Post by headcoats on Feb 15, 2019 12:00:53 GMT 1
I had the RGV adjusters powder coated so had to take a bit off so the top hat spacers fitted for the KR1S axle as it's 2mm smaller
I had to take a bit off the back of the top hat tube so when the axle was tightened it would snug up properly
Does this sound right ?
Post by headcoats on Feb 18, 2019 21:22:48 GMT 1
Fitted new bearings and masked it off ready for the rattle can
Post by donkeychomp on Feb 18, 2019 23:58:27 GMT 1
I use a pack of cards...way quicker!
Post by headcoats on Feb 21, 2019 18:57:25 GMT 1
Yipeee. the EBC discs turned up
Post by headcoats on Feb 21, 2019 19:00:22 GMT 1
Feckin Half Wit Kuntz ARRGGGGGHHHHHHHHHH!!!!!!!!!!!!!! FFS I opened the other box and have two shades of gold Did I say FFS !!!!!!!!
Post by donkeychomp on Feb 21, 2019 23:16:06 GMT 1
Twerps.
I like the one on the left...
Post by headcoats on Feb 27, 2019 10:35:47 GMT 1
Professional job of painting the rear wheel LOL
Post by headcoats on Mar 1, 2019 11:10:21 GMT 1
Fitted new bearing to sprocket carrier Think whoever had the carrier vapour blasted left the old bearing in !
Post by headcoats on Mar 4, 2019 17:21:08 GMT 1
Finished rear wheel As I used normal masking tape I had to wet and dry the edge back in but looks OK for the price of a rattle can ?
Post by donkeychomp on Mar 5, 2019 0:04:02 GMT 1
That looks really good mate.
Post by headcoats on Mar 5, 2019 9:59:36 GMT 1
Cheers Donk , my number one fan !
Well with new wheel bearings all round, it will be easier to push if/when it seizes LOL
Post by tsa on Mar 5, 2019 11:11:55 GMT 1
A tip for ya when you mask up next time use the thin butchers tape as your line as it leaves a much crisper edge
Post by headcoats on Mar 5, 2019 11:32:29 GMT 1
It wasn't too bad, 10 minutes to do :-)
Post by donkeychomp on Mar 5, 2019 22:32:15 GMT 1
I use 3M tape (the blue stuff) for lines like that. Also great for masking out curves. It's what car painters use to get the flame effect down the wings.
Post by headcoats on Mar 8, 2019 20:39:43 GMT 1
Testing the tablet to load pics Not as easy as laptop and my pet mouse, b*****ds lol
Post by headcoats on Mar 8, 2019 20:53:16 GMT 1
Got two matching discs now !
Post by donkeychomp on Mar 8, 2019 23:21:40 GMT 1
You sure? Right one looks darker to me...
Post by midlifecrisisrd on Mar 8, 2019 23:38:42 GMT 1
You sure? Right one looks darker to me... Alex Stop you winding him up 🤣🤣 Steve
Post by headcoats on Mar 8, 2019 23:40:24 GMT 1
It's the flash LOL
Post by donkeychomp on Mar 9, 2019 0:16:42 GMT 1
Haha!
Post by headcoats on Mar 9, 2019 16:54:44 GMT 1
Another possible issue with the feckin discs !
The one disc outer looks to have been finished , a bit like honing with a cross hatch pattern but the other one looks smooth
When measuring the thickness , the honed one is 4.95mm, the smooth looking one is 5.17mm thick
Is this an issue ? Did they forget to finish the one disc ?
I have emailed EBC direct to see what they have to say......
Fukkin brake discs and showers LOL
Post by donkeychomp on Mar 9, 2019 23:38:44 GMT 1
Should be exactly the same. Bleedin' heck they finally get the colour right then this...
Post by headcoats on Mar 10, 2019 8:45:04 GMT 1
Yes becoming a right royal pain in the arse but looks like they are going back AGAIN !!!
Post by headcoats on Mar 16, 2019 9:11:31 GMT 1
Trimmed down thre chain rubber The unmodified ones is next to it
May have to alter the cut out a little more to make sure it clears the frame
Post by headcoats on Mar 17, 2019 14:43:15 GMT 1
Brake Update EBC sent postage labels and I posted them back 16th March They will then send another set directly from EBC to me and hopefully that's that !
Post by donkeychomp on Mar 17, 2019 23:35:55 GMT 1
Fingers xxd
Post by headcoats on Mar 18, 2019 18:03:23 GMT 1
Don't know if chopping the rubber up makes it flimsy but with just a bolt and washer, the chain rubber flaps about so made a plate to hold it better
Post by headcoats on Mar 19, 2019 11:56:11 GMT 1
Fitted head race bearings and yokes Loosely fitted swing arm to check if the chain rubber cleared the frame
Put the lock in for the German steering lock and re riveted the frame plate back on
Waiting for new swingarm dust caps and the EBC discs,plus need to get the rear tyre changed then it's on it's wheels next !
Post by headcoats on Mar 26, 2019 12:16:52 GMT 1
Fookin Hurrah! Third lot of discs now fitted
Post by donkeychomp on Mar 26, 2019 23:48:34 GMT 1
Very nice. Very nice indeed.
