Post by Delbert on Feb 23, 2013 18:54:19 GMT 1
Stole this from the fz1 forum & is an on going thing over there
All you do is post what you did to your bike , keep it as long or as short as you like / with or without pics ,,, it dosent matter
It may or may not catch on its up to you ! !
I'll go first .
Drained float bowls / cleansed fuel tap & replaced inline filters
Post by oldelsieboy on Feb 23, 2013 18:56:06 GMT 1
Nowt
Post by Roofmonster on Feb 23, 2013 18:56:47 GMT 1
Rebuilt R/H 4lo brake calliper.
Post by jollyjoiner on Feb 23, 2013 19:07:47 GMT 1
Touched it
chorltoncumrd
I need to ship up or shape out
Post by chorltoncumrd on Feb 23, 2013 19:13:24 GMT 1
checked trickle charger is working , checked wheels free to turn (bike on centre stand on piece of wood)
Post by marsbar350 on Feb 23, 2013 19:23:52 GMT 1
what did i do today on me bike took carbs off and swopped mains up to 230s permanently fitted kennys TSA pipes greased me rubber tank mounts a bit more.tank was pretty tight removing always nervous taking it off started her up god they are loud in the garage ;D ;D one question! i noticed oil coming out of the lefthand pipe none out of the right. what adjustment do i need to make thanks guys andy
Post by scoobytoo on Feb 23, 2013 19:45:19 GMT 1
Lifter the cover off, looked at it and put the cover back on
Post by rich on Feb 23, 2013 19:47:51 GMT 1
Naff all as it's in bits and the frame is still in the loft Did give the RSV a good clean though which made me feel better.
Post by jollyr6 on Feb 23, 2013 19:48:39 GMT 1
Sod all been at work
m1ke
Post by m1ke on Feb 23, 2013 19:49:23 GMT 1
Took the paint of the right hand engine case. Bought a piece of pipe to use as a fork seal driver, might put the forks together this evening too.
Post by arrow on Feb 23, 2013 20:22:36 GMT 1
Nothing today, but I like the idea behind the thread. It might remind people not to forget important jobs.
Post by raven13 on Feb 23, 2013 20:42:31 GMT 1
fitted a new front brake hose and bled it, fitted new louder horn, tacho & speedo cables. fitted new chain and adjusted it. made and fitted custom lenth clutch and throttle cables,checked the electric's(they all work. :-) removed centre stand as i dont want it. tried to fit my new end can only to find it doesnt need to get this sorted coz apart from a nut and bolt check over and the end can i think its ready for the test. ;D
Post by deltadave on Feb 23, 2013 20:50:48 GMT 1
ordered some new parts
Post by scoobytoo on Feb 23, 2013 20:53:25 GMT 1
Nothing today, but I like the idea behind the thread. It might remind people not to forget important jobs. OR forget its there in the 1st place
Post by speedysquires on Feb 23, 2013 21:09:18 GMT 1
Bought a new of pipes Going to get her ready for an MOT next week
Post by liffy16 on Feb 23, 2013 21:37:29 GMT 1
petrol tank still leaking on my ypvs rotten on the bottom r/h side been bodged then sprayed up nice so decided to do a decent repair.started welding tank up got all the rot out now solid metal but its still leaking and ive got a bloody red face from all that tacking lol
Post by davey on Feb 23, 2013 21:52:28 GMT 1
Looked and stared, stared and looked. Mine lives inside my house and is better than watching s..t tv as its pi....g down .
Post by Deleted on Feb 23, 2013 22:35:08 GMT 1
Pulled the master cylinder to bits to get ready to paint and overhaul... Odrered the bits to do it.
Post by duckegg on Feb 23, 2013 22:37:25 GMT 1
Nothing not got it back yet from getting work done
Post by Yogi on Feb 23, 2013 22:45:36 GMT 1
Drove the rebuilt engine around that I picked up on Thursday, in the back of my poxy work van cos I've been on call ever since,still I'm putting it back in me bike tomorrow,if I'm not out all night
Post by Deleted on Feb 23, 2013 23:21:58 GMT 1
just looked at it wondering when i will have the money to rebuild engine,,again
Post by x444guy on Feb 23, 2013 23:23:17 GMT 1
striped and rebuilt heads and sprayed them satin black.
Post by shandyboy on Feb 23, 2013 23:23:34 GMT 1
Took cover off it then started it up blew shit all over the garage from the exhausts
Post by steve h on Feb 23, 2013 23:35:05 GMT 1
Nothing. But took delivery of 2 very nice downpipes for my 400c.
Post by kennyroberts on Feb 23, 2013 23:48:29 GMT 1
moved it so i could clean the garage around it, then made a template for a Carbon clock face to fit in the nose fairing.
Post by steven on Feb 24, 2013 0:13:58 GMT 1
Hi, Took the brand new radiator cap out the bag, then box, to find out that after i fitted it, it would not even hold 10 psi. Pondered for ages as to wheather i should take the base gaskets off too when i replace the head gasket that is leaking, that will also not hold 10 psi. thought about taking my zed for its mot. Went and got pished, lol. Steven.
Post by billy on Feb 24, 2013 8:29:48 GMT 1
I havn't done anything to any bike today, but last thing I did was to start up the 125 as it hasn't been running for a long time. I wanted to do the same on the 350 aswell but then I realised it's broken lol. I just kicked the engine around a few turns to relube the bores etc. Hopefully it's enough. Edit: Oh now I just remembered the last thing I did, I cleaned a 125 pipe header from rust and gave it some new paint. Getting the rust off was a PITA but I got it all down to bare metal. It didn't stop the rust though lol, too much pores in the metal that the rust stays in. I have to sandblast it in the spring and perhaps do the vinaeger trick aswell. Oh the joy... Why didn't Yamaha just make them in SS instead?
Post by dusty350 on Feb 24, 2013 9:40:45 GMT 1
Done nothing to mine since last year . Been rebuilding the garage - new boiler, wiring, pipework etc. Have been buying parts for all three bikes though so will have lots to do when I can get them back into the now slightly bigger garage Dusty
Post by Delbert on Feb 24, 2013 18:30:18 GMT 1
Went for a brisk ride this morning and with the temperature just above freezing it was brisk
Post by Roofmonster on Feb 24, 2013 19:22:43 GMT 1
Tried to remove the seized bleed nipple in my caliper and subsequently snapped it off. Then I drilled it and put a screw extractor in it - which snapped off too. Now I have a very hard and undrillable extractor stuck too! I gave up and went back into the warm!! Anyone got any ideas how to get it out??
