Post by rostrumorhospital on May 8, 2017 0:16:16 GMT 1
Bike looks immaculate, glad to hear you got to the bottom of the starting issue, there's always something. now enjoy the finisheng stage
Post by mouse on May 8, 2017 7:26:36 GMT 1
Looking great mate Glad you sorted the caliper carrier - bet it didn't need much did it ? At this rate you'll be riding it by next weekend !! Dusty No, just a fraction, all done by hand! Going to order hoses today, so maybe at the weekend... Mouse
Post by mouse on May 8, 2017 7:27:06 GMT 1
Bike looks immaculate, glad to hear you got to the bottom of the starting issue, there's always something. now enjoy the finisheng stage Thanks very much, yes, very close now Mouse
Post by Yogi on May 8, 2017 8:41:08 GMT 1
Hi Andy
The bikes looking the bizz now mate
Really nice build
Atb Matt
Post by mouse on May 8, 2017 10:24:20 GMT 1
Hi Andy The bikes looking the bizz now mate Really nice build Atb Matt Cheers Matt throttle switchgear painted, ready to fit, brake hoses and number plate ordered for the weekend, i'm feeling a bit nervous now!! Take care Mouse
Post by mouse on May 10, 2017 20:05:20 GMT 1
Post by Yogi on May 10, 2017 20:38:51 GMT 1
Good luck Andrew
I'm off tomorrow so any probs give me a ring
Atb Matt
Post by Mr Kipling on May 10, 2017 20:56:31 GMT 1
So today, this little lot arrived. I find i am not working tomorrow, so going the fit the brake hoses and bleed the brakes, never done it before, wish me luck!! Mouse Could of lent u that bleed kit ... ::)
Post by mouse on May 12, 2017 7:36:39 GMT 1
Fitted the brake hoses yesterday, got the routing right, turned all the banjos to the right angle etc. The lengths i ordered are good. Good service from Hel, ordered them on Monday, got them Wednesday.
Started to bleed the front, using the vacuum pump, after several hours i gave up (some of the kit broke, then it started to let air into the system!) Went back to the old school method of pipe on bleed nipple, pump lever etc. After several more hours, i think i have removed all the air but the brakes feel more spongy than a slice of Mr Kipling's finest (No offense Mr Kipling!!)
By this time i had had enough and so had my knees! In desperation i cable tied the lever back to the bars. Checked it this morning and there is a definite improvement, more pressure at the lever, this is good!
Haven't even tried bleeding the rear yet, but still hoping to give her a quick run at the weekend
Mouse
Post by Mr Kipling on May 12, 2017 10:02:45 GMT 1
...Personally I use the pipes with the little bleeds inline works for me first time all the time , if I wasn,t away tomo I,d pop over n do for u , hopefully another member can help out if needed ... fingers crossed u can get to take it for a spin...Atb...
Post by mouse on May 12, 2017 13:04:43 GMT 1
...Personally I use the pipes with the little bleeds inline works for me first time all the time , if I wasn,t away tomo I,d pop over n do for u , hopefully another member can help out if needed ... fingers crossed u can get to take it for a spin...Atb... That's good of you, no problem, i think most of the problems are caused by my mechanical incompetence!! Still hoping to be out this weekend, i have a plan!! Mouse
Post by Mr Kipling on May 12, 2017 14:20:09 GMT 1
Hope it doesn,t involve cheating n temp using the brakes off the other bike ... :-)
Post by mouse on May 14, 2017 8:42:21 GMT 1
So, my 'plan'. A girl at work's boyfriend is a motorcycle mechanic and on Saturday morning he very kindly came over to help with the brake bleeding. He said i had got all the air out and he made a few tweaks to the front and they are loads better, not quite as good as i would like but, the discs and pads are brand new plus the calipers have been refurbished so it all needs bedding in. He then proceeded to bleed the rear in about ten minutes flat!! So we have brakes and a running engine. Just needed to drill and fit my numberplate onto the brackets i made, plus go and get a bit more fuel in my fuel can and we are ready! I'm now a bit apprehensive about riding it and finding any excuse to delay! Weird, but i don't want a huge anticlimax. Can't put it off any longer so, fire her up, let her warm up and off we go...as i change into second gear it starts. this really, really loud high pitch scream/screach coming from the front, jeez, everyone could hear it and the faster i went the louder it got! The speedo suddenly leaps from 40 to 70 to 60 to 70 etc. Straight back home, having done two tenths of a mile! I figure it is not the engine, i reckon something in the clocks, so i take out the speedo drive cable and try again. No noise but also no speedo. Back home again, remove the fairing and strip the clocks again!! Take out the speedo and lubricate where the cable goes into it. Refit it all, refit the speedo cable and lube it and try again. Yeeeeeeeeeeeeeey it works! So i carry on, it all works, bloody brilliant. Got home and had a beer to celebrate.
Going to check every nut and bolt and i have a few tweaks to make before putting on some more miles today. RELIEF!!!!!
Mouse
Post by Yogi on May 14, 2017 9:16:09 GMT 1
Really happy for you mate You hung in there and it's payed off Strange thing is I finally got the misses home from hospital Friday So I took my lc2 out for its first spin and hey ho exactly the same issue Haven't had time to sort it yet though Enjoy it now mate summers coming Atb Matt
Post by dusty350 on May 14, 2017 11:05:08 GMT 1
Yea, great news Andrew I never doubted you would end up with another stunning hybrid Enjoy Dusty
Post by mouse on May 14, 2017 11:10:35 GMT 1
Really happy for you mate You hung in there and it's payed off Strange thing is I finally got the misses home from hospital Friday So I took my lc2 out for its first spin and hey ho exactly the same issue Haven't had time to sort it yet though Enjoy it now mate summers coming Atb Matt Weird?? Yogi, i just lubed it with GT85 and seems to have worked. I can't thank you enough for sorting me out the speedo, really fantastic of you, especially for the running in. All the best Mouse
Post by mouse on May 14, 2017 11:11:43 GMT 1
Yea, great news Andrew I never doubted you would end up with another stunning hybrid Enjoy Dusty Thanks very much dusty, trying to put pics up but Photof****t has other ideas! Mouse
Post by mouse on May 14, 2017 19:03:48 GMT 1
So here are the brake hoses, all fitted and full of fluid
Just got to borrow a hairdryer (since i gave up my beauty regime, i don't have one!) to do the heat shrink bits on the hoses.
WELL SHE IS PRETTY MUCH FINISHED!!!!!!!!!!!!!!! Went out today, did 100 miles and no problems! Everything went well, i still have a few little bits to do, but here she is...
She is very different to my 4LO hybrid, feels a lot bigger, but feels really good. Still got to run her in, bed in the brakes and scrub in the tyres, but joy! I can't believe it has gone so well on the shake down, considering i bolted everything together, amazing!! I am really happy with the way she has turned out, i wasn't sure about the white wheels, but actually i really like them. A very happy Mouse
Post by yamark on May 14, 2017 19:10:08 GMT 1
Andrew, simply awesome and a real thing of beauty I don't think you can improve on anything.
Top work, well done mate
Post by dusty350 on May 14, 2017 19:53:12 GMT 1
Hi mate Really stunning build If I built an Lc2 hybrid - which I would love to do - it would look exactly like that ! I would mirror exactly what you have done coz it looks so right ! Another stunner Andrew - well done Dusty
Post by rostrumorhospital on May 14, 2017 21:14:02 GMT 1
Have to admit, I normaly favor the look of an LC, but when you see a PV done like yours it has to be admired, absolutley stunning, the overall look and attentension to detail is superb and particularlly like the pipes, cant put my finger on it but they just sit so well on the bike. Enjoy!
Post by marsbar350 on May 14, 2017 21:49:14 GMT 1
looks great mouse throught my own experience.get those brake hoses away from the rad grill wont take much to rub a hole in them put them 90* to the legs
Post by headcoats on May 14, 2017 22:00:24 GMT 1
Have to admit, I normaly favor the look of an LC, but when you see a PV done like yours it has to be admired, absolutley stunning, the overall look and attentension to detail is superb and particularlly like the pipes, cant put my finger on it but they just sit so well on the bike. Enjoy! I agree completely !
Post by mouse on May 15, 2017 7:41:05 GMT 1
Top work, well done mate Well thank you Mr Yamark, very high praise indeed!! Mouse
Post by bazzer5115 on May 15, 2017 7:42:41 GMT 1
Beautiful,I love my hybrids,looks and go so much better than standard bikes. That bike just looks right😄
Post by mouse on May 15, 2017 7:42:47 GMT 1
Hi mate Really stunning build If I built an Lc2 hybrid - which I would love to do - it would look exactly like that ! I would mirror exactly what you have done coz it looks so right ! Another stunner Andrew - well done Dusty Hey Dusty, thanks very much, that is very flattering. I'm really happy with her. Very different to the 4LO hybrid, feels twice the size! Mouse
Post by mouse on May 15, 2017 7:44:43 GMT 1
Have to admit, I normaly favor the look of an LC, but when you see a PV done like yours it has to be admired, absolutley stunning, the overall look and attentension to detail is superb and particularlly like the pipes, cant put my finger on it but they just sit so well on the bike. Enjoy! Thank you Sir, yes i love the pipes too. I'll say this quietly but i also think the 4LO is prettier! (hope she didn't hear!) Mouse
Post by mouse on May 15, 2017 7:45:30 GMT 1
looks great mouse throught my own experience.get those brake hoses away from the rad grill wont take much to rub a hole in them put them 90* to the legs Thanks for that, will have a check Mouse
Post by mouse on May 15, 2017 7:46:12 GMT 1
Have to admit, I normaly favor the look of an LC, but when you see a PV done like yours it has to be admired, absolutley stunning, the overall look and attentension to detail is superb and particularlly like the pipes, cant put my finger on it but they just sit so well on the bike. Enjoy! I agree completely ! Thank you very much Mouse
Post by mouse on May 15, 2017 7:48:54 GMT 1
Beautiful,I love my hybrids,looks and go so much better than standard bikes. That bike just looks right😄 Cheers! I love them too and yes it gives them modern(ish) handling and they are truly fantastic fun, I know they are not everyones cup of tea but each to their own. Mouse
