Post by 47x on Jul 30, 2012 16:47:32 GMT 1
n2 didnt come with one,but i"ve seen a few with them??i dont know if they are 31k ones.i"ve asked norbo if they are.
Post by kennyroberts on Jul 30, 2012 22:09:10 GMT 1
If it fits mate ill do you one. And ill ship it back with the rest of your stuff and if you get hold of something im after we can come to some sort of trade im sure. But i thought yours was a F2 frame? Same as mine.if so im making a custom bellypan that suits thr bike frame and rad surround.if you would prefer one of those. Check the pics out ( when i have finished) and you can have one of these, but it will take a little longer.
Post by 47x on Jul 30, 2012 22:39:01 GMT 1
the n2 and f2 have the same frame andy,so it would be good to see what your one is like when you make it,but if you look at the black/red n2 in norbos thread in lincoln bike shop/show,it looks like its a lc2 bellypan on it,looks great m8!!!cheers for the offer andy...top man.
Post by kennyroberts on Jul 31, 2012 21:41:41 GMT 1
Mould made for the belly pan.....just neet to get it trimmed.,things going a little slower than anticipated but i should have a cast Put before the weekend
Post by kennyroberts on Aug 1, 2012 20:55:42 GMT 1
Trimmed at last....working gets in the bloody way!!!!. Will do a cast by this weekend..then hopefully a saturday morning at supermarine aero engineering for a few hours of metal related fun!!!
Post by 47x on Aug 1, 2012 23:23:50 GMT 1
looking good mate!!!!
Post by kennyroberts on Aug 3, 2012 21:16:25 GMT 1
Finally i get the bellypan cast out. And it looks like i will have to do quite a bit of remodelling to make this look good around the F2 rad. It only means a remodel newmould and another cast......nothing is quick or easy is it?
Post by kennyroberts on Aug 4, 2012 17:52:55 GMT 1
Looks like it may fit a little better than anticipated. A few bits to trim and then find a way to bolt it at the rad section Pitty i cant say the same for thr headlight fairing to make it fit and still use my clocks and f2 headllight bracket(woth a few welding adjustments to fit a round headlight.......anyone got any shortcuts or smart ideas?
Post by kennyroberts on Aug 5, 2012 21:15:52 GMT 1
Remodelled to fit the existing f2 frame with a little bit of Grp. And im well pleased, i had to bend op a frame bracket by 90 degrees but it looks kind of "factory"
Post by kennyroberts on Aug 5, 2012 21:31:38 GMT 1
Post by kennyroberts on Aug 12, 2012 10:24:37 GMT 1
Exhaust graft (of a new downpipe) worked well, after holidays onto pipe number 2.
Post by kennyroberts on Aug 13, 2012 20:49:08 GMT 1
ORIGINAL YAM TOOL KIT. ANY GUESSES ON PRICE!!! ??. CAME WITH ORIGINAL CASE .....BARGAIN £5-00, , ALL IT NEEDED WAS A COATING OF ZINC PLATE ...! Result!!
Post by kennyroberts on Aug 25, 2012 23:12:31 GMT 1
Back from holidays .....so i cam crack on again with the worlds slowest resto
Post by skidave on Aug 25, 2012 23:55:44 GMT 1
Keep going...
Post by kennyroberts on Aug 29, 2012 22:15:52 GMT 1
Post by kennyroberts on Aug 30, 2012 18:23:49 GMT 1
And now to the welder!!!!!!!"
Post by kennyroberts on Sept 4, 2012 21:13:38 GMT 1
Had to do a little remodelling on the bellypan to stop the pipes melting it. Im pleased with the results
Post by kennyroberts on Sept 20, 2012 0:05:41 GMT 1
just had a little play on photoshop for a colour scheme...this is getting pretty close,so whats the feedback, im thinking it may look a bit too much like a snake, and not a kenny eagle with a speedblock stripe.....what do you guys think?
Post by deltadave on Sept 20, 2012 22:02:33 GMT 1
Like your art work but have to agree does look a little like a snake ,You say that the tool kit was nickel plated did you do this yourself ,or get it done by someone else ,imwondering about buying a diy plating kit ,not heard if many have used one
Post by kennyroberts on Sept 21, 2012 2:10:27 GMT 1
Dave. The plating was done on a home plating kit that am Ate of mine has, it took a few attempts to get it right....(length of time in the solution, how warm to have the solution etc ) before it got as good as the plating that i paid a profassional company to do...but i have to say.the results are recomended....
And....re the snake, that was my thought....ill make the lines a little straighter to help against that...thanks for the feedback and for looking!
Post by daglad on Sept 28, 2012 18:32:09 GMT 1
Just a thought i haven't seen a wrangler pv in ages........
Post by kennyroberts on Oct 6, 2012 20:49:36 GMT 1
Post by marsbar350 on Oct 6, 2012 20:51:50 GMT 1
thats some cracking metalwork kenny is it a one off or are ya makin a couple spare
Post by kennyroberts on Oct 6, 2012 21:03:10 GMT 1
One off im afraid. It took too long and i never tooled up a jig. Im gonna sort the fairing to fit it tomorrow
Post by marsbar350 on Oct 6, 2012 21:26:35 GMT 1
i doff me hat to ya thats a load of work and can appreciate the patience,skill and bloody mindedness that went in to it
m1ke
Post by m1ke on Oct 6, 2012 21:49:32 GMT 1
Great thread, I really like your attention to detail.
m1ke
Post by m1ke on Oct 7, 2012 0:31:32 GMT 1
On a related subject, I have a pair of exhausts that are otherwise perfect, but the downpipes are completely shot.... Would you do another pair for the right money?
Post by kennyroberts on Oct 7, 2012 11:42:39 GMT 1
I bent up a set myself and they were ok. But ended up using a pair from an ebay seller that bends pipes and sells nothing but....i think his seller name was " thepipebender" . The curve was bang on......i think i showed it in my thread somewhere. It would be virtually impossible to trim them to fit your bike without having it to work with. The pipes were a bargain at less than £20 ! I think this would be the best way to go .ill certainly help out wherever i can...take a browse on the bay. And ill have another check for his details too.
Post by kennyroberts on Oct 27, 2012 17:47:32 GMT 1
Well this could be a challenge too far...but what the hell.im going for it But i couldnt leave it for £20 .IM GONNA MAKE IT FIT
m1ke
Post by m1ke on Oct 27, 2012 18:48:56 GMT 1
Im sure with some patience that will fit .
