Post by butchers on Jul 28, 2013 21:20:28 GMT 1
Rd 250 D project guys having looked thru the forum for a local powder coating place i've decided to go to C J Edwards in Burton tbh i normally use Potteries powder Coaters but there opening hrs are difficult for me to take and collect so having a bit of time atm i got nearly all the parts ready. Thanks sheeney,trubrit and Norbo for recommendations i'll let ya know how i go one
Post by Norbo on Jul 31, 2013 6:57:31 GMT 1
They are very good mate you will be happy with the job.
Post by marsbar350 on Jul 31, 2013 11:08:41 GMT 1
im sure they will do an excellent job paul looking forward to this build
Post by Trubrit on Jul 31, 2013 14:12:56 GMT 1
Top Blokes Tim & Chris Ward , You Wont Go Wrong ....
Dave
Post by arrow on Jul 31, 2013 19:40:37 GMT 1
Good to see your cracking on with it.
Post by Denzil on Jul 31, 2013 21:46:10 GMT 1
Nice¥¥¥
Post by butchers on Jul 31, 2013 23:09:59 GMT 1
Top Blokes Tim & Chris Ward , You Wont Go Wrong .... Dave mate i'm well happy they are very helpful guys tbh i've a problem with the frame as its already powder coated (Red) how ever they gave great advice as to what to do and who to do it so atm i've the back frame at home. as i'm away this wk. i'll take the frame to a chemical company they recommended. Tbh they said they could probably do it but it would cause harm to the frame and tbh i respect there honesty. ;)so it looks like i'll take the frame for chemical strip on Monday 12th and collect the parts from C J wards they are working on at the same time. i'll collect the frame friday 16th Aug from the chemical strippers and drop it off at Cj Wards on the way back easy ain't it can't wait guys
Post by Trubrit on Aug 1, 2013 5:57:57 GMT 1
If You Want The Frame Picking Up From The Strippers & Taking Back To Wardys & Can sort That For You , We Are Always Round That Neck Of The Woods , Wouldnt Be A Problem At All ,
Dave.....
Post by butchers on Aug 1, 2013 23:03:28 GMT 1
If You Want The Frame Picking Up From The Strippers & Taking Back To Wardys & Can sort That For You , We Are Always Round That Neck Of The Woods , Wouldnt Be A Problem At All , Dave..... thats great Dave mate i might take ya up on that offer i'll be in ;)touch
Post by butchers on Nov 9, 2013 21:40:16 GMT 1
Post by Roofmonster on Nov 10, 2013 14:39:59 GMT 1
Starting to come together nicely! Keep up the good work mate.
Post by steve h on Nov 10, 2013 16:51:16 GMT 1
House sale? After building a new man cave
Post by butchers on Nov 11, 2013 22:12:56 GMT 1
House sale? After building a new man cave its a property i rent out mate i'm sick of it atm and today its Sold so happy days hopefully assuming it all goes thru The man shed is all tax deductible
Post by butchers on Nov 16, 2013 22:36:47 GMT 1
Post by marsbar350 on Nov 16, 2013 22:38:53 GMT 1
lookin good butch
Post by butchers on Dec 7, 2013 13:33:19 GMT 1
Post by Denzil on Dec 9, 2013 1:18:06 GMT 1
Superb work as always Butchers.
Post by butchers on Dec 22, 2013 19:24:35 GMT 1
Post by Roofmonster on Dec 22, 2013 19:29:44 GMT 1
Vapour blasted cases always look really good! - makes them look new. Good work butchers - It's coming together nicely.
Post by marsbar350 on Dec 22, 2013 20:07:13 GMT 1
real nice finish butch will pop round for me xmas wine
Post by butchers on Dec 22, 2013 20:17:47 GMT 1
real nice finish butch will pop round for me xmas wine bring ya empties and i'll sort a out with a red and white
Post by marsbar350 on Dec 22, 2013 21:06:24 GMT 1
painting those fins must have been a pain if i had done them guaranteed somewhere would have been paint free
Post by butchers on Dec 22, 2013 21:36:27 GMT 1
painting those fins must have been a pain if i had done them guaranteed somewhere would have been paint free they were a pain mate
Post by marsbar350 on Dec 22, 2013 21:38:00 GMT 1
must have been a rubik cube checking everywhere
Post by spaceman1972 on Dec 22, 2013 21:52:01 GMT 1
Looking forward to seeing the finished bike
Post by butchers on Dec 23, 2013 3:29:33 GMT 1
Looking forward to seeing the finished bike Me too
Post by 1966baz on Dec 23, 2013 10:32:59 GMT 1
Tats going to be absolutely mint. Keep up the good work mate.
Post by butchers on Jan 7, 2014 22:24:16 GMT 1
been busy doing other bits guys but while i've been waiting for a few engine bits etc i did some work on the brake calipers this is where i am today hope my tip will helps some one. Removing the piston from the brake caliper, Guys i've recently started to work on my front/rear Caliper for my 250 D project. i know folk may have there own ideas but i hope you can find something useful with my recent experience. i bought the Calipers from Andy Rdbreaker last yr and while they were stored i placed them in a bag and let them soak in oil/diesel and occasionally turned them around so it could get into the nooks and crannies etc and so i finished up with a clean pair of calipers. the first thing i did was to first crack off the two allen bolts and fixing bolts on the caliper i also thought it made some difference in removing the fixing bolts etc. Using and old banjo bolt i welded an small tube so i could fit a grease nipple at the end of it Ok after fitting the banjo adaptor in the caliper banjo hole i could now using a grease gun to apply pressure to the inner side of the piston forcing it outwards. you have to do this carefully as in my case 1 piston moved and the other didn't. to overcome this problem i inserted a 10mm allen key in the caliper opening and continued to apply pressure using the grease gun this allowed the calipers to move forward and have a clamping effect on the key, at this stage the two pistons are now clamping the key with quite considerable force so the remove the key you need to remove the pressure the only way i could do this was to remove the grease nipple but be careful thou don't be surprised if you have a squirt of grease down the front of your shirt Having done that you will be able to remove the key, refit the grease nipple and reapply the pressure. now by using control you will be able to hold either one of the pistons using a clamp or large screw driver until the two pistons are out in equal portions from there housings When you get to this tage you can now part the caliper into two halves this then allows you to clamp the piston in the vice note protecting it from damage and by rocking left to right with an upward motion will result in the caliper body being removed from the piston. so if all goes well you will have removed the piston without damage This next pics show the caliper stripped and 1 of the pistons polished showing no damage to the seal area. Good luck i hope its been of use to some one.
gringo
Post by gringo on Jan 8, 2014 22:48:03 GMT 1
Looking good mate,keep the pics and info coming
Post by spaceman1972 on Jan 9, 2014 20:11:04 GMT 1
Coming along lovely
