Post by 4l04ever on Oct 28, 2023 21:04:04 GMT 1
I have an older Sealey vacuum tester, which has a big cast aluminium pump so a bit more robust than the newer ones, but any decent vacuum tester should work. The older Snap-on ones look the same as mine www.ebay.co.uk/itm/186132857658
Post by 4l04ever on Nov 11, 2023 16:49:54 GMT 1
Post by Tobyjugs on Nov 12, 2023 8:33:16 GMT 1
The clutch and clutch cover were recently fitted. Hi Rob is that gasket your design?
Post by 4l04ever on Nov 12, 2023 9:39:03 GMT 1
It is based off a 3GG clutch gasket with the external tab part removed.
Post by stusco on Nov 12, 2023 12:30:41 GMT 1
They work perfectly 👍
Post by Tobyjugs on Nov 12, 2023 16:20:14 GMT 1
It looks good
Post by 4l04ever on Nov 14, 2023 20:36:56 GMT 1
Refurbished stator wiring. Fitted new PVC tubing over wires. Fitted new connector for charge wires. Fitted on bike. All connected up now.
Post by 4l04ever on Nov 14, 2023 20:40:34 GMT 1
Pics
Post by 4l04ever on Dec 10, 2023 19:02:58 GMT 1
Fitted refurbished back wheel.
Post by 4l04ever on Dec 10, 2023 19:03:43 GMT 1
Carbs ready after a full balls out rebuild.
Post by wallcraft on Dec 13, 2023 23:20:07 GMT 1
Nice Rob, looks like your running slicks!!
Post by chrisg on Dec 14, 2023 10:46:21 GMT 1
Looking good. I do like stock bikes.
Post by 4l04ever on Dec 18, 2023 20:17:21 GMT 1
Finally got some water hose clips sorted.
Post by donkeychomp on Dec 18, 2023 22:33:38 GMT 1
Got to ask Rob, where did you get those?
Post by 4l04ever on Dec 18, 2023 23:13:32 GMT 1
I got them from my stash and had them blasted and greened.
Post by donkeychomp on Dec 18, 2023 23:31:31 GMT 1
They look the part!
Post by 4l04ever on Dec 24, 2023 22:49:16 GMT 1
Post by 4l04ever on Dec 24, 2023 22:52:10 GMT 1
Post by donkeychomp on Dec 24, 2023 23:06:08 GMT 1
Well done for not putting the brake shoe warning sticker on!
Post by 4l04ever on Dec 27, 2023 21:25:50 GMT 1
Post by 4l04ever on Dec 29, 2023 23:36:42 GMT 1
Fitted lifting handle.
Post by 4l04ever on Dec 29, 2023 23:38:56 GMT 1
Fitted radiator.
Post by 4l04ever on Jan 1, 2024 18:44:58 GMT 1
Post by 4l04ever on Jan 1, 2024 18:46:04 GMT 1
Fitted modified aftermarket throttle cable. Oil pump lined up perfect 😀
Post by 4l04ever on Jan 2, 2024 22:46:46 GMT 1
Engine tie bars fitted.
Post by acmemoto on Jan 4, 2024 17:31:08 GMT 1
Great work it looks mint!
Post by 4l04ever on Jan 6, 2024 18:03:45 GMT 1
Chain fitted
Post by 4l04ever on Jan 6, 2024 18:04:30 GMT 1
Left exhaust fitted.
Post by 4l04ever on Jan 6, 2024 18:05:08 GMT 1
Right exhaust fitted.
Post by 4l04ever on Jan 6, 2024 22:52:01 GMT 1
Got clutch functioning. I only had a silver lever for now, but will get a black one fitted soon.
