrd on Oct 30, 2019 19:01:57 GMT 1
Another little piece sorted When I offered up the tdr hub to the swingarm it had 1mm play each side so I had spacers 1mm bigger made Now see the wheel is not central so 4mm off the caliper bracket (2mm off each side) and a 4mm bigger spacer for the sprocket side should sort it now Steve
Post by midlifecrisisrd on Nov 1, 2019 10:49:57 GMT 1
Got the cases and head prepped and painted now Steve
Post by veg on Nov 1, 2019 10:52:33 GMT 1
Fabulous esp love the stealth spark plugs
Post by Yogi on Nov 1, 2019 15:46:45 GMT 1
Looking good Stevo๐
That ainโt a crack in the bottom case is it๐ค
Matt ๐งธ
Post by midlifecrisisrd on Nov 1, 2019 15:52:03 GMT 1
Looking good Stevo๐ That ainโt a crack in the bottom case is it๐ค Matt ๐งธ No it's the super quality yamaha castings ๐ Does look like it mind Steve
Post by Yogi on Nov 1, 2019 16:13:07 GMT 1
Looking good Stevo๐ That ainโt a crack in the bottom case is it๐ค Matt ๐งธ No it's the super quality yamaha castings ๐ Does look like it mind Steve Just checking ๐คช It looks like the chain let go but they got lucky๐ Iโve had them like that before so it probably is yams cheap casting Matt ๐งธ
Post by midlifecrisisrd on Dec 12, 2019 22:14:43 GMT 1
Been doing bits and bobs as time allows Fitted the new spacers so rear wheel sorted Used an RD 500 torque arm for the caliper bracket as nicer than the round bar of the FZ Steve
Post by midlifecrisisrd on Dec 12, 2019 22:52:20 GMT 1
Post by dusty350 on Dec 13, 2019 8:54:14 GMT 1
Looking mint Steve Those spokeys do look good in a valve Dusty
Post by midlifecrisisrd on Dec 13, 2019 23:45:33 GMT 1
Time to stick the engine together New hot rods crank, a tube of threebond 1211 and some shiney bolts later Steve
Post by marrcel on Dec 14, 2019 14:34:01 GMT 1
Threebond1211? I assumed that the 1215 was the way to go. Can you tel us why rhe 1211?
Post by midlifecrisisrd on Dec 14, 2019 14:55:46 GMT 1
Threebond1211? I assumed that the 1215 was the way to go. Can you tel us why rhe 1211? 1211 spec says it's petrol resistant, 1215 doesn't Think 1211 is slower curing too so more assembly time Steve
Post by JonW on Dec 14, 2019 22:33:05 GMT 1
nice work Steve. I use 1211 as well, it was recommended by a builder of banshee and yps engines in the USA.
Post by veg on Dec 15, 2019 12:02:55 GMT 1
Whatโs the plan long term? Keeper or seller?
Post by midlifecrisisrd on Dec 15, 2019 15:15:08 GMT 1
Whatโs the plan long term? Keeper or seller? Probably a seller to fund the TR Steve
Post by veg on Dec 15, 2019 15:52:34 GMT 1
Crossing my fingers now for my inheritance to come through in time. ๐
Post by yamark on Dec 15, 2019 20:00:10 GMT 1
Gorgeous build and detail Steve. Following with interest. Love the wheels
Mark
Post by midlifecrisisrd on Dec 20, 2019 17:11:41 GMT 1
The primary gear key and oil/water drive I was missing turned up so fitted and torque along with the clutch centre nut Clutch plates now soaking in oil Fitted another crankcase breather spigot as I managed to break the new one They have been superseded to a black one that is tighter to fit ๐ Steve
Post by midlifecrisisrd on Dec 20, 2019 17:18:34 GMT 1
Waiting on new red pv bush o rings to arrive as only got pattern ones which are crap and even Yam have superseded to a black over sized ring which doesn't fit well. Luckily I had a full set of bushes that measure 17.2mm and under so don't have to buy new ones for this build Fitted the valves in the barrels to save a little time when the rings arrive The barrels are freshly bored to 0.75 over but was a bit annoyed as one was 0.00 and the other 0.25 and they looked fine but hey ho they said they needed it to get them true. Hopefully get the motor finished and fitted over the holidays ๐ Steve
Post by veg on Dec 21, 2019 12:01:53 GMT 1
If you can have it ready for around end February March time thatโll do ๐
Post by midlifecrisisrd on Dec 21, 2019 15:14:19 GMT 1
If you can have it ready for around end February March time thatโll do ๐ Should be done for you by then, Hope you like chrome allspeeds ๐ Steve
Post by midlifecrisisrd on Dec 31, 2019 14:09:29 GMT 1
Top end ready to fit now Painted the "ypvs" on the head red to match the tarts handbag red hoses ๐ฌ Steve
