artie
Post by artie on Mar 24, 2013 20:28:41 GMT 1
Couldn,t even get to my garage let alone open the door,there is my car somewhere in there
Post by flames on Mar 25, 2013 17:15:14 GMT 1
not actually on my lc,but fitted kr1 frnt wheel into xj600 forks,ready to go in lc in the future.
Post by Deleted on Mar 26, 2013 10:53:15 GMT 1
Couldn,t even get to my garage let alone open the door,there is my car somewhere in there Bleedin' hell!!!
Post by copper99 on Mar 26, 2013 10:55:50 GMT 1
Thats shocking Artie...sure is bloody bad up North at the mo...
Post by steeley on Mar 26, 2013 12:27:37 GMT 1
done nothing on the lc for a couple of days to cold.engine still on the bench.itll warm up soon eh.
Post by flames on Mar 26, 2013 14:18:28 GMT 1
you are hoping arent you?? getting colder where i am.if i was ever in any doubt whatsoever,i can honestly say now,i would hate to be an eskimo!!!
r1olly
Post by r1olly on Mar 26, 2013 16:28:20 GMT 1
Started it warmed it up then thrashed it!
Post by mikee on Mar 26, 2013 21:36:12 GMT 1
New tyres delivered today Made some fancy washers and screws for the radiator Hunted for some brake lines , found one
Post by Denzil on Mar 27, 2013 1:11:26 GMT 1
Took it for an MoT and she passed first time in 25 years according to their computer system they could not tell me when the last test was if at all. So well happy just got. To get the tax and do a little more with the clutch neutral problem.
Post by grunt33 on Mar 27, 2013 2:55:16 GMT 1
About to go have a mid morning beer and put on my new fuse box that just came in the mail
Post by Deleted on Mar 27, 2013 13:54:21 GMT 1
gave the 350 a good staring at went on nk racing website www.nkracing.co.uk/n.htmwent oooooo thats nice, and oooooo thats nice Picked up the phone, ordered 6mm spacers and a boost bottle Came off phone poorer than when i picked it up
Post by flames on Mar 27, 2013 15:29:47 GMT 1
something and nothing.set to work on a differant project,but found time to poke about with kr1 wheel and xj and lc swinga.fink ive worked out a plan.
Post by theodoric on Mar 28, 2013 23:38:35 GMT 1
Collected the wheels from the painters, took said wheels to local bike shop who fitted the new bearings and seals (thanks Norbo) also fitted some new tyres. I had a few hours in the shed today so chain and sprockets went on along with the wheels and calipers. There are some more to go on this weekend but if I finsh too quickly I'll end up at the out laws so I'm pacing myself. I took a snap of Reba on the lift and for the first time in 5 months she was without an axle stand as extra support. She starting to come together now. OK I kind of cheated a bit as the silver is not diamond cut but painted instead. I figure as I'm not doing a nut and bolt must be as it left the factory rebuild it wouldn't hurt if they were painted silver instead of genuine diamond cut would it?
m1ke
Post by m1ke on Mar 29, 2013 0:09:27 GMT 1
Started putting the bottom end of my engine back together, at this point realising I had bought gasket "cement" not silicone. So need to get some silicone instead.
Post by steve h on Mar 29, 2013 0:37:37 GMT 1
Fixing bust side panel with ABS slurry (melted ABS "welding" rods in acetone) Is it a bit of a bind working on Reba Theodoric ? Kol Tuv
Post by spencerd on Mar 29, 2013 0:46:41 GMT 1
Started to wire in the VAPOR speedo unit & idiot lights
Post by theodoric on Mar 29, 2013 1:48:42 GMT 1
Fixing bust side panel with ABS slurry (melted ABS "welding" rods in acetone) Is it a bit of a bind working on Reba Theodoric ? Kol Tuv I wouldn't say it was a bind, it keeps me somewhere near sane as I've been off work 19 months. Plus it keeps me away from getting lumbered with house chores... ;D Kind of dreading getting her finished but then there is the Gamma to do next. That should keep me away from shopping duties and getting roped into using the hoover!! ;D
Post by steeley on Mar 29, 2013 13:38:51 GMT 1
got the engine in this morning.got the chain on and rivited it up then found out for years the back wheel has been out of line ,sorted now.pipes to get on ,carbs and body work.nearly done.back to work sat / sun.aprilia 50 engine to build mon.not back to work till thurs.
Post by raven13 on Mar 29, 2013 15:27:14 GMT 1
took her for the mot. failed on a lighting fault but was soon rectified. enjoyed the ride out in the sun even if it was a bit cold.
Post by arrow on Mar 29, 2013 17:34:19 GMT 1
Had a quick ride on mine today. I've been off sick after an accident at work. I'm getting my strength back now and due back to work on Tuesday.
scoobysal
If it hurts, you know ya made it.
Post by scoobysal on Mar 29, 2013 18:17:01 GMT 1
Made a bolt for clocks and putting it all together tommorow so hopefully take it out and see if everything works.
Post by jollyjoiner on Mar 29, 2013 20:01:25 GMT 1
Tripped over wheels my luminas yellow wheels in garage, couldn't see um
Post by mikee on Mar 29, 2013 20:23:47 GMT 1
Dragged it outside now the snows gone for now Made and fitted some pivot bolts ,look a bit better than the stock yam ones New res top and kill switch in the garage (somewhere) Fitted these blue hoses , but can't find the clips for them , not sure if I like them either Mike
Post by yammandave on Mar 29, 2013 22:27:44 GMT 1
Cut out and replaced filter. Took off head and replaced with one I bought from eBay
Post by yammandave on Mar 29, 2013 22:35:11 GMT 1
Post by steve h on Mar 29, 2013 22:49:35 GMT 1
Started on another side panel. It's got 10 layers of paint and is probably twice as heavy as it should be!
Post by Deleted on Mar 29, 2013 22:54:19 GMT 1
Cleaned and painted the master cylinder... Just waiting on a new sight glass to come from USA and the rebuild kit to arrive.
Post by midlifecrisisrd on Mar 29, 2013 22:56:27 GMT 1
Annoyed the neighbors by firing up the 31k at 9pm ;D
hazey
Post by hazey on Mar 29, 2013 23:03:00 GMT 1
Annoyed the neighbors by firing up the 31k at 9pm ;D Steve Well done that man ;D its your bike fire it when ya like
Post by midlifecrisisrd on Mar 29, 2013 23:09:16 GMT 1
Annoyed the neighbors by firing up the 31k at 9pm ;D Steve Well done that man ;D its your bike fire it when ya like That's what I thought, they chose to live there lol Did feel sorry for the next door neighbor as my garage door is 3m from their lounge window so Kenny's pipes and idling at 4k on choke might have disturbed their Friday night telly Steve
