Post by 4l04ever on Jul 28, 2023 8:51:58 GMT 1
Got the swingarm setup and test fitted. Swings freely with no excessive play. Just got to fit the rubber protector and that can stay on.
Post by 4l04ever on Aug 8, 2023 21:39:04 GMT 1
Rebore will hopefully be ready on Friday Just started building a left switchgear.
Post by 4l04ever on Aug 9, 2023 18:38:35 GMT 1
Left switchgear body now built up and decals applied. Need to repair one connection.
Post by 4l04ever on Aug 14, 2023 22:53:22 GMT 1
Both switchgear now assembled
Post by donkeychomp on Aug 15, 2023 21:10:52 GMT 1
Look great Rob!
Post by bezzer on Aug 18, 2023 7:55:16 GMT 1
Great work Rob, Wheels look especially good!
Post by 4l04ever on Sept 1, 2023 21:02:01 GMT 1
Engine finally put together. Leak tested and only found 1 small leak....can you guess where from?
Post by dusty350 on Sept 1, 2023 21:04:36 GMT 1
Cross over tube joints ?
Post by 4l04ever on Sept 1, 2023 21:07:17 GMT 1
dusty Have you hacked into my CCTV again? 🙂
Post by dusty350 on Sept 2, 2023 15:29:11 GMT 1
Haha, I knew it wouldn't leak from anywhere with your gaskets fitted, so it had to be the cross over tube New clips may be enough to sort that if the rubbers are good to start with
Post by 4l04ever on Sept 8, 2023 16:59:26 GMT 1
Up on wheels now. Back one is temporary until a rear has been refurbished. Temporary handle bars as OEM ones are away being powder coated.
Post by 4l04ever on Sept 8, 2023 21:46:07 GMT 1
Got the loom on and battery tray.
Post by 4l04ever on Sept 8, 2023 21:47:14 GMT 1
Tried the side panels on.
Post by 4l04ever on Sept 24, 2023 17:13:44 GMT 1
Fitted new headlight shell, OEM handle bars, indicators
Post by 4l04ever on Sept 24, 2023 17:17:05 GMT 1
Fitted back mudguard, number plate holder and indicators
Post by 4l04ever on Sept 24, 2023 17:18:58 GMT 1
Back light, Tail and grab handle.
Post by 4l04ever on Sept 26, 2023 20:22:22 GMT 1
Post by 4l04ever on Sept 26, 2023 20:54:34 GMT 1
I just checked the timestamps. I did the full swap in two hours, but was not rushing and was messing with other things at the same time.
Post by 4l04ever on Oct 8, 2023 20:09:05 GMT 1
Popped the engine in. Pics a bit out of focus as light was fading...
Post by 4l04ever on Oct 11, 2023 22:42:01 GMT 1
Clocks fitted.
Post by 4l04ever on Oct 11, 2023 22:42:51 GMT 1
New inlet rubbers and bolts.
Post by JonW on Oct 15, 2023 0:43:04 GMT 1
great progress!
Post by donkeychomp on Oct 15, 2023 21:26:32 GMT 1
And already done 111 miles! Looks great mate.
Post by tout on Oct 20, 2023 4:14:28 GMT 1
Always admire observing somebody`s hard work whilst grabbing a minute on night shift. Not seen you for a long while in person but can see your still as keen-on
looking very nice sir Regards Tout
Post by 4l04ever on Oct 28, 2023 19:16:39 GMT 1
Been refurbing a pair of 4L0-01 carbs. Bodies have been blasted by Andy AVB. I then removed their balls. Then tapped them for M5 grub screws.
Post by 4l04ever on Oct 28, 2023 19:19:01 GMT 1
Next I took the grub screw out and gave them a bath in the ultrasonic cleaner. Then dried them off and gave the passageways a blast with the carb cleaner. Then dried off again and sprayed with WD40 and wiped dry.
Post by 4l04ever on Oct 28, 2023 19:21:04 GMT 1
Fitted jets and float valves. Vacuum tested the float valves and o-rings. All holding nicely
Post by 4l04ever on Oct 28, 2023 20:16:16 GMT 1
Set float height to 21mm.
Post by 4l04ever on Oct 28, 2023 20:22:42 GMT 1
Fitted new Oldmoto carb bowl gaskets. They fit just perfectly
Post by archloafer on Oct 28, 2023 20:33:41 GMT 1
Very nice work I have never heard of vacuum testing the float valves before. Useful knowledge. May I ask what tool it is you are using to do that?
