Post by midlifecrisisrd on Aug 27, 2023 20:44:36 GMT 1
Oil tank vent tube arrived so fitted, shoved some 2 stroke oil in, added coolant to the expansion tank and filled the gearbox with oil Steve
Post by midlifecrisisrd on Aug 28, 2023 19:35:52 GMT 1
Spannies on π Steve
Post by oldbritguy on Aug 28, 2023 20:38:53 GMT 1
Sweet.
Post by midlifecrisisrd on Aug 30, 2023 21:27:04 GMT 1
Why is it after filling with oil I find the neutral switch ain't working π
And I'd fitted the stator case and gearchange π
And the kick-start is bent
Post by evochris on Aug 30, 2023 21:47:19 GMT 1
Thatβs the fun of the build, can be annoying though. Good luck with finding the issue π
Post by oldbritguy on Aug 30, 2023 22:54:08 GMT 1
Bugger! I think yamark had the same thing with his 700 build although changing the switch on his was a bit more involved. Hopefully no more than a replacement switch and a bit of cursing Steve
Post by midlifecrisisrd on Aug 31, 2023 7:22:04 GMT 1
Bugger! I think yamark had the same thing with his 700 build although changing the switch on his was a bit more involved. Hopefully no more than a replacement switch and a bit of cursing Steve Hopefully so π Got some new switches but will need a mate round to lean the bike over to save me dropping the oil Steve
Post by sidney81 on Aug 31, 2023 8:33:54 GMT 1
I'll be there in half hour Steve ππ
Post by midlifecrisisrd on Aug 31, 2023 16:12:12 GMT 1
I know you would if you were nearer
After seeing your wheel in a lathe pic I may have a favour to ask on a couple of front wheels π
Post by midlifecrisisrd on Aug 31, 2023 16:17:01 GMT 1
Waiting for a more local mate to come back to me
Either that or the wife will be holding an lc over π€£
Got home from work sharp so whipped the kickstart off, stuck it in a vice then used an old fork stanchion to persuade it back into a more reasonable shape
Refitted then warily did the task I was trying when I realised it hit the footpeg π«£
Yes we have a spark π
Post by midlifecrisisrd on Aug 31, 2023 17:06:44 GMT 1
Ended up propping it up against the shed at a dodgy angle and get the switch changed over All working now π Managed a decent pic while it was outside π Steve
Post by arrdy350 on Aug 31, 2023 20:24:37 GMT 1
Top job Steve π It is impressive how quick some of the members of this forum build bikes/specials on here. Do you want to build mine ππ
Post by Tobyjugs on Aug 31, 2023 20:35:35 GMT 1
It looks really nice Steve
Post by midlifecrisisrd on Aug 31, 2023 20:48:24 GMT 1
Top job Steve πΒ It is impressive how quick some of the members of this forum build bikes/specials on here.Β Do you want to build mine ππ Thanks π This this has been one of my longest, it's been 2 years lol Had a couple of things on the go at the beginning so was part gathering/planning for a while Don't get as much time on them these days βΉοΈ Been busting myself over the last few months between work and trying to finish it before I move house Nearly there now, just the teething problems you get at the end of any build Steve
Post by arrdy350 on Aug 31, 2023 21:02:39 GMT 1
Top job Steve π It is impressive how quick some of the members of this forum build bikes/specials on here. Do you want to build mine ππ Thanks π This this has been one of my longest, it's been 2 years lol Had a couple of things on the go at the beginning so was part gathering/planning for a while Don't get as much time on them these days βΉοΈ Been busting myself over the last few months between work and trying to finish it before I move house Nearly there now, just the teething problems you get at the end of any build Steve I wish my was 2 years lol. I am at over 5 years just putting the engine back together π¬ then I have got to sort everything else on it it as well Carbs, brakes. Hopefully it will be done by the end of the year π
Post by donkeychomp on Aug 31, 2023 22:10:56 GMT 1
5 years? That's longer than me! But I think I might be catching you up.
Bike looks ace Steve, glad you got it sorted mate.
Post by midlifecrisisrd on Sept 3, 2023 20:16:56 GMT 1
Replacement LH switchgear arrived so swapped over the innards and refitted it Also picked up some working 3 pin genuine indy relays so fitted one of those and now have working left and right indicators Fitted the coil cover and tool tray Steve
Post by midlifecrisisrd on Sept 3, 2023 21:41:48 GMT 1
Bolted the horns on, connected them and all working Had to buy a new pair as the old ones looked like they had been dropped and bashed the outside edges which they did not take well to straightening Steve
Post by donkeychomp on Sept 3, 2023 22:23:37 GMT 1
Horny.
Post by andy748 on Sept 4, 2023 10:58:41 GMT 1
Looks great Steve, on a side note, do you have a link to the headlight you're using? Cheers, Andy.
Post by midlifecrisisrd on Sept 4, 2023 12:42:08 GMT 1
Post by andy748 on Sept 4, 2023 15:40:38 GMT 1
Yer a star Steve. Cheers.
Post by midlifecrisisrd on Sept 4, 2023 21:22:36 GMT 1
Had to do the unthinkable tonight and take a hammer to the exhausts π± They are really hugging to the bike so the spaced off hangers to get everything to clear the ridiculously wide swing arm has spaced them outward This caused 2 problems. The RH pipe was just kissing the bottom frame rail and the side stand spring lug was a good 5mm into where the pipe was I shaved the mushroom on the stand lug down flat and it still hit. Stand actually has very little slop so don't think swimming would help. Can't go external spring as it's the type with the tab Ended up taking a ball peen hammer, cutting 5 fingers off a rubber glove and stretching them over the ball. Then worked the area it was hitting very gently and worked away till I have a slight recess then touched in with some barbecue paint where the lug had scratched it. Should blend in when the paint has cured and matted in Did similar to the top edge of the RH pipe maked a shallow 30mm or so recess in it. This can't be seen when fitted Steve
Post by donkeychomp on Sept 4, 2023 23:56:34 GMT 1
Surgery is seldom painless. But if it had to be done...
Post by midlifecrisisrd on Sept 5, 2023 19:50:13 GMT 1
She lives π
Post by midlifecrisisrd on Sept 5, 2023 20:16:49 GMT 1
First time it's ran since 1992 π
Post by peddrotzr on Sept 5, 2023 20:51:14 GMT 1
looks great Fabulous news its running, a lot of work, great result
Best regards Johnny C
Post by dusty350 on Sept 5, 2023 20:53:23 GMT 1
Great news Steve She looks ace
Post by donkeychomp on Sept 5, 2023 21:34:57 GMT 1
Fan-bleeding-tastic mate!
Post by Tobyjugs on Sept 5, 2023 21:49:10 GMT 1
Nice one Steve.
We just need to see the bike fully dressed. It's like the finally of a film we are are gripping our keyboards in anticipation.
I bet your mate will be badgering you now that it's running.
