Post by headcoats on Dec 12, 2018 23:32:18 GMT 1
They were still wrapped in the white paper from the anodisers so looked like screwed up bits of paper, so you can gueaa what happened there :-(
Post by headcoats on Dec 17, 2018 16:09:08 GMT 1
Got stuff back from powdercoaters today Not 100% happy but don't think I ever am LOL Frame number was masked off so just a bare metal strip which will have to be painted in when the German frame is registered Banana arm is still showing the dinks/repair so going to need filled and blown over but I kinda guessed it would
So still work to do !
Will sort a few pics out
Post by headcoats on Jan 2, 2019 16:57:46 GMT 1
Random pic time !
Powder coated footrest brackets plus a few spares
I like the standard footrests , even though it's a Hybrid When you get to a certain age , they are in the right position, believe me :-)
Post by headcoats on Jan 4, 2019 13:03:59 GMT 1
Had the LC headlamp rim powder coated too as chrome wasn't great and had some road rash but still usable Did use M5x8mm button heads to hold the 2 rings together Someone is sending me the little screw , nylon bolt and spring so just need the "w" clips to hold the headlight rim in All little things but need doing :-)
Post by oldelsieboy on Jan 4, 2019 13:12:17 GMT 1
Had the LC headlamp rim powder coated too as chrome wasn't great and had some road rash but still usable Did use M5x8mm button heads to hold the 2 rings together Someone is sending me the little screw , nylon bolt and spring so just need the "w" clips to hold the headlight rim in All little things but need doing :-) Have you tried the lens in the rim, you might find it snags the domed bolt heads. OEB
Post by headcoats on Jan 4, 2019 13:36:53 GMT 1
Got the light in and it is a bit of a squeeze, but this lens is an aftermarket one Now I had to take one of the button head screws out to get it in so it looks like I need the original "flat" screws to get the clearance
Post by headcoats on Jan 4, 2019 14:04:27 GMT 1
Got it in ! Wouldn't recommend it though and you really need those flat screws The one side isn't the problem, as you tilt the lens in past it, it's the other side where it needs squeezing over the top of the button head The headlamp ring does flex a bit so that helps
Post by headcoats on Jan 4, 2019 14:45:04 GMT 1
In the new LC headlamp I bought ages ago but new problem ffs The headlamp shell is Yamaha so are the headlamp rings I had powder coated but the 2 screws that hold the rim to the shell don't quite line up !
Post by headcoats on Jan 4, 2019 17:32:34 GMT 1
I did this on my old LC but that was with an aftermarket rim on a standard shell
Sacrilege on a new part but drilled 7MM and inserted some alloy tube 6mm I.D. to give a little wriggle room
OK I promise no more pics of the feckin headlamp LOL
Post by donkeychomp on Jan 4, 2019 23:50:14 GMT 1
Black! So much better than that awful olive green. Why on earth did they choose that colour? Did they have a ton of it in a vat somewhere?
Post by jon on Jan 5, 2019 11:25:26 GMT 1
Black! So much better than that awful olive green. Why on earth did they choose that colour? Did they have a ton of it in a vat somewhere? Alex I stand to be corrected, but wasn’t an LC headlight rim chrome? One of the few bits that was along with grab rail, top yoke bolt etc. Maybe your thinking of the early YPVS models? Jon
Post by headcoats on Jan 5, 2019 11:26:05 GMT 1
LC's were chrome but chrome is for Harleys
Do not over do the chrome on an LC, it's against the law !
Post by jon on Jan 5, 2019 11:29:16 GMT 1
LC's were chrome but chrome is for Harleys Do not over do the chrome on an LC, it's against the law ! Oh no. I’m a criminal, I think I might have broken the law with my latest LC. LOL. Jon
Post by donkeychomp on Jan 5, 2019 23:47:06 GMT 1
I was referring to the foot rests but I kinda like the black headlight.
Post by jon on Jan 6, 2019 9:47:37 GMT 1
I was referring to the foot rests but I kinda like the black headlight. Alex I couldn’t agree more about it being an awful colour. The trouble is a lot of people try to replicate the original during restorations just because ‘that’s how they were from the factory’. When decorating/renovating an older house you don’t rip all the carpets up and have bare floorboards, take all the electrics out, sweep the chimney for an open fire etc; you do it how you want with the finish you want. You don’t put it back to how it was when it was built. So why do so many restore faithfully an LC? That’s why I like hybrids. Jon
Post by headcoats on Jan 6, 2019 10:11:23 GMT 1
I can see why they do it because that's how it was
That's why I like Hybrids too !
Post by donkeychomp on Jan 6, 2019 23:50:45 GMT 1
Too bleedin' right both of you. When I got my first ever LC first thing I did was slap some expansions on it. Then clock protector bars. Then jacked up the back. Probably made the whole thing a lot worse but who cared? It looked cool!
Post by headcoats on Jan 25, 2019 16:11:29 GMT 1
Got to tackle the uneven surface of the powder coated banana arm
I did have the main stuff welded and filled but there is a lot still showing !
Going to rub it down and try some P38 filler , then good old Simoniz tough black I have already sprayed some tough black on to see how it matches and looks OK to my mole eyes :-)
(There is a bit just above the threaded hole for the bobbin too)
Any tips before i start :-)
Post by midlifecrisisrd on Jan 25, 2019 16:37:19 GMT 1
I reckon the main area is actually the marks on the recessed area Try filling that area then blend in the paint and see how it looks. It's surprising how little you see in the front half depending on your rearsets. Either that or just stick a carbon cover on it lol Steve
Post by headcoats on Jan 25, 2019 16:53:25 GMT 1
Will have a go myself then if I can't get a good finish then ask my mate as he does car repairs and if that doesn't work then a carbon cover may be on the cards but another expense I don need
Post by midlifecrisisrd on Jan 25, 2019 17:10:09 GMT 1
The weld in the recess looks proud so I'd think more material needs removed then a little filler at the transition from weld to arm
Post by headcoats on Jan 31, 2019 10:49:54 GMT 1
Had another go but still needs finishing
Post by headcoats on Jan 31, 2019 10:55:48 GMT 1
Another angle
Post by midlifecrisisrd on Jan 31, 2019 11:57:22 GMT 1
Just get it fitted 😜
Post by philmill on Jan 31, 2019 12:16:19 GMT 1
That looks way better, in its fitted position you won't see anything.
Phil
Post by headcoats on Jan 31, 2019 12:24:59 GMT 1
One last coat and I might LOL
Post by midlifecrisisrd on Jan 31, 2019 13:38:58 GMT 1
One last coat and I might LOL That's what we all say them make a mess of it 🤣 Steve
Post by headcoats on Jan 31, 2019 14:06:43 GMT 1
Already done that ! It said leave 30 minutes between coats which I didn't read and it reacted ! Last pic was after leaving it a few days and flattening it back
Post by headcoats on Feb 8, 2019 13:30:17 GMT 1
Rebuilt rear YPVS master cylinder Leaving it unpainted as the one on my red bike has stood up well not being painted the last ten years Just a bit of metal polish on a tooth rush every now and then !
Post by headcoats on Feb 13, 2019 13:36:51 GMT 1
Mate trimmed down the Ducati Monster mudguard as I felt it was too long Just need to get it fitted now !
The brake discs I have , I have found cracks in them so looking at some EBC discs at £120 each which I suppose ain't bad for EBC These wheels were on my old LC built 10 years a go so need repainting but it has held up pretty good really
