Post by midlifecrisisrd on Sept 5, 2023 22:06:11 GMT 1
Cheers guys
Got a little leak in the water joint housing, hopefully nipping it up will sort it
I'll pop the exhausts off and silicone the flanges to seal them up
Then I'll stick the bodywork on, need to fit the fuel tap first
Also need to fit the side panel decals to line up with the tank
Post by lcmarky on Sept 6, 2023 9:54:15 GMT 1
I'm using the same one.. It's a bit of a wobbly fit and you'll need to faff with the W clips, but it's very bright and knocks out my DAB radio every time it's on too!!
Post by midlifecrisisrd on Sept 6, 2023 10:39:51 GMT 1
I'm using the same one..Β It's a bit of a wobbly fit and you'll need to faff with the W clips, but it's very bright and knocks out my DAB radio every time it's on too!! I've got it in a pattern rim and it fits very well Clips went in east too Steve
Post by lcmarky on Sept 6, 2023 11:26:32 GMT 1
I'm using the same one.. It's a bit of a wobbly fit and you'll need to faff with the W clips, but it's very bright and knocks out my DAB radio every time it's on too!! I've got it in a pattern rim and it fits very well Clips went in east too Steve I'm sure my rim is pattern too. Will look to get a better headlight & bowl at some point..
Post by midlifecrisisrd on Sept 7, 2023 19:39:45 GMT 1
Took the exhausts off, smear of silicone in the flanges then back on
Stripped off the water joint. Seemed well bonded to the actual joint but no adhesion to the head. New gasket ordered from Rob, I'll give it a smear of silicone to be sure
I'd also used a normal m8 copper washer which looked like it wasn't seated centrally so I've ordered a new genuine one from Fowlers
Going to screw on the new fuel tap now
Post by midlifecrisisrd on Sept 8, 2023 22:19:49 GMT 1
No gasket or copper washer yet so put the first bit of bodywork on Steve
Post by JonW on Sept 9, 2023 2:33:50 GMT 1
lovely!
Seeing the yellow reminds me I have a yellow LC at the back of the garage I really should pull out and give some love :/
Post by midlifecrisisrd on Sept 10, 2023 0:19:58 GMT 1
I never fitted the side panel decals as I needed to fit the tank onto the bike to mark up where the decals line up Popped the tank on, bit of masking tape as a guide then fitted the decals I'll get some proper pics once the fuel lines are connected and I've stuck the seat on Steve
Post by sidney81 on Sept 10, 2023 9:10:13 GMT 1
Great job Steve, especially them decals!! I wouldn't even attempt them ha ha , ππͺ
Post by midlifecrisisrd on Sept 10, 2023 13:42:42 GMT 1
Seat on
Post by JonW on Sept 10, 2023 14:03:14 GMT 1
Must almost be handover day?
Post by stusco on Sept 10, 2023 14:35:37 GMT 1
What exhausts are they? I really like them
Post by midlifecrisisrd on Sept 10, 2023 15:54:57 GMT 1
Must almost be handover day? Hopefully within the week π€ Waiting on a couple of little nylon spacers arriving to fit the reg plate. Without them the plate doesn't clear the 2 mounting bolts for the plate holder π As long as the coolant weep is sorted now it just needs the fuel lines connected to the tap then moved round the front for a trip up and down the street just to check the clutch/gearbox Quick going over the major bits with a wrench just to be sure and it can go Steve
Post by midlifecrisisrd on Sept 10, 2023 16:02:02 GMT 1
What exhausts are they? I really like them They are really nice, hug the bike well They are Swarbrick Steve
Post by midlifecrisisrd on Sept 12, 2023 16:54:03 GMT 1
Post by sidney81 on Sept 12, 2023 19:19:00 GMT 1
πππͺ, beautiful
Post by midlifecrisisrd on Sept 12, 2023 19:26:03 GMT 1
Did a massive 0.4 miles checking the clutch and gearbox.
All good π
Post by veg on Sept 12, 2023 20:03:02 GMT 1
Just remember I have a brand new xs650 hub in the garage with your name on it , just for the next one. π
Post by midlifecrisisrd on Sept 12, 2023 20:14:19 GMT 1
Just remember I have a brand new xs650 hub in the garage with your name on it , just for the next one. π Appreciate the offer π Was packing stuff up for the house move and have somehow ended up with 2 xs650 and 1 xs500 front hubs π€ͺ Steve
Post by veg on Sept 12, 2023 20:16:56 GMT 1
Veritable retirement fund then ππ I want at least 70 trillibilly pounds bigly for mine.
Post by sidney81 on Sept 12, 2023 22:02:12 GMT 1
Did a massive 0.4 miles checking the clutch and gearbox. All good π Steve the furthest this year?? πβΊοΈ
Post by veg on Sept 12, 2023 22:07:52 GMT 1
Thatβs harsh
True but harsh π
Post by midlifecrisisrd on Sept 12, 2023 22:08:46 GMT 1
Did a massive 0.4 miles checking the clutch and gearbox. All good π Steve the furthest this year?? πβΊοΈ Do you know that is true π Realised I've packed away my battery charger and I need to have my 385 running to ride it to the new house Hasn't been started this year π Steve
Post by JonW on Sept 13, 2023 0:30:19 GMT 1
Looks fantastic Steve! Well done m8!
Post by tout on Sept 13, 2023 1:37:19 GMT 1
looks a minter, very clean and tidy, excellent work Sir !
Are you fitting a chainguard or leaving without ? Tyre sidewalls to be cleaned ?
Cracking job, your M8 will be chuffed π
Post by Yogi on Sept 13, 2023 5:16:20 GMT 1
Lovely job there Steve π nice and Lean looking π
Post by mouse on Sept 13, 2023 6:35:23 GMT 1
He's a lucky mate, bike looks superb!
Mouse
Post by midlifecrisisrd on Sept 13, 2023 8:47:51 GMT 1
looks a minter, very clean and tidy, excellent work Sir ! Are you fitting a chainguard or leaving without ? Tyre sidewalls to be cleaned ? Cracking job, your M8 will be chuffed π Cheers I've kept a lookout for a chaingaurd for the 2 years I've had this and only been the same one on ebay It's just a small 1/4 piece that just covers the section over the rear sprocket It's a straight bolt on part so I'll leave it to the mate to pay the Β£60 for the one on ebay or find another And yeah, bike needs a wash to get rid of the dust and tyre fitting slop. Literally just wheeled it round the front and took the picture I'm in a rushing panic mode as moving in 2 weeks and still got a load of packing/shifting/storage of the garage and workshop π€― Steve
Post by lcmarky on Sept 13, 2023 9:24:05 GMT 1
What a lovely build - great work!
Is it deliberately sitting high or just requires the suspension bedding in?
Post by midlifecrisisrd on Sept 13, 2023 10:34:44 GMT 1
What a lovely build - great work! Is it deliberately sitting high or just requires the suspension bedding in? Thanks I don't think the perspective of the pictures help but it is on the higher setting that NK supplies but shock is on standard length I'm a regular inside leg and I can comfortably get my feet down once the suspension takes up the sag albeit not flat footed Can't remember how lanky my mate is π€£ Steve
