Post by wallcraft on Mar 31, 2020 19:53:10 GMT 1
If you mean the weed shite, yes does my frikin nut in when you can't even walk down the street with out smelling that shite. Rant over, sorry if I'm barking up the wrong tree 🙄
Post by headcoats on Mar 31, 2020 20:43:02 GMT 1
No not weed , just ciggies I'm quite tolerant of second hand smoke but in my own garden . it makes me fume (no pun intended !)
Post by donkeychomp on Mar 31, 2020 22:31:10 GMT 1
Happy Birthday!
Post by headcoats on Apr 3, 2020 15:54:27 GMT 1
Most together it has ever been !
End cans on and painted and spaced out front mudguard fitted !
Post by headcoats on Apr 3, 2020 19:50:10 GMT 1
Not quite ready to fire up but just a few things left like re clean carbs, fit filters , fit fuel tap and cut fuel pipe to length, add a bit more gearbox oil, add coolant add premix and START LOL
Post by dusty350 on Apr 3, 2020 19:58:40 GMT 1
Looks lovely Dusty
Post by stusco on Apr 3, 2020 20:19:35 GMT 1
You could have that running in less than an hour
Post by headcoats on Apr 3, 2020 20:40:01 GMT 1
You could have that running in less than an hour I could but the bike keeps throwing shit at me LOL
I have to build myself up for it first !
Post by donkeychomp on Apr 3, 2020 22:32:53 GMT 1
Be brave. Do it tomorrow. You know you want to.
Post by somethingelsie on Apr 3, 2020 22:35:36 GMT 1
Nice one pal looks brilliant 👍
Post by doohanno1 on Apr 3, 2020 23:44:58 GMT 1
No not weed , just ciggies I'm quite tolerant of second hand smoke but in my own garden . it makes me fume (no pun intended !) Don't worry, You"ll get them back on start up !!
Post by perazzi350 on Apr 4, 2020 2:59:06 GMT 1
brilliant bike a credit to you
Post by headcoats on Apr 9, 2020 13:11:19 GMT 1
F##k F##K and 3 F##ks !!!
3 niggly leaks
Put coolant in today and the adaptor for the temp. sender that fits on the side of the thermosat isn't sealing , even though it has a new washer on
The clutch window is leaking , I have taken it off and no pinched 0 rings etc and put it back on....
Then my nemesis , the brake fluid ! I had some stainless aftermarket bleed nipples and the one on the rear caliper is leaking up the threads
Some days you just think why bother !
Post by bryan on Apr 9, 2020 18:36:09 GMT 1
oh the fun!
Post by midlifecrisisrd on Apr 9, 2020 18:48:29 GMT 1
First run up and heat will sort the clutch window
As for the leaking bleed nipple I've given up on the stainless ones as it seems the seat is not cut at the right angle so they don't seal correctly
Post by headcoats on Apr 9, 2020 21:58:15 GMT 1
Steve what nipples have you been tweaking on your build then 😜
Post by midlifecrisisrd on Apr 9, 2020 22:41:15 GMT 1
I was just getting standard ones replayed I'm afraid
Try buying a genuine one from Suzuki
I take it that's the caliper you are using
Strve
Post by headcoats on Apr 10, 2020 9:01:16 GMT 1
Has anyone else had trouble with these aftermarket stainless nipples sealing properly ?
Post by headcoats on Apr 13, 2020 15:44:45 GMT 1
Started it today !!!!!
Fired up almost straight away
Temperature gauge is kerputt , so how do I test it ?
THREAD STARTED HERE ABOUT TEMP GAUGE
rdlccrazy.proboards.com/thread/50500/lc-temperatue-gauge-working?page=1&scrollTo=473168
Don't know if gear changes are an issue as it dropped into first OK but trying to select any other gear was next to impossible with engine running but can do with the engine off
Kicking it over felt like it had too much compression, nothing like my red LC
It sounded completely different too with the Athena top end
Let it idle till barrels felt warm and have switched it off an hour and will try again later
Post by bryan on Apr 13, 2020 18:39:11 GMT 1
It will sound different as porting isn’t same as power valves closed at tick over, Plus higher compression on Banshee topend.
Post by stusco on Apr 13, 2020 18:50:07 GMT 1
If you ground the temp gauge connector the gauge should rise to max if it doesn’t the gauge is faulty otherwise its the sender
Post by midlifecrisisrd on Apr 13, 2020 18:57:30 GMT 1
They usually dont like changing up and down the gears while the bike is stationary
Post by headcoats on Apr 14, 2020 10:56:53 GMT 1
Temperature gauge now working , so Thanks for advice and especially Alan Kelly :-)
Basically it needed earthing from the stat to frame to ground it
The gauge needle had stuck about a third open when I left it last night and this morning still the same, so thought feckin great
I put a temporary wire running from the hex on the temp . sender to the frame to earth it and low and behold it started to work !
Plus the needle settled back down to the stop on the temp. gauge :-)
All the tingling of the engine may have dislodged it LOL
Post by headcoats on Apr 15, 2020 15:19:05 GMT 1
Just got it MOT'd today !
Gears worked fine and clutch too
RGV Forks felt low ! Done heat cycles only before so had no idea how it would feel on the road,so maiden run
Was only pulling to 4 grand as was taking it easy but already that was hitting a huge flat spot
After the power valve motor I know I would be in for a shock and will be interesting in the coming months to see what can be fine tuned out by jetting and ignition changes
Post by donkeychomp on Apr 15, 2020 22:38:50 GMT 1
RE-sult! Great news on the MOT!
Post by headcoats on Apr 16, 2020 15:17:38 GMT 1
Earth from the thermostat put on better Used a small petrol clip and a ring terminal either end of the wire (You can see it just below the Hex nut of the sender)
I did have a little spade connector with a ring on the end but it would have meant draining the coolant then removing the sender and re sealing it
Checked the torque on the head bolts and were fine With the thermostat in the way , I could get at most of them by bending the hose out the way, just #10 nut was a bit fiddly but doable
Post by headcoats on Apr 16, 2020 15:45:52 GMT 1
As I went the MOT station with red petrol tank fitted, I'm seriously thinking of swopping the bodywork !
Bike was actually running in this pic !
Thought I had fitted the JJH needles , until I found them in the box LOL I had N68 needles in, so next time round the block it will be interesting how the JJH ones work over the N68 needles
Could be worse !
Post by headcoats on Apr 17, 2020 15:26:34 GMT 1
Well the DVLA site is saying not to send in any paper applications until further notice
Post by midlifecrisisrd on Apr 17, 2020 15:43:26 GMT 1
Well the DVLA site is saying not to send in any paper applications until further notice Swap the bodywork and the reg plate off your other bike, stop whinging and get on with it 🤣 Steve
Post by oldbritguy on Apr 17, 2020 16:10:33 GMT 1
I do like the look of the red bodywork. Likey a lot Swap it over and see how it looks. I was thinking of painting my latest LC project KR yellow but quite like the look of the red on yours. Get some pics up and give my indecision chip a boot up the ar#e John
