Post by lcmarky on Oct 18, 2022 15:19:41 GMT 1
Post by lcmarky on Oct 18, 2022 15:20:29 GMT 1
Post by lcmarky on Oct 18, 2022 15:20:56 GMT 1
Post by lcmarky on Oct 18, 2022 15:21:43 GMT 1
Post by evochris on Oct 18, 2022 15:22:33 GMT 1
Stunning work, and really bespoke. I can see why you called the thread a slow burner, so much special stuff to do! Thanks. I've had Covid and a slow (not yet over) recovery too, so progress has been intermittent. Next couple of weekends I'm away too so thankfully I mainly work from home and will try to get some time in the workshop. Once the squish is measured, I can sort base gaskets and look to assemble the top end. I'll probably put new bolts in too which may require some disassembly work too I guess. I have also been distracted with the thought to buy a Valve, but that was trumped with the potential offer of a 1989 EXUP that hasn't been run since 2013 - 1 owner etc that I just might be able to get my hands on locally - my fingers are very firmly crossed on this one. Will need an ignition system and some carb jets plus new Koso clock prior to hopefully firing up. Covid is still around, just seems to not be reported any more, we have some guys off at work with it, i hope you have a good recovery. First of the Exup 1000's? Great machines, i had an 88 Genesis and 91 RU, ballistic fast for their day and solid. Good luck with requiring, I would love another but 28 tyres is already too many to look after.
Post by lcmarky on Oct 18, 2022 15:23:52 GMT 1
Post by lcmarky on Oct 18, 2022 15:24:37 GMT 1
Post by lcmarky on Oct 18, 2022 15:25:16 GMT 1
Post by lcmarky on Oct 18, 2022 15:25:54 GMT 1
Post by lcmarky on Oct 18, 2022 15:26:43 GMT 1
Post by lcmarky on Oct 18, 2022 15:34:52 GMT 1
Strangely in my gasket set I have x2 base gaskets and one is 0.5mm with the other measuring 0.6mm - good eh!
Will check what I actually need and get some proper ones.
Aiming for 1.1mm - 1.2mm Squish.
Post by lcmarky on Oct 18, 2022 15:38:05 GMT 1
Thanks. I've had Covid and a slow (not yet over) recovery too, so progress has been intermittent. Next couple of weekends I'm away too so thankfully I mainly work from home and will try to get some time in the workshop. Once the squish is measured, I can sort base gaskets and look to assemble the top end. I'll probably put new bolts in too which may require some disassembly work too I guess. I have also been distracted with the thought to buy a Valve, but that was trumped with the potential offer of a 1989 EXUP that hasn't been run since 2013 - 1 owner etc that I just might be able to get my hands on locally - my fingers are very firmly crossed on this one. Will need an ignition system and some carb jets plus new Koso clock prior to hopefully firing up. Covid is still around, just seems to not be reported any more, we have some guys off at work with it, i hope you have a good recovery. First of the Exup 1000's? Great machines, i had an 88 Genesis and 91 RU, ballistic fast for their day and solid. Good luck with requiring, I would love another but 28 tyres is already too many to look after. My mate had his R1 a short while back. 50th Anniversary, 06 plate with 1500 miles or something silly - like a new bike that's just sat for years.
Post by sidney81 on Oct 18, 2022 19:45:16 GMT 1
Fantastic work there, looking forward to seeing it finished!!! ( No hurry ) 🤣👍
Post by donkeychomp on Oct 18, 2022 21:46:59 GMT 1
Nice work! How do you get the LED indicators to work properly? Do they come with some adapter gizmo?
Post by lcmarky on Oct 19, 2022 7:58:37 GMT 1
Fantastic work there, looking forward to seeing it finished!!! ( No hurry ) 🤣👍 On the road in Spring is my target ….
Post by lcmarky on Oct 19, 2022 8:00:09 GMT 1
Nice work! How do you get the LED indicators to work properly? Do they come with some adapter gizmo? Alex I have an LED specific relay that I hope will do the job. These come with an in line resistor set up, but I’m planning to ditch those in favour of the one main relay..
Post by lcmarky on Oct 19, 2022 8:15:00 GMT 1
OE head bolts
Post by lcmarky on Oct 19, 2022 8:15:44 GMT 1
Ti replacements.. Spoiling the old girl!!
Post by lcmarky on Oct 19, 2022 15:00:41 GMT 1
There will be a slight interlude in proceedings as I have now sorted the EXUP so that should hopefully be a quick turnaround to get it MOT'd and sorted - what have I just said! IMG_7725 by KTM Marky, on Flickr
Post by lcmarky on Oct 23, 2022 20:45:59 GMT 1
Ti washers arrived. Look lush.
Post by JonW on Oct 23, 2022 23:21:15 GMT 1
Thos Ti nuts look amazing!
Post by evochris on Oct 24, 2022 12:47:51 GMT 1
So does the FZR!
Post by donkeychomp on Oct 24, 2022 21:37:19 GMT 1
I agree! But perhaps a bit of reflector overkill?
Post by lcmarky on Oct 25, 2022 10:15:27 GMT 1
I agree! But perhaps a bit of reflector overkill? Alex They've already gone! Well I left the little round one.
Post by jessy03 on Oct 25, 2022 11:08:59 GMT 1
It’s coming along very nicely, do you intend to use the Nikon pipes or will you be getting a set made to suit the bigger cylinders/porting?
Post by lcmarky on Oct 25, 2022 17:55:14 GMT 1
It’s coming along very nicely, do you intend to use the Nikon pipes or will you be getting a set made to suit the bigger cylinders/porting? I shall start with the Nikon pipes..
Post by lcmarky on Nov 23, 2022 21:34:57 GMT 1
EXUP is complete and about to be moved to free up the ramp for the Hybrid.
Need to remind myself where I left off - check Squish & source decent base gaskets of the correct thickness, I think.
Need to start thinking of carb jets too..
Post by lcmarky on Nov 23, 2022 21:38:31 GMT 1
Post by lcmarky on Dec 7, 2022 10:44:30 GMT 1
Post by lcmarky on Dec 7, 2022 10:46:35 GMT 1
Anyhow.. Back on track now with the Hybrid which is on the bench again and awaiting the squish to be set, a new KOSO instrument set up & and ignition system as a starter.. Hybrid & Exup 1 by KTM Marky, on Flickr
