Post by headcoats on Apr 3, 2019 11:23:41 GMT 1
Not much done but spent an hour on the phone sorting my insurance renewal out Got the new build insured on frame number only now and on market value until registered No time limit which is a bonus as I'm so slow LOL
Post by headcoats on Apr 8, 2019 17:07:27 GMT 1
Got the lecky stuff out ! Envelope says I got this in 2011
Post by donkeychomp on Apr 8, 2019 22:29:47 GMT 1
G'wan get out there and ride the beastie!
Post by philmill on Apr 9, 2019 6:25:31 GMT 1
How did you manage no time limit on frame number only.... I only got 6 weeks with Carol Nash, can I ask who you are with ?
Phil
Post by headcoats on Apr 9, 2019 7:07:41 GMT 1
Footman James
Post by headcoats on Apr 17, 2019 17:03:32 GMT 1
Swingarm now in
Post by headcoats on Apr 24, 2019 9:18:40 GMT 1
Need to decide which Zeeltronic to get ! Got the Athena top end so no powervalves But may revert to a YPVS top in the future ? Plus the one Zeeltronic does away with needing the high/low windings on the stator ? Or get the Zeeltronic already set up so plug in jobby ?
Plus with the a Athena top end, I'm expecting more of a flat spot/lull in the midrange, so would programmable timing help through the transition ?
Post by donkeychomp on Apr 24, 2019 22:22:57 GMT 1
Yes, yes, yes and yes.
I think.
Post by headcoats on May 2, 2019 9:55:35 GMT 1
This pic looks just like the first pic I posted 2 years a go ! Rolling chassis !
A lot has been done but anyone else could have done it in 2 weeks...
Post by headcoats on May 2, 2019 9:58:39 GMT 1
The other side !
I like the shadow it has left !
So hopefully now I can bolt stuff on the giant jigsaw
Want to sort the brakes out , the brake lines should be standard from the splitter to the calipers, then a custom pipe to the radial m.cylinder I have
The rear will need to be a custom line too
Post by headcoats on May 2, 2019 13:48:23 GMT 1
A waste on a Hybrid ?
Are they still available ?
Post by midlifecrisisrd on May 2, 2019 15:23:47 GMT 1
Not at all
Still available at about £100 the pair but you now get identical copies for £40
Post by headcoats on May 4, 2019 18:41:45 GMT 1
Post by headcoats on May 5, 2019 18:41:38 GMT 1
After feckin about with washers to try and get the clearance with the master cylinder and swingarm, hopefully sorted now and need to order some spacers
The little M6 hole on the m. cylinder mounting bracket is for a nylon swingarm bobbin that will bolt behind and support the bracket so it won't want to rotate when you dab the brake Really poor design IMO
Post by headcoats on May 9, 2019 14:24:54 GMT 1
After ignoring these since I had lost one of the clamps, I have now tackled the feckers !
I had the clamps anodised black too which I have since changed my mind
Thanks to Stusco I attacked the anodised finish with oven cleaner , so back to alloy again but will be spraying the brackets that hold the headlamp black , so why on earth I didn't just get those anodised black and left the clamps bare is a bit of a f##k up LOL
NK Racing is making a replacement clamp but said 4 weeks
I had to drill the indicator holes out to accept the standard LC indicator stalks too
Bit more forward !
Post by headcoats on May 12, 2019 16:28:16 GMT 1
The Ducati front mudguard is now shortened and in the position it will stay in so what do you think ?. It will need some alloy strips to hold it on , front and back and I will paint them black to match the mudguard when that is finished in black
Post by Tobyjugs on May 12, 2019 19:53:33 GMT 1
Looks good for this type of fork set up
Post by donkeychomp on May 12, 2019 21:58:41 GMT 1
I really like that muddie. Go with it I say.
Post by headcoats on May 12, 2019 22:06:49 GMT 1
One potential problem which I have completely missed is that inside "strap" on the mudguard is close to touching when the forks are compressed and the large upper tube passes down Ducati forks must be wider spaced than RGV ? I will make the alloy plates to fit and flex the mudguard straps in a bit if I can or its going in the bin LOL
Post by veg on May 15, 2019 11:46:00 GMT 1
At least you have an excuse now that Nigel is involved making a part. 4 weeks that’s a nk 4 weeks so be about 12.
Post by headcoats on May 15, 2019 15:08:35 GMT 1
Don't need excuses to slow me down LOL
Post by veg on May 15, 2019 16:34:15 GMT 1
Mine took me 3 years so you’re well on target 👍
Post by headcoats on May 18, 2019 9:16:44 GMT 1
Painted the head now !
The plumbing out the top of the head is going to be interesting as the hose has to go 90 degrees to miss the radiator as the Athena head has the outlet in the wrong place ! Then I wanted to connect the go kart thermostat , then a small bypass connector for the bleed pipe then somehow route it to the top radiator connection
Post by headcoats on May 31, 2019 16:58:55 GMT 1
Getting the clocks sorted,not the best but the speedo is a UK one Tacho has a new face
Don't know if they are functioning , but will find out soon !
Had a bit of trouble getting the wire routing out the bottom of the clocks
Here is a thread to show the way they go ( Thanks to oldelsieboy)
rdlccrazy.proboards.com/thread/47907/standard-lc-clocks-wiring-route
Post by headcoats on Jun 6, 2019 9:54:33 GMT 1
At least you have an excuse now that Nigel is involved making a part. 4 weeks that’s a nk 4 weeks so be about 12. Came this morning !
Post by veg on Jun 6, 2019 9:58:17 GMT 1
Wow well done Nigel. Hose wise I used wire reinforced hose that allows you to bend it without it deforming had to use it on the feed to the head from the pump 180 degrees and from head to radiator. Good stuff.
Post by headcoats on Jun 9, 2019 15:34:58 GMT 1
Had a go at the brackets for the front muddy, they will be painted black to blend in as will the mudguard
Opinions please :-)
Post by donkeychomp on Jun 9, 2019 22:35:09 GMT 1
With black brackets that will look great I think. Thing is if you have to ask for opinions the nagging seed of uncertainty is there. It's unique and will grow on you. Go for it I say.
Post by headcoats on Jun 9, 2019 22:39:04 GMT 1
I was born with a nagging seed of uncertainty !
Think it's ones of my Bollox LOL
I think the front ones are OK but not sure about the rears , but will decide when I paint em black
Post by midlifecrisisrd on Jun 10, 2019 9:04:30 GMT 1
Fit the upper end of the rear brackets to the inside of the muddy and it should look a lot better
