Post by pedheadfred on Apr 15, 2021 16:54:30 GMT 1
Another step forward still looking for a front mudguard there are two on eBay but expensive especially as ones cracked
Post by abar121 on Apr 15, 2021 17:31:13 GMT 1
Cool. Give them a good clean out with switch cleaner, especially the sliding switches.
Post by pedheadfred on Apr 15, 2021 17:37:01 GMT 1
It will be fully striped down cleaned possibly paint and new decals see how it cleans up 😉
Post by JonW on Apr 16, 2021 1:02:14 GMT 1
Great news on the switch, and as it matches across the loom connector you know its the right year etc.
That is actually a really nice condition switch, most of these lose their writing quickly and the sliding action of the light switch wears the black paint. I would be tempted to touch this up with some satin black paint rather than strip and repaint the whole thing, the reason i say this is that all the decals for these switches are way too fat, like they used BOLD or the wrong font when making them.
Post by pedheadfred on Apr 19, 2021 11:31:33 GMT 1
Right folks what should I expect to pay for a used original mudguard that needs painting ? Few on eBay at the moment two at £60:00 ones damaged cracked. Two at Bids ones got bracket bolted on others got it riveted on which is correct ? What would reasonable price be plus £10:00 postage
Post by midlifecrisisrd on Apr 19, 2021 11:32:42 GMT 1
85 was bolted, 86 on was riveted 🤓
Post by midlifecrisisrd on Apr 19, 2021 11:33:59 GMT 1
Don't think around the £60 up is unreasonable if not cracked
Post by pedheadfred on Apr 19, 2021 14:40:10 GMT 1
So same mudguards but one came riveted other came bolted on. £70 ones cracked which I could plastic weld and be good again but think £60 expensive for damaged muddy.
Post by midlifecrisisrd on Apr 19, 2021 16:42:24 GMT 1
It is ☹
Rob123
Post by Rob123 on Apr 19, 2021 17:31:35 GMT 1
Hi do you still need the mudguard i may have one?
Post by pedheadfred on Apr 19, 2021 20:14:23 GMT 1
Yes I do pm me
Rob123
Post by Rob123 on Apr 19, 2021 20:30:20 GMT 1
Message sent
Post by pedheadfred on Apr 22, 2021 9:45:33 GMT 1
Question folks should my bike have a cdi with a separate power valve controller? Or does cdi control the power valve aswell ? As my bike came with some mackler up none Yamaha cdi no power valve motor Iam trying to collect bits to make it all work as it should do. Thanks 👍
Post by midlifecrisisrd on Apr 22, 2021 15:49:59 GMT 1
It should have separate cdi and pv controller
Only the 88 model had a combined unit
Post by pedheadfred on Apr 22, 2021 20:17:20 GMT 1
Right thanks so two more parts required for this Rz then🕵️
Post by JonW on Apr 22, 2021 23:58:15 GMT 1
I thought only the 85 N model came with bolted on front guard? Certainly the Aussie 85 F1 came riveted.
Re the 88 CDI, thats the 3HM is it? FYI Instead of locating the 52y-50 and PV conroller you could fit a Zeel/Iggy, cheaper maybe?
Post by midlifecrisisrd on Apr 23, 2021 11:23:01 GMT 1
I thought only the 85 N model came with bolted on front guard? Certainly the Aussie 85 F1 came riveted. Re the 88 CDI, thats the 3HM is it? FYI Instead of locating the 52y-50 and PV conroller you could fit a Zeel/Iggy, cheaper maybe? I think the nut/rivet thing is strange Even if you look at the parts diagram it shows a plate with captive nuts. I've never found this. Only nuts and washers. Yes the 88 combined is 3hm1. I actually have one of them spare but got knows how compatible with the stator it is Steve
Post by pedheadfred on Apr 26, 2021 10:32:52 GMT 1
Post by pedheadfred on Apr 26, 2021 10:35:34 GMT 1
Post by pedheadfred on Apr 26, 2021 10:38:01 GMT 1
Fairing s hopefully for my Rd200 racer 😎 when I find time to look at it. Been on boil 5 yrs
Post by pedheadfred on Jun 6, 2021 22:49:52 GMT 1
Bought a powervalve control unit today from Newark jumble. Tonight I won CDI off eBay thats marked up as a 1ua-50. Will have to wait till it arrives but I think the connectors have been changed for bullet connectors. Might need help wiring up
Post by pedheadfred on Jun 7, 2021 9:08:15 GMT 1
Got a few bits from Newark Inc a motoplat race igntion for single. Some 110 80 18 rear tyres new Pirelli and a part warn race tyre plus a Michelin 90 90 18 new front tyre
Post by pedheadfred on Jun 7, 2021 9:14:40 GMT 1
Post by pedheadfred on Jun 8, 2021 11:09:06 GMT 1
Can anybody help with pic of connector colour code etc. Anybody know we're I can buy block connector like Yamaha one ?
Post by rbridd on Jun 8, 2021 18:39:56 GMT 1
Post by midlifecrisisrd on Jun 8, 2021 19:11:25 GMT 1
Red, green and brown are high/low speed windings
Orange is coil feed
Black is earth
Black/white is kill switch
Black/yellow is pv controller/tacho signal
White with green trace and white with red trace is pick up coil
Post by pedheadfred on Jun 8, 2021 21:29:14 GMT 1
Thanks for that appreciate your help
Post by pedheadfred on Jun 8, 2021 21:32:37 GMT 1
Post by pedheadfred on Jun 8, 2021 21:34:09 GMT 1
Brand new old stock off 2 different stalls but £5:00 each
Post by shaunthe2nd on Jun 8, 2021 21:44:43 GMT 1
You did well. I was at Newark and was amazed at how many private stalls there was. Bought a few bits for garage, only LC stuff I got was a UK headlight and an NOS kidney clock under case for a YPVS kidney clock. Not as cheap as yr bargains though, but still happy.
