Post by mellow on Nov 15, 2006 17:13:38 GMT 1
me again.been siftin through ur pics m8.............the black wire im on about is connected on the back of the coil mount m8..............or it was when DSCF0030-1.jpg was taken in that pic theres quite a few blue wires...........check they are all connected m8 - could b where ur stray one should go
zebrd
Time for Bed!!
Post by zebrd on Nov 15, 2006 17:39:12 GMT 1
Many thanks mellow. Pic DSCF0030-1.jpg was taken last night so the black wire will be in place. I will check the blue ones tonight. We will work on the electrics tonight so no doubt I will be online later seeking guidance. ;D The cancelling unit is connected to the bike. I will check these wires tonight. Thanks for the help mate.
Post by mellow on Nov 15, 2006 17:43:44 GMT 1
no worries m8. i did notice u repaired neutral wire............check u rejoined it to its original place coz that has summin to with the stand cut out m8 just giss a shout if u get stuck
zebrd
Time for Bed!!
Post by zebrd on Nov 15, 2006 23:33:57 GMT 1
Good news - we have a spark! Bad news - we've pretty much resigned ourselves that the battery is knackered! Plus, we're still having wiring issues: wire 1=yellow/black from turning signal relay wire 2=yellow/black from wiring loom wire 3=yellow/green from wiring loom - can be traced to connector attached to wiring from cancelling unit looking at the Haynes wiring diagram, the signal relay has a yellow/black which connects to what looks like a splitter connection (yellow/black and yellow/green) only as you can see on the picture, the connections on each wire wouldn't allow this, nor do we remember the bike being like this! plus I've traced the yellow/green to the cancelling unit so it makes sense for yellow/green to be attached to the signal relay, but I can't find what the yellow/black would be attached too, and in the diagram, yellow/black from that section becomes a black wire, leading to loads of stuff so no chance! Also, the blue line I've drawn in... the muppet before us had created a connector that was too short and as a result left us with a random wire - which we've now twigged is supposed to connect to the white connector at "B". what we were wondering was if we could make new connections for each individual wire, and do white to white for the 3 white wires and blue to sky blue (C) Thanks for all your help so far guys, almost there, just a little bit more and we'll finally have corrected the biggest bodge in biking history!
Post by mellow on Nov 15, 2006 23:36:05 GMT 1
zeb its l8 n i cant read all that u need the yellow/black into the yellow/green...............sorted
Post by mellow on Nov 15, 2006 23:40:28 GMT 1
ul know if its right................indicators will flash or just make a rapid clickin noise.but yellow/black to yellow/green is correct.
the other yellow/black goes to all earths like backlight bulbs/earths etc etc
zebrd
Time for Bed!!
Post by zebrd on Nov 15, 2006 23:42:24 GMT 1
PMSL - that's the missus for ya! she's the electrickery expert
Cheers Mellow, but even with the yellow/green attached it still leaves yellow/black doin naff all!
We will not be beaten, so it's back to the drawing board tomorrow night!
Post by mellow on Nov 15, 2006 23:44:05 GMT 1
dude..............DONT TRY and connect the yellow/black it does nuthin if u got self cancel unit fitted
Post by mellow on Nov 15, 2006 23:44:50 GMT 1
mine is sittin there doin nuffin ul b there forever with no result for no reason
zebrd
Time for Bed!!
Post by zebrd on Nov 16, 2006 0:27:43 GMT 1
Ok thanks mellow. Got to get the battery sorted at the weekend and then hopefully this time we can start up the bike.
zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 17:29:13 GMT 1
Am i right in thinking that you turn the fuel switch to up for prime position? I cant remember its been that long ago since the bike was running. ;D
Post by mellow on Nov 20, 2006 17:31:14 GMT 1
point it to the back i think think up is reserve
Post by vin on Nov 20, 2006 18:33:49 GMT 1
Yep up reserve and pointing back pri
zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 21:42:59 GMT 1
Thanks peeps Still no joy, have put the new battery on tonight and the bike is as dead as a doornail. The powervalves dont wirr like normal, horn, lights etc not working everything is wired up now. I think the fuses may be knackered. Was going to test them with my multimeter but I can bloomin find it. Any suggestions peeps. Im getting close to kicking this bike.
Post by vin on Nov 20, 2006 22:07:41 GMT 1
This is probably stating the obvious but have you checked you have a good connection at the ignition switch plug connector?
zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 22:08:48 GMT 1
Yes we have checked that and we have a good connection vin.
Post by mellow on Nov 20, 2006 22:10:04 GMT 1
if u have nothin workin m8 check earth n as u say the fuses. have u still got the crappy glass ones?
zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 22:12:18 GMT 1
No the wiring loom has been modified, i have the two pin blade type fuses.
Post by mellow on Nov 20, 2006 22:13:21 GMT 1
who modified it m8? have the correct wires been joined together?
zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 22:14:56 GMT 1
It was modified before I had the bike, the wires must have been correct as the bike did run before the rebuild.
Post by mellow on Nov 20, 2006 22:19:04 GMT 1
i reckon u have forgot a black wire sumwhere m8 theres a few hidin especially up the front end where headlight is
zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 22:26:59 GMT 1
The only black wires that spring to mind are the one at the back of the bike and the one on the cdi. The haynes (page 23) mentions a earth strap is connected from the battery to the gearbox is fixed and making a good contact. I dont remember seeing this on the bike before.
Post by mellow on Nov 20, 2006 22:32:16 GMT 1
just a black wire on my bat neg..no strap
Post by mellow on Nov 20, 2006 22:33:39 GMT 1
just looked at wire diagram.that could b ur problem.........dunno where u got that strap m8 or where u put it but disconnect it........i aint got it
zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 22:34:28 GMT 1
Im pretty sure all the wiring up has been done now, i will check on the black wires and make sure they are getting a good contact with the frame.
Post by mellow on Nov 20, 2006 22:36:15 GMT 1
theres 2 or three in front wire harness for indicators n summin else.check them.............i spect kill switch one is in there to all in that rubber domed shroud
zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 22:37:17 GMT 1
just looked at wire diagram.that could b ur problem.........dunno where u got that strap m8 or where u put it but disconnect it........i aint got it Mellow will you pm me your number and I will ring you, its easier I think over the phone than on here. Cheers
zebrd
Time for Bed!!
Post by zebrd on Nov 20, 2006 22:38:40 GMT 1
theres 2 or three in front wire harness for indicators n summin else.check them.............i spect kill switch one is in there to all in that rubber domed shroud Ok so I havent connected the front indicators up, will this affect all the electrics?
Post by mellow on Nov 20, 2006 22:40:51 GMT 1
ACTUALLY........................theres a single black wire i think and then a double connector...........if i remember correct one indicator goes in the double with the single black n the other indicator goes into the other single connector...........if that makes sense
Post by mellow on Nov 20, 2006 22:43:03 GMT 1
ok m8 just checked..............IGNORE wot i just said.........i was talkin shite the indicators go into the double connector..........then im sure theres another single black wire floatin round there sumwhere.
