zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 22:44:31 GMT 1
I will connect the indicators tomorrow but I wouldnt have thought that not having the front indicators on would stop the bike from starting. Although stranger things have happened at sea. ;D
Post by mellow on Nov 20, 2006 22:45:24 GMT 1
look for the single black wire floatin round up front m8..........it goes to ur ignition/kill switch AND clocks
Post by mellow on Nov 20, 2006 22:46:54 GMT 1
me number is 07885 7
Post by scott on Nov 20, 2006 22:47:09 GMT 1
sorry to butt in chaps,but are you sure that all the electrical bits are ok like cdi and coil....etc.was the bike runnin before
Post by mellow on Nov 20, 2006 22:50:27 GMT 1
It was modified before I had the bike, the wires must have been correct as the bike did run before the rebuild. ;D
Post by mellow on Nov 20, 2006 22:51:34 GMT 1
i reckon u just missed a single black earth m8 n maybe the indicators are'nt completeing the earth circuit
Post by scott on Nov 20, 2006 22:52:35 GMT 1
It was modified before I had the bike, the wires must have been correct as the bike did run before the rebuild. ;D :-Xsorry i'll shut up now my next line was,i've got 2 of everthing if you want to try em
zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 22:53:24 GMT 1
Post by mellow on Nov 20, 2006 22:53:43 GMT 1
u wanna swap one of ur carbs so i can have a matchin pair?
Post by nuttytart350 on Nov 20, 2006 22:55:57 GMT 1
Would I need to remove the paint under this black wire (by the rectifier) to make a better connection? bloody right....metal 2 metal contact is best...
Post by scott on Nov 20, 2006 22:56:09 GMT 1
u wanna swap one of ur carbs so i can have a matchin pair? who me
Post by mellow on Nov 20, 2006 22:59:00 GMT 1
yeah u ;D as long as u aint sprayed the thread of the bolt u should b ok. im still goin for a single black up front
zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 22:59:51 GMT 1
Would I need to remove the paint under this black wire (by the rectifier) to make a better connection? bloody right....metal 2 metal contact is best... We will check the black wires tomorrow and get a better connection on the earth. And fit the front indicators.
Post by scott on Nov 20, 2006 23:05:45 GMT 1
u wanna swap one of ur carbs so i can have a matchin pair? i'll check the numbers on em if ya want,but would av thought the numbers are the same as mine
Post by mellow on Nov 20, 2006 23:07:31 GMT 1
i got 1ua 00 n a 1ua 10............one has press in power jet one has screw in
Post by scott on Nov 20, 2006 23:09:25 GMT 1
i got 1ua 00 n a 1ua 10............one has press in power jet one has screw in yeah,but which numbers are on which carbs
Post by mellow on Nov 20, 2006 23:10:49 GMT 1
dunno cant remember now ;D
Post by scott on Nov 20, 2006 23:13:57 GMT 1
i'll av a look when i get chance and pm ya when i know if ya want
Post by mellow on Nov 20, 2006 23:15:33 GMT 1
no rush...................they still on bike hopin for few more runs out yet b4 winter
Post by mellow on Nov 23, 2006 17:24:26 GMT 1
cummon zeb...............expected a "WHOO HOO ITS RUNNING" sentance by now
zebrd
Time for Bed!!
Post by zebrd on Nov 23, 2006 23:07:51 GMT 1
Havent had much time to work on the bike as I have been working away. Changed all the fuses and the powervalves wurrs as normal. WOOHOO!!!!! No neutral light though, but the bike maybe in gear as I havent connected the gear lever yet. Just got to fill the radiator and fit the exhausts now. All this will be done Saturday morning and then I will kick it over and see if it runs. (fingers crossed again) ;D Thanks for all your help guys, will either be laughing and smiling or crying on Saturday, either way beer will be involved. ;D
Post by mellow on Nov 23, 2006 23:40:15 GMT 1
oi zeb fone me up n let me hear it start m8 ;D im sure it will b fine
zebrd
Time for Bed!!
Post by zebrd on Nov 25, 2006 19:23:02 GMT 1
Hiya
Got the radiator sorted and the exhausts on now. But I tested the electrics out and every time I press the horn its blowing the 5 amp fuse, also turning the lights on caused the same thing. I think I will have to clean the switchgear again.
Now on the petrol tank there are 2 connections but I only have one pipe from the carbs, and which way round should the pipe(s) go.
Cheers
Zeb
Will battle on tomorrow afternoon to see if I can get the bike to run.
Post by vin on Nov 25, 2006 20:38:57 GMT 1
The larger of the two connections is the fuel feed pipe and the other is the vacuum pipe that connects to the inner side of the right hand (non choke side) carburetor.
I will try and find a picture as I know theres one on the RD forum somewhere!
zebrd
Time for Bed!!
Post by zebrd on Nov 25, 2006 21:45:20 GMT 1
Thanks vin a pic would be appreciated Ta.
Post by mellow on Nov 26, 2006 10:32:38 GMT 1
the larger pipe goes on the front stub of the tap and the smaller one goes from smaller rear stub on back end of tap to the inside of the right hand card onto a stub below the balance pipe between the two carbs. i got a pic sumwhere if u cant understand my typin m8
Post by mellow on Nov 26, 2006 13:47:29 GMT 1
here ya go zeb.............ignore the big bracket thing. the vacum outlet is the one with red dots on it n the BIG yellow arrow m8 ;D
zebrd
Time for Bed!!
Post by zebrd on Nov 26, 2006 15:06:43 GMT 1
Thanks mate. Will have a look at this later.
What I did to overcome it was fit my 350R fuel tank (no vacum) but the fuel did not flow into the carbs. I take it this was because there was no pipe on the vacum.
I will transfer the fuel to the F2 tank and fit the pipe to the carb when I get home (im at work at the moment)
Post by mellow on Nov 26, 2006 21:52:46 GMT 1
work on a sunday thought i was the only one to do that wot do u do?
zebrd
Time for Bed!!
Post by zebrd on Nov 26, 2006 22:18:22 GMT 1
Im an estimator of facades. (I price up elevations of buildings basically) ;D Bad Bad News Im afraid.Spent 3 hours on the bike, connected the pipe from the carb to the vacum connection on the tank, got a fuel filter off norbo which p*ssed petrol everywhere so back to the old fuel filter. Put the tank on primed kicked it over several times and the fuel only went to the filter not into the carbs and now the kick start has siezed up or come out of place (Im hoping the latter). So Ive got to drain the bike of two stroke, engine oil, water / antifreeze to look at the kickstart. So thats gonna set me back a couple of weeks. Mellow (or anyone) do you have a diagram how the kick start should fit in the crankcases as the haynes is shite. How the mechanism should sit is what we want. To put it midly myself and rufarse are well p*ssed off.
