Post by donkeychomp on Aug 6, 2024 21:26:21 GMT 1
Cheers matey. Funnily enough I just got a message saying it's being sent. Woo hoo!
Post by donkeychomp on Aug 8, 2024 20:50:30 GMT 1
It was Elsie's birthday today. Firstly all the clutch/brake bits arrived. Then 2 large boxes. Stunning. Just stunning. What surprised me is I'd forgot to drill the bolt holes in the mudguard but Mark did it for me without even mentioning it. What a top bloke. Back to the clutch I put all the new bits on and have discovered a new issue. The clutch push rod isn't pushing in. As I slide it in it is hitting something metal inside the engine. Any thoughts lads and lasses? Alex
Post by midlifecrisisrd on Aug 8, 2024 21:18:25 GMT 1
Bodywork looks brilliant
Have you used a ypvs clutch case?
Post by midlifecrisisrd on Aug 8, 2024 21:19:25 GMT 1
Just looked back and can see it's lc so forget that
Post by midlifecrisisrd on Aug 8, 2024 21:36:31 GMT 1
Is the ball bearings in place
Post by donkeychomp on Aug 8, 2024 22:02:47 GMT 1
Ah. Very good question indeed. I shall investigate tomorrow, thanks Steve.
Post by 4l04ever on Aug 8, 2024 22:22:05 GMT 1
Post by donkeychomp on Aug 8, 2024 22:33:20 GMT 1
Haha! Cheers Rob!!
Post by dusty350 on Aug 9, 2024 7:02:56 GMT 1
Paintwork looks ace as usual mate. Another big part of the jigsaw ticked off How far in does the rod actually go ? Good chance there is a witness mark where it sits within the seal. That will give you an idea of how much it is out
Post by arrdy350 on Aug 9, 2024 7:08:50 GMT 1
That paint job is stunning Alex๐ Can't wait to see it on the bike ๐
Post by JonW on Aug 9, 2024 8:17:32 GMT 1
Ohh good update....
The clutch is not just stuck plates is it?
Post by donkeychomp on Aug 9, 2024 21:07:32 GMT 1
I measured the rod today as per Rob's instructions. That's fine. Dusty popped over just now (cheers matey, glad the new clocks work) and he thinks it might be the clutch actuator itself. Could be off an A/C bike. Plus the casing itself was very awkward to fit suggesting the actuator is engaging as you fit the case! We shall see...
Post by dusty350 on Aug 9, 2024 21:21:38 GMT 1
Just got in and checked an Lc casing in the shed. I think yours has an aircooled actuator fitted in your casing - different to mine (which has 4l0 scribed on it as I thought). I think I have a spare - will check tomorrow and if so it's yours
Post by donkeychomp on Aug 9, 2024 22:23:57 GMT 1
Dusty, what can I say? Thanks mate, owe you loads. I'll ride over to your place if you like...the potholes should prove interesting lol.
Post by tony2stroke on Aug 10, 2024 10:59:52 GMT 1
Wonder why someone put an AC one on there, just goes to show, you never know what you're getting, until you strip it down.
Post by Mr Kipling on Aug 10, 2024 12:32:03 GMT 1
Paintwork looks ace mate , hope the clutch actuator is the problem , then its an easy fix . Atb
Post by donkeychomp on Aug 10, 2024 21:10:56 GMT 1
I'll put my hands up to that one. Almost certainly I put it in, thinking it was LC. They do look very similar. But the problem is now solved!
Post by donkeychomp on Aug 12, 2024 21:24:11 GMT 1
The new brake and clutch levers are on. Need a cool evening to pop over to Dusty for that part. I'm SO tempted to fit the bodywork but it's probably for the best if I wait till everything else is done.
