Post by urbantangleweed on May 4, 2024 21:23:04 GMT 1
Been wiring in the rad thermo switch on MT2 today, fan comes on a little after 78°C and switches off around 72°C. Takes a bit over a minute on tickover to bring it down that 6°C. Left the manual over-ride switch in too in case I want to operate it manually or if the thermo switch fails. Just to ease my paranoia, I also put a tell-tale "fan on" light in the dash too. Note to self: Ambient temp today was 17°C.
Post by urbantangleweed on Jun 11, 2024 17:15:03 GMT 1
Post by reedx on Jun 12, 2024 8:48:41 GMT 1
Even better - the reflection makes it look like you've got a carbon fibre mudguard! Colin
MT2
Jun 12, 2024 21:35:47 GMT 1
Post by 4l04ever on Jun 12, 2024 21:35:47 GMT 1
Where did you get that mesh from?
MT2
Jun 13, 2024 7:28:00 GMT 1
Post by urbantangleweed on Jun 13, 2024 7:28:00 GMT 1
Where did you get that mesh from? A pal has it, he makes stone guards for RD500's so I blagged a bit from him together with the edging strip for the top and bottom, the sides were from a piece of aluminium extrusion from a brush type draught excluder with the brush part removed. The mesh and edging are mild steel so it was all bonded together with hi-temp JB Weld and the channels on the side pieces crimped onto the other components for good measure, then painted with Hammerite aerosol smooth silver.
Post by urbantangleweed on Jun 13, 2024 7:30:42 GMT 1
Even better - the reflection makes it look like you've got a carbon fibre mudguard! Colin Hi Colin, It's not a reflection, and although the mudguard isn't carbon, it has a carbon like finish on the top front part. ![](https://uploads.tapatalk-cdn.com/20240613/91102396df1ceea928db094fccc45419.jpg)
