Post by mellow on Dec 11, 2006 16:52:22 GMT 1
so wot was up with the 2 stroke feed m8? left one smokes more on start coz chokes on left carb m8
zebrd
Time for Bed!!
Post by zebrd on Dec 11, 2006 17:23:37 GMT 1
I dont know, I basically did what Vin suggested I ran it with a little premix and disconnected the tubes to the carbs and held the pump open and the oil carried on pumping through the tubes. They are connected up now and working fine. Oh yeah I forgot about the choke on the left side. D'oh!!!!!!!!! ;D ;D
Post by nuttytart350 on Dec 11, 2006 22:39:20 GMT 1
I dont know, I basically did what Vin suggested I ran it with a little premix and disconnected the tubes to the carbs and held the pump open and the oil carried on pumping through the tubes. They are connected up now and working fine. Oh yeah I forgot about the choke on the left side. D'oh!!!!!!!!! ;D ;D dont wanna rain on yur parade....but how do you know its flowing into the carbs....cos it wasnt b 4......
Post by mellow on Dec 11, 2006 22:40:25 GMT 1
coz he can see it fillin the pipes n not flowin back?
Post by nuttytart350 on Dec 11, 2006 22:41:45 GMT 1
mmmmm
zebrd
Time for Bed!!
Post by zebrd on Dec 12, 2006 13:29:25 GMT 1
coz he can see it fillin the pipes n not flowin back? Correct. There is definatley two stoke getting in the carbs now. I can see it moving in the pipes and it is heading in the direction of the carbs.
Post by alibongo on Dec 12, 2006 14:00:03 GMT 1
Also smoke out of the pipes is a giveaway, DOH!
Post by pablo on Dec 12, 2006 21:42:08 GMT 1
its right what she's saying tho...now its got no bubbles its harder to see the oil moving ;D...was the carb blocked where the oil feeds in then?...im wondering why the oil moved up the pipes when they were off,but not when they were on and 2 strokes smoke for ages on tickover even when they have no oil in them...the pipes do that ...careful ZEB...i do hope its all sorted properly for you fellah...not trying to scare you
Post by mellow on Dec 12, 2006 22:09:01 GMT 1
if its like all the others with clear pipes it will run back down a bit when not in use so he will see
Post by nuttytart350 on Dec 12, 2006 23:17:24 GMT 1
its right what she's saying tho....im wondering why the oil moved up the pipes when they were off,but not when they were on thanks pabs.....that would worry me.....
Post by mellow on Dec 12, 2006 23:21:02 GMT 1
Post by pablo on Dec 12, 2006 23:21:28 GMT 1
ive bled a couple n ive never had to remove the tubes...just undid the screw on the pump n let it drain for a bit,then start him up and tug the cable so the pumps full on...im worried the oil jets are blocked where they go into the carbs
Post by nuttytart350 on Dec 12, 2006 23:25:46 GMT 1
Also smoke out of the pipes is a giveaway, DOH! that could b from the pre-mix...
Post by pablo on Dec 12, 2006 23:29:20 GMT 1
Also smoke out of the pipes is a giveaway, DOH! that could b from the pre-mix... they smoke for ages due to the oil in the exhaust pipes...
Post by alibongo on Dec 13, 2006 9:43:50 GMT 1
Also smoke out of the pipes is a giveaway, DOH! that could b from the pre-mix... I was just being a mong.
zebrd
Time for Bed!!
Post by zebrd on Dec 13, 2006 10:10:15 GMT 1
its right what she's saying tho...now its got no bubbles its harder to see the oil moving ;D...was the carb blocked where the oil feeds in then?...im wondering why the oil moved up the pipes when they were off,but not when they were on and 2 strokes smoke for ages on tickover even when they have no oil in them...the pipes do that ...careful ZEB...i do hope its all sorted properly for you fellah...not trying to scare you I used a very very small amount of 2 stroke for premix and this should be out of the system by now, if not the weekend. I think the fact that I originally didnt have the inlet rubbers that sit between the carbs and the airbox fitted might have been the cause as I was unsure if I would have to balance the carbs again. But thank you all for you concern. I will run it for a good length of time and keep a eye on the oil feed pipes.
Post by mellow on Dec 13, 2006 16:54:49 GMT 1
that's it zeb u tell 'em ;D
zebrd
Time for Bed!!
Post by zebrd on Dec 13, 2006 16:58:23 GMT 1
that's it zeb u tell 'em ;D No I appreciate the concern. Damn decent of them mellow. I will give an update on this saga at the weekend, oh and I will video the bike running for you. It does sound gound Mellow. It brings back distant memories from nearly a year ago when it was last running. ;D
Post by mellow on Dec 13, 2006 17:00:30 GMT 1
u got standard pipes on? they do sound ok..........brings it all back if u get a vid of u ridin past..lovely sound
zebrd
Time for Bed!!
Post by zebrd on Dec 13, 2006 17:16:14 GMT 1
The bike cant be ridden as: A) the chain and rear sprocket are not fitted yet. (Im waiting to get the wheels sorted first. B) There are no brakes on the bike. ;D And yes I would crash it. ;D
Post by alibongo on Dec 13, 2006 17:39:09 GMT 1
that's it zeb u tell 'em ;D Shut it Beefer! ;D
Post by vin on Dec 13, 2006 18:22:14 GMT 1
Zeb it wouldn't harm to have a quick look at the plugs I know it's not a proper plug chop but it should give you enough info to put your mind at rest
Post by mellow on Dec 13, 2006 22:08:05 GMT 1
that's it zeb u tell 'em ;D Shut it Beefer! ;D MMOOOOOOOOOOOOOOOOOOOOOOOOOOOOSE ;D
Post by nuttytart350 on Dec 14, 2006 10:10:19 GMT 1
I was just being a mong. welcome alimongo....you'll fit right in.... ;D probably between the beefers n the moooooose.....
Post by alibongo on Dec 14, 2006 14:33:23 GMT 1
Jobs a good un eh?
zebrd
Time for Bed!!
Post by zebrd on Dec 21, 2006 14:01:21 GMT 1
No rest for the wicked. Over christmas we plan on doing the wheels and brakes and then in the new year sort out the bodywork. Merry Christmas everyone. Zeb & Rufarse.
Post by vin on Dec 21, 2006 19:00:30 GMT 1
Merry Christmas Zeb and Rufarse ;D hope the rest of the build goes smoothly for you guys
Post by mellow on Dec 21, 2006 23:32:30 GMT 1
still waitin zebs
zebrd
Time for Bed!!
Post by zebrd on Dec 22, 2006 11:18:11 GMT 1
what for mate? The video? I will redo it over the xmas break.
Post by mellow on Dec 22, 2006 16:52:12 GMT 1
ok ;D
