Post by headcoats on Apr 29, 2020 13:37:20 GMT 1
They are a bit fiddly to get the tops off and I do tend to remove the tank
I can strip them in my sleep though !
When you see how tiny some of the holes are you can understand how easily they become blocked
Post by donkeychomp on Apr 29, 2020 21:55:34 GMT 1
Quick release carbs? Or did I dream that...  Alex
Post by headcoats on Apr 30, 2020 7:35:34 GMT 1
The Missus is always on about quick release 😂
Post by headcoats on Apr 30, 2020 9:33:10 GMT 1
Last night I upped the pilot jets from 45 to 50 and although the flat spot was the same I now have some colour in the plugs which was a concern ( I have some 48's too but will keep these 50's in for now)
I will now weaken the needles as I can't go the other way , anyway as it's on richest setting
Don't like to weaken the needles and will try clip #4, middle clip and clip #2 but no more to see if I can get a better transition
I have some needle shims too , to go half a clip to try
Post by headcoats on May 2, 2020 12:26:25 GMT 1
Put the N68 needles on middle clip and much better, so engine is asking for weaker there I had put 50 pilots in and plugs looked a good colour but with needles weaker the plugs look weaker ffs So can't do anything with needles, so do I go richer on the pilots
Post by headcoats on May 4, 2020 13:14:00 GMT 1
Marked up the throttle to show what openings things are happening at and at 1/2 throttle is a stutter that quickly goes by turning the throttle a bit more then the flat spot/Lull is at 3/4 throttle
Quite surprised at the flat spot showing at 3/4's
So on the Keihin chart that is needle taper and main jet
Post by LC_BOTT on May 4, 2020 13:34:13 GMT 1
What jets do you have in now? Just cleaned my Carbs ready to fit this week hopefully, staying with 40 pilots but 155 mains (on slightly tuned YPVS engine, a long way from a start-up though)
Assume you've cleaned those tiny galleries in the main body one of mine was blocked solid.
Post by headcoats on May 4, 2020 14:28:29 GMT 1
Yes I have taken out the security screws that holds the main jet block etc in
Setup so far is
160 main jet 50 pilot 2 turns out air screw N68 needle in middle clip Ramair pod filters
Post by headcoats on May 6, 2020 11:14:58 GMT 1
Dropped the needles weaker again to 2nd clip and it has ran the best yet
Will cruise up and down to 6 grand now and will climb through into the powerband , but still nothing like a PV engine does
Keep saying it LOL but needs finishing off on the dyno
Post by midlifecrisisrd on May 6, 2020 11:19:11 GMT 1
Just put smaller mains in
If dropping the needle is helping that's the way to go
Think you may be finding the downfall of the No pv's as it won't be any where as strong out of the power
Post by headcoats on May 6, 2020 11:30:04 GMT 1
It is quite torquey and not unrideable out the band and the kick around 7K is manic LOL
When I get to the dyno maybe mains can be adjusted
Front brakes feel great too with the radial master cylinder on the RGV 250 calipers, really progressive
Dash indicator right turn bulb has given up the ghost !
Post by headcoats on Jun 14, 2020 10:14:34 GMT 1
Done 127 road miles now
Went on a 32 mile round trip, so engine had the longest non stop run, no overheating or anything
Tacho has become jerky , so need to keep an eye on it
Post by headcoats on Jul 10, 2020 22:19:40 GMT 1
Another ride today and went to bike cafe Attracted a few people and I was in a reflective mood and just kept saying, looks nice but rides shite LOL
Sorted the indicator warning light, was a corroded connection and hopefully the jerky tacho with some grease
Post by flames on Jul 11, 2020 11:59:11 GMT 1
Another great read. Bike looks awesome dude. Hope you get her going as good as she looks soon. You must have the patience of a saint with all the issues you had along the way!
When I was young I swapped a scabby mt5 for a non running cb125j. Spent ages trying to get the thing running. One evening me and my mate tried bump starting it. It felt like we must have done 5 miles and I was getting angrier and angrier until I finally hit savage. Push her home, removed seat and tank, and beat the 5hit out of the bike with a sledge hammer!!! I think I invented the banana frame.
I have calmed down in my old age, but I think that's mostly down to the fact the sledgehammer seems so much heavier!😁😁😁
Post by headcoats on Jul 14, 2020 15:10:33 GMT 1
Just been out for a short ride and have to admit the JJH (middle clip)felt better, not sorted but an improvement over the N68 needles
Still a splutter and the flat spot but not as bad and 4 to 6 grand felt smoother
I feel if I can get it close to running half decent then time at the dyno will be shorter !
The Banshee boys use the JJH needles a lot and PWK 28 carbs too , so having a Banshee top end , do I need to follow them ?
Need the Banshee map Borut sent me loaded in now
Done over 200 miles now on the bores
160 main jet 50 pilot jet 2 turns out on airscrew JJH needles middle clip Ramair filters
Post by headcoats on Jul 26, 2020 16:16:34 GMT 1
Put 48 pilots back in for now Plugs are a nice chocolate brown now which only seemed to happen when I put in the JJH needles over the N68's
Getting a bit jaded with it now but just come back off holiday so got the blues LOL
160 main jet 48 pilot 2 turns out air screw JJH needle in middle clip Ramair pod filters
Post by headcoats on Aug 9, 2020 17:05:14 GMT 1
F##K IT I HAVE HAD ENOUGH !
It's on the naughty step until I can be bothered with it again !
Post by flames on Aug 9, 2020 18:01:18 GMT 1
Why what's happened?
Post by headcoats on Aug 9, 2020 19:13:12 GMT 1
Can't get it running at all and I need to get it to the dyno to see what's going on
Zeeltronic needs setting up etc
Post by flames on Aug 9, 2020 19:18:14 GMT 1
Bugger. I know it's not been an easy task getting it set up, but you know it's going to be worth the hassle when it is sorted.....these set backs will just make it more satisfactory when it's finally running sweet.
Post by headcoats on Sept 18, 2020 18:52:10 GMT 1
Post by headcoats on Sept 25, 2020 20:37:02 GMT 1
Just putting the feelers out
I think I am going to sell the Athena top end as I don't want special pipes made etc to make it run better
It would suit probably more someone doing a 4mm crank build and got the resources to buy the pipes and set it up on the dyno etc
Post by donkeychomp on Sept 25, 2020 21:49:43 GMT 1
Well that's me out then  Alex
Post by headcoats on Sept 26, 2020 8:35:10 GMT 1
Well maybe a set of custom pipes and a dyno sesh then LOL
Post by headcoats on Sept 30, 2020 12:07:01 GMT 1
Barrels are off LOL
So I either stick a standard top end on or persevere with the Athena s
Post by headcoats on Oct 8, 2020 10:23:48 GMT 1
OK Gummy Bears :-) Now I think I'm going to fit my YPVS barrels to this bike but I'm going to miss that Athena kick at 6 grand  So what can I do to the standard YPVS barrels to get the same thrill ? Lock the power valves LOL Do you set the powervalves to fling open 100% as soon as the engine comes on pipe ?
Post by headcoats on Nov 21, 2020 13:41:26 GMT 1
 The Athena bike has had it's testicles removed LOL
Post by headcoats on Nov 22, 2020 20:38:55 GMT 1
As I had the Athena top end on without power valves. I have no wiring for one and no bracket for the servo motor etc
I have the LC loom and the Zeeltronic box with the built in PV controller though
I have the standard F2 CDI too and may remove the Zeel and have the stock F2 CDI and PV controller but going to need some wiring either way
Post by midlifecrisisrd on Nov 22, 2020 20:50:55 GMT 1
Was it not Dusty that put up the diagram for the bracket to fold and make the pv bracket that goes under the coil
Personally I'd leave the Zeel on it and just wire up the servo motor
That way you aren't messing around trying to fit in the other boxes
Post by headcoats on Nov 22, 2020 21:34:22 GMT 1
I could lock the PV's open for now as I always wondered how it would ride !
