Post by dusty350 on Aug 10, 2021 21:14:24 GMT 1
Thought I would post this in here as the bike is basically finished now.
The build started around February 2020, but the seeds were sown a little earlier when Alex gave me a lovely 250d German frame. Went through the usual hoops to get a Uk reg, but once that was achieved I started collecting parts to build a hybrid 400. The resto section has the build thread, plus the engine build thread, and the crank rebuild thread;
rdlccrazy.proboards.com/thread/50009/next-line
rdlccrazy.proboards.com/thread/49716/rd400e-engine-rebuild
rdlccrazy.proboards.com/thread/50276/crank-rebuild
So, it started with this;
20191213_121009 by dusty miller, on Flickr
And ended with this;
20210725_091233 by dusty miller, on Flickr
I basically had to get everything to build a bike, and there is a very long list of parts that I had to source to get it built. I kept a tally of all the parts, so thought I would list them here to put you off ever building a bike from just a frame !!
Brand new parts
Allspeed exhausts - Gibsons
Ramair foam pod filters - Ramair Uk
Keihin Pwk28 carbs - Muttsnuts
N68a needles and assorted Keihin jets - Allens Performance
Billet inlets - Muttsnuts
Yamaha throttle cable - Fowlers
Throttle tube - Yambits
Throttle tube shim - Dennis Trollope Racing
Yss Shock absorbers - Brookes Suspension
Metmachex hybrid 400/Rgv swingarm - the first they've ever built - Metmachex Swingarms Ltd
NOS Rgv Vj22 rear wheel - Ebay
Suzuki cush drive rubbers - Robinsons Foundry
Rear disc - ebay
Tyga rear caliper carrier - Jap4 Performance
Brembo rear caliper - Biketorque Racing
3 x Aeroquip stainless braided brake lines + stainless Banjo's - Think Automotive
2 x Bridgestone tyres - Guildford Tyres
All wheel bearings and hub bearing - ebay
Bespoke ali undertray - BWB Engineering
Kickstart - ebay
Banshee coils - Norbo
Ngk plug caps - Norbo
Rex Speedshop Cdi - Rex Speedshop
Complete loom - ebay
Rearset foot controls - ebay
Side panel, tank, battery box and clock damper rubbers -Yambits
Billet yokes - Spondon440
Taper head race bearings - ebay
Handlebar clamp to take Koso temp gauge with dual pick up -Spondon440
Koso temp gauge - Digital Speedos
Renthal bars - Renthal
2 x switchgear - ebay
Titax levers - Titax
Yamaha clutch cable - Fowlers
Nos clock bracket - ebay
Top yoke nut - ebay
Stainless headrace cover - Norbo
Trip meter knob - Norbo
Headlight - Norbo
Headlight brackets - ebay
Horn - Yambits
Ignition switch - Yambits
Rear light - Yambits
Number plate - ebay
2 x Hi flow petrol taps - Norbo
All fuel and oil lines - Fowlers & Norbo
Speedo cable - ebay
Nos Suzuki speedo drive - ebay
Renthal grips - ebay
All engine mount plates - ebay
Chain and sprockets - Talon and ebay
Bespoke front sprocket spacer in stainless - W Taylor Engineering
Bespoke gearshaft sleeve - W Taylor Engineering
Billet front brake reservoir - Seller in Australia
Bespoke shock absorber extensions - W Taylor Engineering
2x Siberedyne clear engine covers - Simon at Siberdyne
Suzuki Rgv fork seals - Robinsons Foundry
New fork, gearbox and 2 stroke oil - ebay
Disc bolts - ebay
All bolts nuts and washers in stainless - Kempton and local fasteners supplier
New Mark Cordwell paint scheme - Mark Cordwell
Bespoke Seat cover - Frank
Stainless seat side strips - ebay
Rear brake pressure switch -ebay
2 x Long, front engine bolts - ebay
Engine mount dampers x 8 - Norbo
4 X Barrel damping rubbers - Norbo
16x Head damping rubbers - Norbo
Yamaha tacho cable - Fowlers
Clutch perch - unknown
Fork preload adjusters -ebay
Yamaha Gearbox bearings x 5 - Fondseca
Pistons, rings, little ends, circlips and gudgeon pins - PJME
Exhaust gaskets - Fowlers
Yamaha Head and base gaskets - Fowlers and ebay Germany
Yamaha inlet gaskets - Fowlers
Mitaka billet clutch basket - Muttsnuts
Clutch damper "pucks" x 8 - Muttsnuts
Ebc clutch pack complete - Muttsnuts
Gold anodised Titanium clutch pressure plate bolts - Martin at MadBiker Designs
All Yamaha seals, circlips, e clips etc - Fowlers
Neutral switch + O ring - Fowlers
Stainless head bolts x 8
Ngk plugs - Norbo
Speedo cable guide - Ebay
Side stand spring - Fowlers
Bespoke tail light bracket - Bwb
Clutch push rod - Fowlers
All Yamaha engine seals - Fowlers
Used parts
Rd250D frame 1977 - Alex
Battery box - ebay
Electrics plate - ebay
Swingarm spindle - ebay
Rgv Vj22 forks - Forum
Rgv front wheel - Forum
Rgv front wheel spindle and spacer - ebay
Rgv front mudguard - ebay
Rgv front discs - Forum
Nissin front calipers x 2 - Mouse
Rgv front wheel spindle - Forum
Petrol tank - Ebay
Oil tank - ebay
Side panel - Aircooled forum
Tail cowl - Aircooled forum
Rd400e seat complete - Aircooled forum
Speedo - Alex
Tacho - Alex
Centre binnacle - ebay
Engine ! - ebay
Gear box - ebay
Sprocket hub - Mouse
Side stand - ebay
Regulator/Rectifier - ebay
Frame cross brace - ebay
Rear brake master cylinder - Forum
Services
Powdercoated frame, wheels, battery box, electrics plate, side stand, clock bracket, clock cups - Microblast in Windsor, and Jamie McClean in Thorpe
Cerakoted Barrels and heads - Jamie McClean
Crank rebuild and rebore - Paul at PJME in Wednesfield
Crank cases vapour blasted - Jamie McClean
Side cases powdercoated - Jamie
Forks vapour blasted before polishing - Jamie
Total paintjob of all bodywork - Mark Cordwell in Derby
Oil pump total rebuild - Gary, aka Arrow, in Ellesmere Port
Frame mods including chain clearance mod, undertray, bracing and brackets - Clive at BWB engineering in Ashford
Welding - Glen Cammack
Extended Frame mounts for shock absorbers - Garry Gratton at Metmachex Swingarms Ltd
Clear clutch and generator covers - Simon at Siberdyne
Twin tap conversion on petrol tank - Clive and Glen at BWB
Rearset back plates cut on a Plasma cutter - BWB
Andy aka Spondon440 - Billet yokes and the temp gauge holder bracket are just perfect
A day on Muttsnuts dyno, getting the jetting correct and set up properly. 46.6bhp @ 7750rpm
And without whom...
Norbo - numerous parts, both trick and standard
Alex, aka Donkeychomp - for the frame, and speedo and tacho
Mouse - rear hub and Nissin calipers
Mutts - supplying the carbs and inlets, and fitting oil spigots to the inlets for me And also the dyno set up - worth his weight in Gold
Paul Vetere - awesome rebuild of the crank, and kind enough to document it so we could all learn what's involved
Arrow for finding some hard to source parts to produce a better than new oil pump
Mark Cordwell - paint that is flawless
Jamie McClean - didn't think I would find anyone fussier than me regards finish, but Jamie is !
Garry and Tamsyn at Metmachex - A great firm and a great product, and Garry is a brilliant engineer
Steve at W Taylor Engineers - knocked up the gearchange shaft support and shock extensions with perfect precision - another old school engineer worth his weight..
Frank - a golfing buddy of Yamark's, who skillfully resculptured the seat foam and made a new, bespoke cover
ReedPete - a very generous donation of a hard to find seat lock, and the last part of the jigsaw - top man
Paul Dawkins for the dating certificate, and Midlife Steve for the knowledge on how to get a registration
Fowlers of Bristol - Most Yamaha parts from stock, with next day delivery
And you lot, for continued support, interest, and continually setting the bar ever higher with your builds
Dusty
Brand new parts
Rear disc - ebay
Kickstart - ebay
Top yoke nut - ebay
Headlight - Norbo
Horn - Yambits
Number plate - ebay
Speedo cable - ebay
Disc bolts - ebay
Ngk plugs - Norbo
Used parts
Battery box - ebay
Petrol tank - Ebay
Oil tank - ebay
Speedo - Alex
Tacho - Alex
Engine ! - ebay
Gear box - ebay
Side stand - ebay
Services
And without whom...
Dusty
