Post by dusty350 on Jun 3, 2024 6:34:32 GMT 1
Looking great Alex The pipes have come up really well Just shows what can be achieved with some elbow grease
Post by mouse on Jun 3, 2024 10:03:02 GMT 1
Great progress Alex!
Mouse
Post by donkeychomp on Jun 3, 2024 21:39:57 GMT 1
Cheers lads. Need to get those brake lines measured tomorrow and head off to get them made up.
Post by sidney81 on Jun 4, 2024 8:57:27 GMT 1
Fantastic to see It outside ! Looks good I love the look of a LC wth clip ons ππ
Post by donkeychomp on Jun 4, 2024 21:09:19 GMT 1
Cheers mate! Yep, me too.
Post by donkeychomp on Jun 18, 2024 21:35:17 GMT 1
I decided I needed a day off. Totally knackered but after a decent nights kip I found some time to do a bit to Elsie. I was armed with an Aprilia RS125 speedo cable (length 720mm so should be fine) and my offset sprocket from Dave. I didn't get a pic for some odd reason but the cable fits perfectly, so third time lucky! If anyone wants a brand new Mito one... Then the sprocket. After flattening the tab washer I looked for a 32mm socket. Shazbot, I don't have one. So I tried an adjustable spanner and was mildy shocked as the nut was done up finger tight!! So I put the new one on (ordered a socket) and prayed all would be well. RESULT! Lined up perfectly!! Alex
Post by dusty350 on Jun 19, 2024 7:50:32 GMT 1
Looking good mate. Tyr the "straight edge" on the outside of the sprocket faces - to check you have clearance on the inside of the frame rails above the swingarm pivot
Post by arrdy350 on Jun 19, 2024 10:13:16 GMT 1
That's great Alex glad you got it sorted ππ
Post by donkeychomp on Jun 19, 2024 21:10:22 GMT 1
Cheers lads. I did check today Dusty and loads of clearance all round. Also added a new bike to the stable Alex
Post by arrdy350 on Jun 19, 2024 21:30:01 GMT 1
New bike is nice 2002-07 Z1000 ππ
Post by donkeychomp on Jun 19, 2024 22:28:49 GMT 1
It is isn't it? Mint too. Shame it ain't mine lol. Check out the sticker on the front for a subtle hint.
Post by donkeychomp on Jun 23, 2024 21:38:36 GMT 1
Armed with my 32mm socket I did the nut up. Tight. The sprocket is ever so slighty loose, it needs a washer the size of, well, the locking washer. So I ordered 2 from Norbo, along with the horn cover and some oil line clips that I could have sworn I had but can't find them anywhere.
Post by donkeychomp on Jul 3, 2024 22:29:42 GMT 1
The sprocket is on. I used on tab washer as a spacer and it worked a treat. Checked the alignment three times just to be sure! All is good. So now I need a chain but I need to move the rear wheel as far back in the swinger as it'll go. Putting a bike with no centre stand onto a paddock stand on your own is not possible. Or is it? Anyone know something I don't?
Still scratching my head about the twin horn set up. Re-read some earlier posts and I need the actual bracket. Another Norbo order has been, err, ordered.
Also bit another bullet and bought a new Mito mudguard. From ze Germans. Not cheap and I bet customs sting me...thanks a lot Boris you f**king w**ker. Once that arrives I'll be in touch with a certain painter to get Elsie some spangly bodywork!
Post by jon on Jul 3, 2024 23:18:21 GMT 1
The sprocket is on. I used on tab washer as a spacer and it worked a treat. Checked the alignment three times just to be sure! All is good. So now I need a chain but I need to move the rear wheel as far back in the swinger as it'll go. Putting a bike with no centre stand onto a paddock stand on your own is not possible. Or is it? Anyone know something I don't? Still scratching my head about the twin horn set up. Re-read some earlier posts and I need the actual bracket. Another Norbo order has been, err, ordered. Also bit another bullet and bought a new Mito mudguard. From ze Germans. Not cheap and I bet customs sting me...thanks a lot Boris you f**king w**ker. Once that arrives I'll be in touch with a certain painter to get Elsie some spangly bodywork! Alex Look up βfront motorcycle wheel chockβ. Iβve got one, and itβs amazing. Seems to defy gravity. Easy to put a conventional paddock stand in no time single handed. Jon
Post by JonW on Jul 4, 2024 0:03:41 GMT 1
I agree wth Jon that the front chock is a wonderous device.
But, I can paddock stand a bike on me own... its hairy tho, you need to hold it upright by the grab rail and stand on the paddock stand. you can put the bike in a corner or a block riser under the stand as well to help, but it is fraught with danger... get the chock, its much simpler and ive never had a bike fall over from mine. Both it down if you can, can you drill the floor to make a removable point to locate it I wonder?
Post by donkeychomp on Jul 4, 2024 17:00:04 GMT 1
Thanks chaps! Had a look at them and it took me a moment to see how they actually worked. Simple but effective! All look the same, all made in China (sigh) but I've ordered one from a UK seller.
Post by Yogi on Jul 4, 2024 17:17:12 GMT 1
Looking good Alex πlight at the end of the tunnel π«£
P,s thatβs old mr mouseys kwaka I assume π
Post by midlifecrisisrd on Jul 4, 2024 18:03:10 GMT 1
Wheel chocks are great
If I park it up in winter on one I alway fit a tie down strap from between the bar clamps up to a roof joist as you can knock them over
As Jonw said you can put it on a rear paddock stand withe the grab rail
I leave the side stand down and always err on that side when holding it by the grab rail and hooking the stand onto the bobbins
You soon get the hang of it but best practice without the tank on just in case π¬
Post by donkeychomp on Jul 4, 2024 21:23:34 GMT 1
Yes Matt. It's his. I love it, especially the pipes!
Chock should be here Saturday. Maybe. Not going to try putting it on the paddock stand without it!
Post by donkeychomp on Jul 5, 2024 21:20:46 GMT 1
The sprocket... And I bet this is on upside down and the wrong way round too... Alex
Post by midlifecrisisrd on Jul 5, 2024 23:41:10 GMT 1
Yay, he's got the horns right π€£
Steve π
Post by Mr Kipling on Jul 6, 2024 20:54:31 GMT 1
Taking shape nicely now , keep the updates coming....
Post by donkeychomp on Jul 6, 2024 21:17:39 GMT 1
True to their word this rocks up...I wonder where it was made... 5 minutes later... This is a revelation to me. I have NO idea how I managed without one. Thanks lads for the pointers! Alex
Post by donkeychomp on Jul 9, 2024 21:32:42 GMT 1
The new muddie arrived. I was expecting customs fees, courier 'handling' charges, VAT import tax and to sell a kidney but the bloke handed it to me and buggered off. Brilliant! I'm now having chats with Mr Cordwell about paint. Exciting times! Alex
Post by reedx on Jul 10, 2024 9:24:00 GMT 1
Post by lcmarky on Jul 10, 2024 10:20:09 GMT 1
I decided against the twin horn set up and mounted a smaller single horn under the tank - still plenty loud enough.
I've a twin horn assembly here needs a new home.. and a belly pan and nose fairing.
Post by donkeychomp on Jul 10, 2024 21:35:18 GMT 1
Yes Colin. A while ago I contacted them asking for conformation that this is for a 125 Mito. The reply was 'sure, why not'. After fruitless hunting I had to ask them again and a girl called Sarah said yes it is. And it is too. Alex
Post by reedx on Jul 10, 2024 21:42:17 GMT 1
Yes Colin. A while ago I contacted them asking for conformation that this is for a 125 Mito. The reply was 'sure, why not'. After fruitless hunting I had to ask them again and a girl called Sarah said yes it is. And it is too. Alex I've got one of their complete front fairings for my Mito. Great quality for a very reasonable price. www.ricambiweiss.com/de/verkleidungsteile/cagiva-536/cagiva-125-mito-evo-1996-2007/Colin
Post by donkeychomp on Jul 10, 2024 22:27:20 GMT 1
Glad you got the fairing. I'm not sure about the price for my mudguard but hey, it's brand new and the only one I could find. Plus I avoided any import fees. Wish I knew how...
Post by donkeychomp on Jul 10, 2024 22:31:28 GMT 1
Forgot to mention. Mark quoted me a price. I accepted. It was quite a bit cheaper to send him my plastics as all he has to do is supply a tank. He already has a full set painted up, so all he has to do is paint my mudgaurd (no decal needed) and send it back. Hopefully a quick turnaround. Dosh sent, every part wrapped up and boxed, will be posted tomorrow. I can't wait!
